Question about Gerber Blades Gerber TX 3.0 Tactical Flashlight Black Aluminum Body 3W Model 80048
Broke my gerber 3.0 flashlight
Drop and broke my flashlight, how do i get to the bulb to see if it's broken, and can it be repalced
Wow what entertainment. Both the poster and the bobint17 don't have a clue how this flashlight works... why answer a question you don't know the answer too? To screw with people? To sound like you know what you're doing?
Anyway, the Gerber TX 3.0 uses a Luxeon 3 LED. There is no bulb. It is not designed as a user replaceable item and unfortunately even someone skilled at soldering and such can't fix the light because the head is permanently attached and not designed to be removed allowing access to the LED assembly. Can the head be removed? Possibly. Will it damage something while trying to remove it with a lot of force? Possibly. Should you try? No. Why? Because the light has a limited lifetime warranty from Gerber. Send it to them and they will fix or replace it!!!
Posted on Dec 31, 2009
    Sergeant:
  • 270 Answers
Ok it can be replaced.remove the head of light.insert a new bulb.
Posted on Mar 03, 2009
How to tell if ballast is bad on samsung dlp tv
It is a common practice that the ballast to repalce along with new bulb. There is no way to check the internal winding short of ballast. Repalce both at the same time. If ballast has any damage, it will surely ruin the bulb too.
Jun 04, 2012 | Samsung HL50A650 50 in. TV
How do I change the battery or batteries in a Gerber LED flashlight? The bottom seems to have a black plate that doesn't seem to be removeable.
Hello. The correct way to remove and replace the battery would be to unscrew the end cap all the way. The Battery will then fall away allowing for a new battery insertion. The "plate" is not suppose to be removed (according to Gerber Blades). Hope this helps.
Mar 07, 2011 | Gerber Blades Gerber Recon LED Flashlight
How do I replace the battery or batteries in a Gerber LED flashlight? The bottom has a black plate that doesn't seem to be removeable.
Hello. The "plate" is not supposed to be removed (according to Gerber Blades). The correct way to remove and replace the battery would be to unscrew the end cap all the way. The Battery will then fall away allowing for a new battery insertion. Hope this helps.
Remove Battery to replace
Hello. The correct way to the battery would be to unscrew the end cap all the way. The Battery will then fall away allowing for a new battery insertion. Hope this helps.
Jan 24, 2011 | Gerber Blades Gerber Recon LED Flashlight
I accidentally drop my gerber firecracker flashlight, when I turn it on its not working any more.How can I detach the crown from bulb to fix the problem.Thanks for the help.
Hi I had the same problem. It seems that when I dropped it the back buttton got stucked, so what I did was to unscrew the back part (as if to replace the battery) and gave it kind of gave it a knock or hit it softly just to jiggle the button. Scre it back on and got it to work, Hope it works for you.
Jan 18, 2011 | Gerber Blades Gerber Firecracker LED...
How to remove battery from Gerber Recon LED flashlight?
Hello. According to Gerber Blades, the correct way to remove and replace the battery would be to unscrew the end cap all the way. The battery will then fall away allowing for a new battery insertion. Hope this helps.
Sep 28, 2010 | Gerber Blades Gerber Recon LED Flashlight
Gerber Multi - Plier 600 Needlenose: my knife broke on my gerber 600 a friend has an ol...
no need,send your knife to gerber and they will replace it.gaurenteed for life.
May 16, 2010 | Gerber Blades Multi-Plier 600 Needlenose
Bulb holder is broken
Just buy a new one the bulb holder cost around 18.00
Please rate fixya!
Feb 24, 2009 | MagLite Mag-Lite& Flashlight
Rechargeable mag light not working .
when you dropped it you probably knocked the contacts inside out of place. or you broke a soldered connection. if you can take it apart you can most likely fix this yourself. when you remove the front lens assembly there is a retaining clip that you need to remove so you can take the guts out.....please rate this
Sep 02, 2008 | MagLite - Mag Charger System 110v (M)...
Gerber Blades Gerber TX 3.0 Tactical Flashlight Black Aluminum Body 3W Model 80048 Logo
441 people viewed this question
Top Gerber Blades Camping, Backpacking & Hiking Experts
Tom Chichester
weirdtop
Are you a Gerber Blades Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
