Question about AEG Lavamat 16810 Front Load Washer/Dryer
C9 error AEG lavamat Princess S update
I have the above washing machine in Dutch writing and it has come up with a C9 error and the Voorwas and spoelen + lights flashing. I can't seem to get it to work no matter what I press. I have turned the machine off and the same thing comes up which turned back on. I have managed to translate most of the words to English (I'm in Australia). Can someone help me with this problem.
    Genius:
  • 1,075 Answers
Go on line and contact AEG head office by email they will email you back with instructions in english.adrian
Posted on Feb 16, 2009
What means error code "C9" ? AEG Lavamat 74652
C9Motor tacho fault •Check main drive motor •Check tacho magnet •Check tacho coil •Check module
May 27, 2014 | AEG Lavamat 88840 Front Load Washer
The machine flashes C9
On washing machine displaying error code "C9" on its' display. Normally this indicates that there is a mechanical or electrical problem with the motor (often the brushes need to be replaced).
It could also be an over-sized load of clothes in the machine, try to reset the before beginning to replace parts.
The solution is to put the dial in the off position, then turn the dial to the spin position while holding down the soak and pre-wash buttons simultaneously.
The procedure above is also necessary to reset the washing machine after replacing any parts once the error condition has occurred.
Feb 19, 2011 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 72 620 What does error code C9?
c9 means the electronics is not detecting any drum movement. check the carbon brushes in the motor this is usual culprit.
Aug 29, 2010 | AEG Lavamat 72640 Front Load Washer
What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
Error C9
Hello, to cancel the error C9 try to reset the machine by holding the start Button whilst turning the dial through 360 (from Off-2-Off).
Thanks
Jun 04, 2010 | Washing Machines
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
I need a motherboard for a aeg lavamat l62622
I have an AEG WITH ERROR CODE C9 IT WONT SPIN OR WASH ,COUNTS DOWN THE CYCLE ,FILLS BUT CLOTHES ARE LEFT A STICKY MESS ,MOTOR AND BUSHES ARE FINE ,I HAVE RESET NUMEROUS TIMES BUT STILL GOES TO C9 ANY IDEAS
Feb 26, 2010 | AEG Washing Machines
AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Jul 04, 2009 | AEG Washing Machines
AEG Lavamat 16810 Front Load Washer/Dryer Logo
669 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
