Question about Kenmore 63942 Dryer
Kenmore dryer making rattling noise
Recently I noticed my dryer was making a lot of noise. I opened the lower panel and cleaned out all the debris. I started the dryer up, but the noise continued. When I put my foot against the lower panel, the noise seemed to stop. I am wondering if there is something in the drum, or if the panel is loose and rattling. The drum is very close to the lower panel.
Any suggestions?
  • lindaseybert Feb 21, 2009
    I taped the lower panel of the dryer with duct tape and now my dryer is much quieter. Thank you for the help. You saved me some money.
  • 150 Answers
If the panel's clamps are broken it will rattle,for a quick fix i would use duck tape on both sides.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 16, 2009
Dryer makes loud rattling noise while drying
How old is your dryer? My dryer was making a horrible rattling noise and it turned out to be the idler pulley.
Sep 19, 2016 | Kenmore Elite HE4 Electric Dryer
Fix rattly noise in gas dryer
could be coins in the baffles, sometimes coins make it into your dryer, and they slide under the baffles, remove or open the top of your unit and you will see the screws that hold on each baffle, remove the screws and the baffle will come off inside the dryer with whatever is in there. then re-secure the baffles..
Oct 24, 2015 | Kenmore Dryers
We have a Jenn-Air Dryer, model JDE2000 that has recently started making an obnoxious rattling noise while running. The belt appears to be intact, the drum rotates and clothes are dry when finished. I've...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 19, 2011 | Dryers
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
When the pads on the front wear, it will make noise when running. They can be replaced. There is one on the top and one on the bottom rim where the drum turns. You remove the front to access them by removing the screws on the top. Post your model number for diagrams. It's usually stamped on a small tag in a visible location on your appliance.
Washer-Dryer- behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Mar 21, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Washer making a weird noise
I didn't get to answer this but It makes "cents" to me.
Sep 09, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore 80 series dryer.
true story.I brought my lawnmower to a friend of mine,i said to him Tony my lawnmore is making a terrable noise, he said to me worry when its making no noise...its possable a worn tension pully it would make a rattle like sound,Solution replace pully wheel!.Top of the morning to you Eire
Nov 15, 2007 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
369 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
