Question about Kitchen Ranges
Electrolux oven takes forever to preheat
We just got the brand new Electrolux EW30ES65G dual oven. I love everything about it except that it takes forever to preheat. Tonight it took over 20 minutes to get to 425.
  • Anonymous Mar 10, 2009
    Hi - I just had my Electrolux Icon double wall oven installed and the pre-heat problem is even worse. It took over an hour to get up to 350 and when I used the rapid pre-heat, it took about 35-40 minutes.
    Did your problem get resolved? I am anxious to know, because I think this is a deal breaker. At the amount of money these things cost, this is unacceptable performance.
    Thanks,
    MP
  • kathe731 May 12, 2009
    Do all of them take this long to preheat? I don't know what the rapid pre-heat is - mine must not have it.
5 Suggested Answers
  • 126 Answers
SOURCE: preheat issue with a new kenmore electric range
some of the newer ranges only pre-heat using one element. this gives them a better energy saving rating
Posted on Nov 23, 2007
  • 148 Answers
SOURCE: Takes to long to Preheat
the burner element iside the oven(the rod that glow,s orange) is burned out,even though it glows and the oven is warm,the element is worn out and has to be replaced,unplug the oven,shutt off gas supply to oven,pull off back cover youll see the rod coming thru each end of the rod will have 1 wire unplug the wire off the clip,go back to the inside the oven follow the rod to the back youll see 2 screws holding the rod unscrew and pull rod thru,easy job and elements arent exspensive,but make sure to unplug oven,and shut off gas
Posted on Jul 09, 2008
  • 1214 Answers
SOURCE: my Delonghi gas oven takes nearly 45 minutes to preheat!
I would be suspicious of the thermostat. It or the sensing element may have failed.
Posted on Jan 28, 2009
  • 97 Answers
SOURCE: Takes 20 minutes to preheat.
The unit seems to be working ok....usually the temp probe will reach temp in 5 minutes and it will beep....i sugg for cust to let sit for 15-20 mins for precise cooking.
Posted on Jun 11, 2009
SOURCE: Hi, My LG Dual Convection oven is taking over one
mine too. it took 2 hrs to get to 300. Self cleaning does not get hot enough to clean. it seemed to work for a day after that, but is not working again. i got the error F-7 but can't locate my book to see what that means. the stove is only 1 year old....have you found an answer to your problem??
Posted on Apr 12, 2010
Oven preheat times
It gas not electric. There is NO hidden element. It a bad sensor.
Mar 08, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Preheating?
Standard problem with this unit sorry to tell you! I've worked on several.The main oven would take 20-22 minutes to pre-heat, even on the "rapid pre-heat setting". I was told by Electrolux techs that it is the way the range is designed because of the "hidden element." Very sorry to tell you I found this model to just be very Unreliable. To many issues......
Jun 10, 2013 | Electrolux EW30DS65GS Dual Fuel (Electric...
My electrolux dual fuel range had to have the control panel replaced within the first 6 months, now it is out again, this time not under warranty and will cost me about $800. Has anyone else had this
Hi katnbiff - This is typically something that a professional would need to diagnose. Possible causes could be a faulty EOC (electronic oven control), thermostat, or an oven sensor.
Sep 14, 2012 | Electrolux EW30DF65GS Dual Fuel (Electric...
My oven takes forever to heat up if it does at all
If it's a gas range and you can see the ignitor glow, but there is no flame within 90 seconds after you turned the oven on - replace ignitor.
First Choice Appliance, Sacramento, CA
Jul 08, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven takes forever to preheat
The way the oven works is like so:
1) User sets the desired temperature
2) Power is sent to the ignitor
3) The ignitor is then energized, drawing 3.2 amps of current
4) When the 3.2 amps is drawn, the gas safety valve is allowed to open and gas flows into the burner assembly in the oven.
5) This gas is then ignited, causing the oven to heat.
6) As the oven heats up, the oven sensor, which is the metal rod located at the top on the rear oven wall, converts the heat into an electrical signal, relaying this information to the main control which in turns displaying the temperature.
(In models with a dial thermostat, there won't be a sensor, though a metal wire with a bulbous end will be present, which is actually connected to the thermostat.)
Jun 21, 2012 | GE Kitchen Ranges
Takes forever for my oven to preheat to 400*. 25 minutes or so. Oven is brand new.
A brand new oven should work. You should not tinker with a brand new oven. A brand new oven that is malfunctioning is probably under warranty and should be repaired under that warranty.
Viking is the Rolls Royce of kitchen equipment. Call your installer or builder or Viking for service for your brand new oven.
Thanks for your question @ FixYa.com
Mar 13, 2011 | Viking Professional VGSC3666BSS (Dual...
My oven take forever to preheat! Help..
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 28, 2010 | GE Spectra JBP78 Electric Kitchen Range
Nov 26, 2009 | LG 30 in Kitchen Series Dual Convection...
My Delonghi gas oven takes nearly 45 minutes to preheat!
Jan 28, 2009 | DeLonghi DEFSGG36-SS Gas Kitchen Range
Problem with oven preheating
Hi, I'm Neil
It is a fire hazard! Be Careful!
It's a gas regulator or thermostat
This time you will have to call the the manufacturer for service!
If it's under a year old ,your under warranty and it will not cost you anything!
Please give me a solution rating here!
Thank You
Neil
Jul 14, 2008 | Maytag MGR5750 Gas Kitchen Range
Kitchen Ranges Logo
401 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
