Question about Toshiba (K000016310) Cooling Fan
I have a Toshiba Satelite Laptop with a bad cooling fan
Where can I find a replacement cooling fan or a Toshiba Satelite laptop
model # PSMB0U-015007
  • 77 Answers
Contact Toshiba Parts  here http://www.tacp.toshiba.com/customersupport/parts_accessories.asp
Posted on Feb 16, 2009
How to change the cooling fan in a toshiba laptop model p200d-139
Instructions
Shut down your Toshiba laptop, and then disconnect all cables. Close the LCD lid, and then place the laptop face down on a flat surface. Position the laptop with front edge facing you.
Locate the battery pack near the top section of the laptop's bottom casing. Press on the battery release button. Remove the battery from the laptop.
Locate the cooling fan compartment cover. Its location varies from laptop to laptop, but it will be the only hardware cover with a vent in it. Remove the Phillips-head screws securing the fan's cover in place. Remove the cover from the laptop.
Disconnect the fan's cable from its connector on the motherboard. Remove the Phillips-head screws securing the fan in place. Lift the old fan out of the fan compartment and set it aside. Removing the old fan will reveal the processor chip. Apply a thin coat of thermal grease to the processor's surface using a clean paper towel. This will prevent your new processor from frying once you power on your laptop.
Place the new cooling fan assembly inside the fan compartment. Align the screw holes on the new fan with the screw holes inside the compartment. Replace the four retaining Phillips-head screws, and then reconnect the fan's power cable to the motherboard. Replace the fan compartment's plastic cover, and its retaining Phillips-head screws.
Replace the battery pack and reconnect all power cables and external devices. Turn on your laptop to test the new cooling fan
Jul 28, 2012 | Toshiba Computers & Internet
Toshiba satelite works one day ,not the next
Groan?
Cooling fan, or harddrive.
Only two movable parts, besides the optical drive. (CD/DVD drive)
I suspect the cooling fan. Why?
Inside your laptop is a Processor. It, like the other hardware components inside, are cooled by air. That little fan is all that pushes air through the laptop.
Here, let me use a Toshiba Satellite C650 series of Notebook PC, as an example,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-3.htm
Scroll the page down, click on the photo next to Step 22.
Here you see the TOP of the cooling fan.
Close the photo. Scroll the page down, and click on the photo next to Step 24.
Fan Assembly removed.
That fan sits in bronze bushings. The bushings look like thick tubes, and the fan's shaft sits in those bushings. (One one top, one on bottom)
After time the bushings wear out. This allows the fan to c-ock over to one side. Plus makes a groaning sound.
Solution?
Replace the Fan Assembly.
One example,
http://www.laptopking.com/kingpartdetails.asp?ref=1443&category=fan
Now, am I stating that THIS is the problem?
NO.
I am stating this is the first place to start.
If the laptop is dirty inside, it is almost a sure bet that this is the problem.
Why?
Because if the fan bearings are dry, and worn out, the fan will not operate as it should. It will spin slower than it should, and may have periods where it just stops altogether.
This allows the Processor to overheat. When a Processor overheats it turns off. (BIOS turns it off)
This is a fail safe feature built-in. Keeps the Processor from burning up.
No Processor operating, no computer.
Want to replace the Fan Assembly yourself? No prob! Doesn't take a rocket scientist. (Sorry Gort)
HOWEVER, there is a PROPER procedure. Post back in a Comment, that you want to replace it yourself, and I will guide you.
{Plus you will be cleaning out the inside of that laptop }
Regards,
joecoolvette
[ Article first page,
(Page numbers are at the Top, and Bottom of the page, in white.
Page1 :: Page2 :: Page3 :: Find another model )
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-1.htm
Jun 20, 2012 | Computers & Internet
Model number for the interior cooling fan, for a toshiba laptop
I have found a link to a web site that sells them but they are dear they have the product code also for your fan so you might get one cheaper on ebay or something.
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&cPath=66_140&products_id=1250
Feb 25, 2010 | Toshiba Satellite A105-S4074 Notebook
I have a toshiba satelite and it keeps freezing every 10 minutes
Sounds like the Processor fan is not working.When you turn the unit on , llisten for the fan . If it is not spinning, it is bad. The reason it shuts down is to protect your unit from further damage. Let me know what model, and I will see if I have the service manual or the instructions on how to replace the fan.
Nov 20, 2009 | Toshiba Satelite 5205-S505 Notebook
Toshiba satelite a45-s130 manual
turn on my toshiba satellite a45-s130 hear one beep and the screen stays on for a couple seconds and shuts off.
Nov 03, 2008 | Toshiba Satellite A45-S130 Notebook
Toshiba celeron satellite cooler replacement
first.you can find the processor fan in some computer shop,but i dont know if they will give you.second,check the model # of the fan and check in the internet for delivery or else,you can repair the fan by replacing the dynamo of the fan with another model of fan,just anly remove the screw of the fan and try to find another model fan and replace the dynamo fan.
This kind of issue is i try with some of my customer because they cant find the same model of fan.
Sep 18, 2008 | Toshiba Satellite Laptop Cooler
Toshiba Satelite M10 cooling system not working
If you DO NOT hear the fan running, have it looked at by a professional. Your fan may have died. If you can hear the fan running, blow out the fan exhaust port in the opposite direction of normal air flow. Especially on lap tops, the heat sink cooling fins become completely clogged with dust. When this happens the processor overheats causing it to run slow and eventually shuts itself down to keep from going super nova. You should blow it out at least once or twice a year. Also, if you use your laptop on the couch or in bed, place it on a hard surface like a cutting board or something similar that will allow air to flow underneath the computer. This will also help prevent dust from the cushions or blankets and such from clogging the cooling fins on the heat sink faster than usual. Remember blow it out in the opposite direction of normal air flow. You want to blow the dust out the same passage it came in through.
Sep 15, 2008 | Toshiba Computers & Internet
Mother board crashed
Most likely replacing your motherboard will cost a ton of money (either the part, or the work and labor will cost a lot) . It would probably cost less to buy a used laptop with the same specs:
http://cgi.ebay.com/Toshiba-satellite-m115-s3094-core-duo-laptop_W0QQitemZ250273284600QQihZ015QQcategoryZ177QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
If your laptop is under warranty, disregard what I just said, but if it isn't I would sell your broken laptop on ebay, and buy a new or used one.
If you want to keep your old data, you can just swap out your hard drive.
Hope this helps.
Jul 27, 2008 | Intel Motherboard
My satelite a100 laptop overheats and shuts down
Your cpu cooling fan may need to be replaced.
Apr 17, 2008 | Computers & Internet
Toshiba satelite a45-s151 not turning on.
Toshiba Equium a60 PSA67E-00200D8J, I would like to know whow to install Igb ddr ram on this laptop details and advice would be great.
Apr 09, 2008 | Toshiba Satellite A45-S150 Notebook
Toshiba (K000016310) Cooling Fan Logo
505 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
