Question about Canon Sure Shot Z155 Caption 35mm Point and Shoot Camera
Film door does't stay closed.
Accidently dropped camera. When went to reload film door will not stay closed. Doesn't seem to catch!
  • 538 Answers
Broken door latch.
Needs replacement.
Posted on Apr 02, 2009
SOURCE:
I have a Pentax ME super and the film door will close when there is no film but when i load it with film its not closing properly?
I really loved your camera type though it was 35 years ago I had one. I envy you.
Not sure why you should be having trouble unless you have a bad film. Have you tried more than one film?
If the film cassette has dropped in properly and is laying flat, the film rewind has to be raised, I think, to allow that and the sprocket holes in the film are properly engaged with the sprockets and the free end of the film engaged onto the film wind-on reel then everything should be well below the door aperture.
I would wind on maybe a frame and fire the shutter prior to closing the film door just to observe everything moving as it should and then close the door.
The last quarter inch the door must be closed against the pressure of a spring but if the little spring-loaded device behind the door which is intended to keep the film perfectly flat against the camera body is working correctly only a light pressure will be needed to compress those springs and close the door.
Perhaps something is wrong there?
I don't remember any problems closing the film door.
I hope this helps but if it doesn't please come back again and describe your actions and the feel of the door more fully.
Feb 04, 2015 | Pentax ME Super 35mm SLR Camera
Camera will not accept film. I added a new roll of film and it says there isn't any film in the camera. It worked fine the last time I used it..
I am guessing that you just do not have enough lead in the sprocket to catch the film. Try reeling out a half in more film and reloading. If that does not fit the excess film just trim it a bit and try over.
Apr 20, 2014 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
http://www.lensinc.net/manuals/Nikon_N6006L.pdf
Nov 03, 2010 | Nikon N80 35mm SLR Camera
Camera won't work, has an E on the display
If E blinks in the exposure counter, the film is improperly loaded. Reload the film.
Her is the link to the Olympus website where you can download the instruction manual
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=298
Feb 13, 2009 | Olympus Stylus Zoom 80 Wide DLX 35mm Point...
Can't close door after loading film.
sounds like the door latch broke. (tape) Canon will only replace/upgrade not repair.
ours cracked after a drop then broke replacing the film.
Jan 07, 2009 | Canon Sure Shot Z155 Caption 35mm Point...
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
ERR sign keeps blinking in the lcd
First check the batteries. Are they fully charged? If you still have the same problem, try this:
Is the film (that which did not rewind fully) still in the camera? If so, open the film chamber door once in a dark room and close it again. Try to rewind the film again. This could possibly be the result of the film getting stuck somewhere, preventing the camera from rewinding it.
Mar 18, 2008 | Nikon F80 35mm SLR Camera
FILM REVERSAL
does anybody know a freakin solution????
Jan 09, 2008 | Nikon N55 35mm SLR Camera
Camera not working-please help
No promises but if you take a roll of film that is already light fogged etc. and load it into the camera. Let it wind as normal. Now we need to work quickly: Press the rewind button. While it is winding OPEN THE BACK. It won't rewind very long because very little film is out of the cartridge so be ready. This will fogged a bit of the film but it does seem to clear the error. You can still shoot the roll if you just skip the first few shots.
Dec 06, 2017 | Fuji Zoom Date 60 35mm Point and Shoot...
Canon Sure Shot Z155 Caption 35mm Point and Shoot Camera Logo
227 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
