Question about Dell Inspiron 1000 Notebook
Laptop will not boot up on its own power.
Hello - I have a Dell Inspiron 1000 which rarely has been used. If I run the laptop using the apower adapter it runs like a champ. No Issues, at all. However if I unplug the power adapter and move the laptop to any other location, it will not boot up al all. Its like all the charging had no effect on the battery - No power whatso ever. If it runs on the power adapter, I dont believe that the motherboard is the issue. Is this a typical battery issue question ?
Thanks, Sal
  • spepe Feb 16, 2009
    Hi - When looking at my options, the battery has a red 'X" running thru it. It appears that the charging has not worked. Is it possible the charger is bad ?
    Genius:
  • Dell Master
  • 1,102 Answers
Check in your power options make sure settings are correct for shutdown and stanby ETC
see if battery is showing fully charged or not in your power options
If everything is okay for power options then you need a new battery
please let me know and don't forget to rate
thanx
Posted on Feb 16, 2009
  • DEKR
    DEKR Feb 16, 2009
    could possibly need new battery but we will try some solutions first
    remove battery then startup pc
    let it run a few minutes then shutdown and replace battery
    startup again and got to device manager and see if there is a ? or ! beside battery
    let me know
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Dell inspiron 9400 not booting up. no light in display. num keys and caps locks flashing
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jan 28, 2011 | Dell Inspiron 9400 Notebook
My dell Inspiron 1000 model pp08s when pluged in the computer wont turn on and the green light on the adapter flashes on and off
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad
5. The motherboard could be defective & needs to be replaced.
Sep 17, 2010 | Dell Inspiron 1000 Notebook
My dell inspiron 1000 Model pp08s wont turn on
My dell vostro 1000 won't turn on the green light
Try to do this: (Draining flea power)
1. Unplug the ac adapter (if connected)
2. Remove the battery
3. Press and hold the power button for at least 10sec.
4. Put back the battery and ac adapter
5. Turn it on
- check if you can now boot to windows, if not there could be a hardware problem and next step would be running some diagnostic test on the computer for hardware problem.
Dec 07, 2009 | Dell Vostro 1000 Laptop
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Connecting using wifi
If you go into the device manager and click on Network adapters, is there a wireless adapter listed there? Are there any items that have an exclamation mark next to them? If you answered no to both of the above questions, then there is no wireless adapter installed. You can purchase a PCMCIA wireless adapter rather inexpensively online. ($25) It will just pop right into the PC slot on the side of the laptop.
Dec 04, 2008 | Dell Inspiron 1000 Notebook
Ac adaptor use drains batteries
As a system gets a little age on it, the battery naturally decays. Also, each time you plug the ac adapter into the laptop, the adapter connection on the motherboard becomes a bit looser on the solder points, all of which contributes to the symptoms you describe.
You could try a fresh battery.
The standard rule is a battery is wireds to last between 500-600 cycles, then it's dead. They claim it's a safety feature.
Good luck, hope that helps.
Thanks
Jan 31, 2008 | Dell Inspiron 1000 Notebook
DELL INSPIRON 1000
Try the following:
1. Try to boot the notebook with both battery and adaptor attached.
2. Try to boot with ONLY the battery.
3. Try to boot with ONLY the adapter.
If you can't boot with only the adapter, the adapter has died. If you can't boot with only the battery, the battery is dead.
But as stated above, make sure your battery is sufficiently charged.
In case of a dead battery or adapter, check whether the device is still under warranty. Contact HP if so.
Let me know what you found out.
Greetings,
DarkNeogen
Jan 24, 2008 | Dell Inspiron 1000 Notebook
Dell Inspiron 1000 Notebook Logo
101 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
