Question about Singer 3343 Mechanical Sewing Machine
Singer 15 thread breaks and doesn't sew
I haven't sewn in a while, can't get the machine to sew, I know its operator error, but I'm not sure how to fix the problem. Please give me ideas on the approximate tension. TXs Rose
  • 1,906 Answers
If the upper needle thread is breaking adjust the thread tensioner if the bobbin thread is breaking adjust the bobbin tension screw on the bobbin case
Posted on May 03, 2009
My singer confidence not forming loop to pick up bobbin thread
Make sure the correct thread and needle are being used for the material sewn, and sometimes you have to re thread.
Apr 27, 2017 | Singer Sewing Machines
I would like an instruction manual
[PDF]5, 6, 8, 10 Stitch Sewing Machine - Singer
www.singerco.com/uploads/download/448_5_6_8_10_slide.pdf
exclusives, like a removable extension table ... This Singer Sewing Machine was tested according to. European ... Read all instructions before using this machine. ....The needle and thread you choose will depend upon the fabric being sewn.
Instruction Manuals ' Singer Sewing
www.singerco.com/support/instruction-manuals
Our replacement instruction manuals are provided in a downloadable PDF file ... To download a manual, you will need to know your machine's model number.
[PDF]INSTRUCTION MANUAL 9960 - Overstock.com
www.overstock.com/.../Instruction_Manual_14253523.p...
Overstock.comThis sewing machine is not intended for use by young children or infirm persons without ... The wrong plate can cause the needle to break. 12. Do not use bent ...
Free Sewing Machine User Manuals ' ManualsOnline.com
homeappliance.manualsonline.com > Household Appliance
Find the user manual you need for your home appliance products and more at ManualsOnline. ... First Virtual Communications Sewing Machine Manuals.
Manual Finder « Sew it Works!
Jan 07, 2016 | Sewing Machines
My Singer 648 is having a problem with the bobbin thread getting caught up in the bobbin case and jamming the thread inside the case breaking the thread. Is there a solution to this problem? Thanks
try changing the needle
make sure the top thread has not come off the thread take up lever
try another bobbin
make sure the bobbin is turned the right way in the bobbin case
try rethread the machine top and bobbin
clean under needle plate and in the bobbin area for lint or threads
Jan 06, 2013 | Sewing Machines
How to thread twin needle on singer
Look in your attachments for the secondary spool pin. Then you'll thread both upper threads as normal.
Jul 30, 2012 | Singer Sewing Machines
Singer solid state-bobbin part
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine. Also use a ball-point needle on t shirt material. Good luck!
Nov 02, 2008 | Singer 5050 Mechanical Sewing Machine
I have the same problem, new machine, and I haven't sewn a stich.
Machines should be bought from local dealer who actually has a clue how to show someone to us it. Sorry for your problems but commonly they are operator error
Oct 14, 2008 | Singer 2732 Mechanical Sewing Machine
New machine now working
pull out the plug to reset it self good luck.
Apr 06, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer 3343 Mechanical Sewing Machine Logo
274 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
