Question about West Bend PERCOLATOR
Need new lid and glass top
My plastic see thru top is broken, and I tried to get a new glass one generic. And messed up the lid!!
Need whole new lid and top
  • ebecker1 May 01, 2009
    see thru glass/plastic knob on the lid is broken , where can you get replacment part?
  • 33 Answers
Try this !
http://www.abtecparts.com/westbend.htm
Try this to order all of your part needs
Please don’t forget to rate me!
Thanks
eric
Posted on Feb 16, 2009
Faster than me looking it up 10/10
Posted on May 01, 2009
I want to replace lid on my cabrio model wtw7800xw2 with a solid lid frame on glass lid keeps breaking
If all you want to do is to replace the lid, there are two TORX 15 screws on each side. Undo those and the lid should slide right off the pins. Be careful to not drop them into the tub or dispensers. You can then slide the new lid right on. Put the screws back on and test. If you lift the top cover off and mess with the springs, it is a PAIN to take off and put back on.
Feb 11, 2014 | Whirlpool Cabrio Washing Machines
My dear wife took the lid handle off our breville gourmet wok. The pieces include a screw, a spring and 3 other parts. Im not sure if i put it together properly. Could you help out. Thanks
This is for assembling the Breville Wok lid. This has a built in vent that lets steam escape during cooking. There are 8 pieces not including the glass cover: bolt, metal vent, black O ring, tan round plastic piece, black lid piece (has open/close) on it, spring, clear plastic seal, lid handle.
Order of assembly as follows, starting on inside of glass cover.1. Bolt.2. Metal vent piece sits on top of bolt.3. Black O ring fits snuggly onto of vent piece.Insert what you have assembled against inside of glass cover, bolt poking through topside of glass.4. Add tan plastic piece with 3 prongs going facedown against the glass hole of cover.5. Larger black lid piece goes next. You will need to line up the openings on tan piece and this lid piece so that it sits semi-flush against glass. When complete this piece will turn in place to open/close vent (less than 1/4 turn before stopping).6. Add clear plastic seal to underside of handle.7. Place spring between handle and top of black lid piece and screw together until snug.
Test lid by turning lid piece. It should move back and forth according to the open/close print on top. If no luck, go to step 5 and try again. It is a little tricky, but does work when done correctly.
Feb 02, 2011 | Breville EW30 Gourmet Non Stick Electric...
Whirlpool Cabrio WTW6600SW0. I need to replace the lid but ...
do you see about 2-4 inches down a crease that runs all the way around the top?
there are 2 clips in the front you need to push in with a putty knife and lift the whole top up.
if you where to look at the very left corner and go about 5-6 inches in you will find the clips.
can be a pain.
make sure when you do lift the whole top that you hold the lid or it will crash into something.
let me know if this helps
May 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
How to replace passenger side mirror. Glass is
You can usually just replace the mirror, any commercial auto-glass store has the glass you need. sometimes it is necessary to replace the mirror and its backing (a plastic frame which snaps into the adjustable motor) you don't need to replace the whole mirror unless the housing is broken.
Please rate this answer. Thank you.
Apr 07, 2010 | 2003 Chevrolet Silverado 2500HD
Clasp to lid console top box broken. How do you
This part is available at your local Infiniti dealer. The plastic part is replaceable.
Feb 09, 2010 | 2008 Infiniti FX35
Need plastic handle on Rival Crockpot lid.
easy fix go down to your hardware store and buy a big wooden knob (like you would put on a cabnet to open it) it will even come with its own screw for .99 ! . you will have to snap off with a plyers and a screwdriver whats left of the old knob from the lid . but this fix works great and looks good too !
Mar 25, 2009 | Rival 5070 7-Quart
For what it's worth, when the handle on my mother-in-law's crockpot broke, I went to Home Depot and bought a cheap wooden drawer knob (about $1 as I recall). I put a plastic washer between the knob and the glass and another under the screw head from the bottom (to prevent cracking the lid), tightened the screw and good as new.
Feb 20, 2009 | Rival 38601 Smart Pot 6-Quart
I am Jo Anne Gomez who posted original problem and thought the problem was resolved with husband putting on a knob he found at the hardware store. Just wanted to let you all know that the handle we thought would solve the problem DID NOT....after he replaced the knob and we did another roast in it the lid totally shattered after we'd cooked another roast (luckily the glass did not get into the food), however, this is just a BAD PROBLEM and these lids should ALL be recalled. I have seen, just recently, the exact same crock pot and lid being sold for much less. I think that these crock pots should not even be sold but taken off the market to prevent lawsuits or horrible problems. Just wanted to let you know our solution did not work and Rival was not helpful at all.
Jun 23, 2008 | Rival 38601 Smart Pot 6-Quart
On amazon you can find every single type of Rival Crockpot lid handles. take a look here HOOK UP Connect Customize Entertain and chose yours (which one fits). cheers
Nov 20, 2007 | Rival 38601 Smart Pot 6-Quart
West Bend PERCOLATOR Logo
227 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Steve
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
