Question about Garmin Edge 305 GPS Receiver
Garmin Edge 305 HRM problem
My husband and I both have a Garmin Edge 305 for cycling. We both wear the heart rate monitor. Mine has worked perfectly for a year but recently it has been sporadic and today I did not wear the chest strap but my Garmin was picking up his heart rate when we rode side by side. After the ride, I took mine far away from his and tried to "sensor pair" again so that my unit would pick up my heart rate. Now I can't get anything but his heart rate on my unit. Is there any way to cure this?
  • anniebikes Feb 16, 2009
    additional info...I have replaced the battery on my unit, gotten far away from his unit and "paired" again, all to no avail. I know my Garmin unit is working for heart rate as it picks up his heartrate. There has to be a pairing problem between my strap and my unit as I know my unit works! Very frustrating. I have also tried turning off the accessories in the unit, powering down, then turning the unit back on, pairing again, and no luck. Help, please!!!
Try to pair his unit with your strap and it won't work, you have a bad strapl
Posted on Sep 08, 2009
I just received a brand new Garmin FR 60 with HRM monitor strap and ANT USB from Amazon. I followed the directions to use the strap[wet the electrodes, strap it over my chest, with the Garmin logo facing...
navigate using mode button to enter into watch's menu tree for settings/ sport/ run/ heart rate and turn on the heart rate monitor to hopefully detect and scan for the garmin ant+ protocol heart rate strap!
Sep 22, 2011 | Watches
I can't get the bpm heart rate data field on the unit. I have just turned it on first the first time today and mistakenly said that I didnt have a heart rate monitor. I have tried including it in the...
Hi, it is easy to rectify, goodness knows who writes the programmed for these, simply perform a full data erase 1. turn off unit 2. press in on mode button and power button at same time 3. the unit will ask you do you want to erase 4. select yes with right hand down button. now you will start from scratch again and can set hrm...
Mar 09, 2010 | Garmin Edge 305 GPS Receiver
I haven't used my Garmin Forerunner 305 for over a year - but have just started using it again. It wasn't picking up my heart rate from the HRM, so I changed the battery in the HRM but it is still not...
I found this on the internet......
In the battery compartment there’s a gold contact that touches the top of the battery (+ve) which was in a position that would never make contact with the battery. I bent it out slightly, made sure the battery was seated correctly (i.e. flat) and as if by magic my heart rate appeared on the large Garmin display!
Also found this..........
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80
Hope this helps......
Feb 09, 2010 | Garmin Forerunner 305 GPS Receiver
My garmin forerunner 305 HRM suddenly stopped working. I thought it was a bad battery so replaced that, and still nothing. Any other suggestions?
Nov 01, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin 305 Edge and GSC 10 not receiving one another
Solution copied from Garmin
Pairing the Edge 305 and sensors
Once you have installed the Garmin Edge 305 and the cadence sensor they need to be paired. As they communicate wirelessly with each other the Edge needs to connect to each sensor before it can receive input from it.
The initial pairing needs to be done away from other wireless systems this allows the Edge to pick up the sensors it is supposed to be monitoring. This is a little like black magic, but it seems to work quite easily.
The cadence sensor has a small press contact which puts the sensor into pairing mode. The HRM just seemed to connect by itself.
Subsequent pairing is much faster as the Edge 305 seems to remember which sensors it is paired with. If you have problems or need to change one of the sensors then you can use a setup feature to either turn the sensor off or to re-pair it.
Feb 22, 2009 | Garmin Edge 305HR GPS Receiver
Heart rate zones
Heart rates are known by the garmin software as zones, numeroted 1 up to 9.
You can set on the software your heart rate, based on :
- HR max ;
- intermediate HR, linked to the zones.
Then, when you upload a session in the software, you will analyze the zones you ran in.
Another tip : to set on the Garmin itself, the Zones to ON,then Z0 to ON, and Z0 HRM to ON : here you can indicate your HRM low (ex : 165 for me) and the HRM High (185 for example). Then during your session, an up or down arrow will appear, indicate if you run below your HRM low (aerobic zone), your anaerobic zone (betwin HRM Low and High) or in VO2 max.
Hoping that's clear and that can help you.
Feb 20, 2009 | Garmin Forerunner 50
Garmin 405 pair to wrong HRM
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80)
Jan 04, 2009 | GPS
Garmin edge 305 heart rate sensor does not work
the rescan worked for me, didn't know it existed, briljant. Follow list below:settings/system/accessoires/rescan
I love google today;o)
Mar 21, 2008 | Garmin Edge 305 GPS Receiver
Garmin Edge 305 GPS Receiver Logo
574 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
