Question about Sony VAIO PCV-W600G PC Desktop
Computer shutsdown unexpectedly
My computer just suddenly shutsdown without any warning and the power button does not turn it on, i have to unplug it and wait at least 10 seconds before putting it back in, when i boot, it asks me to go into power settings, I have tried loading the default settings and booting but it takes me back to the same screen. At first i thought it was overheating so I left it unplugged for a night and let it cool down, when i boot up, i logged into windows and tried to make a recovery disk but it shut down halfway through. I tried turning it on again and it just shutdown while I was on the power settings.
I think its a hardware problem.
  • timurbeketov Feb 16, 2009
    thanks, i cleaned out all the dirt and dust and when I booted up, both my fans worked
    But what i think is wrong is when i boot, it asks me to go into power settings for my two fans, unfortunatly, i dont know much about that
  • 77 Answers
It sounds like it is overheating. Take the side off the case and see if your CPU fan works. Replace any fans that do not work or feel loose. And while you are at it, take a can of air and blow the dirt out of it.
Leaving it off overnight will not prevent it from overheating. A computer can overheat in a matter of seconds under the right circumstances.
Posted on Feb 16, 2009
Compute turns on, lights light up, and fans move, but there are no beeps or bios showing up.
Computer turns on but no display. This issue is commonly caused by electrical static on the motherboard. Try doing a power drain.
If this computer is a laptop:
1. Turn the computer off by pressing the power button for a bout 5seconds.
2. Take the battery out of the computer.
3. Unplugged the ac adapter.
4. Press and hold the power button for about 30 seconds. (without any power source)
5. Put the battery back in and plug the ac adapter back into the computer.
6. Turn the computer back on.
If this computer is a desktop:
2. Unplug the power cable from the computer.
3. Press and hold the power button for about 30 seconds. (without any power source)
4. Plug the power cable back into the computer.
5. Turn the computer back on.
Thank you for choosing FixYa! have a good one!
Jun 02, 2011 | Computers & Internet
HP pavilion ze4300 will not shut off.
Two things you can do, you can hold down the power button, keeping it held down, should power it off. The other solution is to remove the battery, this should cause the Notebook to power down
Feb 28, 2011 | HP Pavilion ze4300 Notebook
Laptop shutsdown unexpectedly
It shutsdown because your Computer is overheating so its protecting it, i recommend you cleaning your fan it must be clogged with dust bunnies, open it on the bottom grab a blower and gently bow away dust
Jun 04, 2010 | MSI MegaBook S250 Notebook
Using windows xp the system shutsdown again and again during my work without giving any warning, however working with windows ME it works smoothly, why?
Windows XP "works" the CPU more than Windows ME.
So, the computer heats up, as the CPU works "harder",
and the computer overheats, and shuts itself down.
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air, and give the computer a "blow-job", to blow out all the accumulated dust, which is acting as an insulator, preventing the air-flow in the laptop from cooling itself down to "normal" temperatures.
Jan 02, 2010 | IBM ThinkPad T22 2647 Notebook
I have a Vostro 1700 laptop. Normally i would press the start button the laptop to start up the computer, but recently, when i put the power switch on on my plug socket on the wall the computer just starts...
- buttons, especially the power button could be grounded. This needs replacement and repair. You will need to contact the manufacturer for support if warranty is still active. A technician needs to be there to replace some parts
- The reason why the computer went straight to diagnostic mode is because the power button could be grounded since it's turning on automatically when plugged and when the power was disconnected the system shuts down unexpectedly. Turning on a computer that experienced unexpected power loss may result to running in diagnostic mode
- You might as well check the battery.
Dec 26, 2009 | Dell Vostro 1700 Notebook
Unexpected shutdown in dell inspiron 1545
it's not clear if the laptop shutsdown while in use or while its idle. it it shuitsdown while its idle meaning keyboard and mouse not touched for about 5 minutes this might caused by the power options from the control panel. try to turn off the power options make sure it is set to never.
if shutsdown happens while moving mouse and touching keyboard this might be cause a conflicting windows update. try to reboot computer the boot to F8 then select last known good configuration. if this fails try to run PSA test. power off the laptop then press and hold on the Fn key then press power button at the same time just one, this will run the pre-boot self assessment to check memory and hdd problems, once you see colors display press Y to continue testing, take note of any error code might display such as 0142 and 0146 this are hard drive issues and might needing to replace your hdd.
Nov 12, 2009 | Dell Inspiron 1545 Notebook
Cannon printer quit working suddenly.
Is it possible that the cord came unplugged from the transformer itself instead of the printer or wall plug?
A power outage shouldn't affect it, but a power surge can. Please use surge protection circuits on your computer equipment. It's so much cheaper than repairing or replacing them.
Take it from someone who learned the hard way....
You can try a printer reset. Turn the printer off, unplug the power and data cables from the machine. Wait at least ten minutes to allow the printer cache to be purged.(Canon's recommendation)
Then plug back in and turn on.
I hope this works for you! Good luck!
Apr 10, 2009 | Office Equipment & Supplies
Computer shutsdown unexpectingly
please contact dell customer support, they will help you out in this.
Go on dell.com.
They ask you for service code which is alphanumeric tag written on sticket of your computer.
Rate me Rate me.
Mar 27, 2009 | Dell Inspiron 530 Desktop Computer
PC Shuts down suddenly without warning
As u would 1st know that there is a perfect power supply of 220-230V,
& if Yes try replacing the SMPS, If you still hve the same prob thn its, Motherboard problem, As i am a technical person & Faced many problems like these.......
Mar 12, 2009 | Computers & Internet
Compaq V4325 power issue
Most likely it sounds like an issue with the motherboard the only thing you can do in this case is return it to the manufacturer for a replacement. Sorry
Dec 26, 2008 | Computers & Internet
Sony VAIO PCV-W600G PC Desktop Logo
239 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
