Question about Brother MFC-640CW All-In-One InkJet Printer
I cannot get my printer installed on my computer i cannot figure out where the usb cord connects to the printer
  • 214 Answers
The USB socket is above & to the left of the ink cartridge slot. Here is a link for the manual, on pg 15 is a diagram for you to see. If this helps, plz rate this 'fixya'. Thank you kindly.
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc640cw_all&type2=8&flang=English&dlid=
Posted on Feb 16, 2009
    President:
  • 2,692 Answers
Download the users Maunal for your model. Link below:
http://www.brother-usa.com/SiteSearch.aspx?sk=MFC-640CW
Printer offline
You did not specify if printer was formerly working, the model # of the printer, or what version of Windows you are using. All this information is needed for successful troubleshooting. However, the below is general resolution for your problem:
"Offline" means your computer cannot "see" the printer as connected and powered on.
In order of things to try:
1. Turn printer OFF. Unplug USB cord from printer (or other end from computer). Wait at least 30 seconds. Plug USB cord back in. Turn printer back on. Does it still show as "offline" under Start --> Devices & Printers?
2. Try replacing the USB cord (yes, they can and do go bad).
3. Turn printer off. Unplug USB cord.
Under Windows Start --> Printers and Devices:
RIGHT click the Konica printer icon. Select "uninstall" (or "remove device") and follow through until printer is successfully UNinstalled. If there is other Konica software installed, remove it also (via Start --> Control Panel --> Add/Remove Programs -or- Programs & Features).
4. Reboot your computer. Follow manufacturer printer installation procedure, step-by-step (consult mfr website if you do not have a printed installation manual). Do not plug in USB cord or turn on printer until instructed to do so.
If all else fails:
Ignore any manufacturer installation instructions.
Do # 3 only above.
Reboot computer.
Plug in printer and connect it to computer.
Let Windows try to automatically install it (in most cases, Windows can install the "basic" print drivers, which are smaller and sometimes more stable than the fancy drivers and excess software the manufacturer wants you to install).
If still no go, you probably have a dying or dead printer. Consult manufacturer website for help.
Mar 07, 2014 | Konica Minolta Office Equipment & Supplies
Printer not being recognized by computer
Sir/Madam
1. Is the printer turned on?
Make sure the printer is turned on.
Make sure the power cord is securely plugged into the electrical outlet.
Test the power by plugging in the power cord of another electrical appliance to an electrical outlet and turn it on. If the power to the other electrical appliance comes on, the printer may be considered to be faulty.
If this product is recognized:
Close this page to return to the installation window.
If this product is not recognized:
Proceed to the next step.
2. Are your computer and the printer correctly connected?
Make sure the USB cable is securely connected to the printer and to your computer and check that the USB cable is not damaged nor badly crimped.
The printer will not be recognized during the driver installation if connected to a printer switch or the printer buffer. If this is the case, try to directly connect the printer to your computer using the USB cable.
If you are connecting the printer to your computer via a USB hub, connect the printer to the first-tier hub from your computer. If the printer driver is still not recognized on your computer, try to directly connect the printer to your computer without the USB hub.
If you are connecting the printer to your computer via a USB hub, make sure the USB hub device is recognized by your computer.
3. Does your computer provide USB or IEEE 1394 support?
If Still Your Problem Is not solved Then Click On Below URL
http://files.support.epson.com/htmldocs/r1800_/r1800_rf/dset_1.htm
Or
Still You have problem Then please Follow Us On HP Printer Support
Jan 08, 2014 | HP P4515n LaserJet Printer
How to connect our printer to our computer
disconnect printer from computer -- prepare two cables and drivers -
(USB cable and power cord, along with CD software drivers )
install s/w (software) by inserting CD in drive bay -- allow for auto run to occur
install drivers , follow instructions.
when prompted connect power cord to printer and to Ac wall outlet, then connect USB cable to computer
continue following onscreen instructions. printer will be installed automatically and will be recognized by computer
send me 4 thumbs up please.
Jan 11, 2011 | Epson Office Equipment & Supplies
I bought the HP Deskjet 5650, but I'm not sure how to install it to my home computer.
First find the installation disk that came with your printer in the box. Install the software by placing the disk in your CDROM of your computer and then follow the instructions on the screen. when the software has finished installing, connect your printer to the computer with your USB cord and the computer will automatically do the rest.
Some operating systems already have the driver for your printer and the software is not necessary. To check and see if your computers operating system already has the necessary drivers, just connect your printer via your usb cord. Your computer will recognize the printer once the cord is connected and you will see a pop up message around the right hand corner of the monitor screen that says "new equipment detected" and the computer will do the rest.
Nov 11, 2010 | HP DeskJet 5650 InkJet Printer
How can i install this 3050 scnner
Connect all the cords properly between your computer and the printer. Connect also the usb cords, plug it into the usb port of your computer and also in the printer.Turn on your computer and then use the support cd to install the drivers and softwares for your printer.
Oct 28, 2009 | HP LaserJet 3050 All-In-One Printer
Printer is not working
Please try to unplug all cables connected in your printer to your computer and wait for 20 minutes then plug the cable back and turn on your computer. Make sure that you have installed your printer driver before correctly and make sure that your driver is supported with your operating system.
Thanks
Aug 18, 2009 | Dell A960 All-In-One InkJet Printer
Scanner - MFC 7420
Get the manual, and you may need the install disk too. Look carefully at the usb port on the copier so you get the correct usb cord.
Mar 31, 2009 | Brother MFC 7420 All-In-One Laser Printer
Printer does not Communicate (connect) following Microsoft SP3
I figured out the solution. Download the printer driver here http://downloads.lexmark.com/static/229-1-0-486.html#
Jan 28, 2009 | Lexmark Z600 InkJet Printer
Can't transfer music from my computer to my mp3 cell phone
restart your computer
and try again if not work go online install the driver
Jul 05, 2017 | LG Cell Phones
I have the HP LaserJet Printer. We moved and we lost the cord that connects it to the computer. One side was USB, can figure out what the other side is an what the cord is called...
Hi esmee
The canle you are looking for is a normal USB Printer cable. You could get it from any computer shop. The same cable is used for USB printers. Please feel free to search in the Repair Service Directory on this site for a supplier close to you.
Regards
Go-Tech
Dec 16, 2008 | HP LaserJet 1020 Printer
Brother MFC-640CW All-In-One InkJet Printer Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
