Question about Garmin nuvi 200W GPS Receiver
Garmin260w only says system software is missing.
How do i reload the software,i have tried the reset button .no results.HELP
  • wciaburri Mar 05, 2009
    i have this only 3 months and the GPS cannot retrieve the loaded maps. i need help
  • 728 Answers
You can use this site to download the latest software:
http://www8.garmin.com/support/collection.jsp?product=010-00621-31
Posted on Feb 16, 2009
Hi I haven't used my phone for a couple of years. when I switch it on now it say.. error 102 reload software... what do I do?
You need to do a Factory Reset, AKA a Hard Reset. This removes everything on the phone and reloads the operating system. Your phone is a Blackberry?
  • Error 102 Reload Software - BlackBerry Support Community ... https://supportforums.blackberry.com/t5/BlackBerry-Device-software/... Hello, I've just had a problem with my Blackberry 9930 phone. I already tried updating the Blackberry Desktop Software and I also tried the phone,
  • Error 102 - Reload Software - Blackberry Torch 981 ... https://supportforums.blackberry.com/t5/BlackBerry-OS-Smartphones/... Hi. I took the battery out of my phone and when the phone re-booted I now can only see a white screen with the error 102 and states reload software.
  • How to Reload Blackberry Mobile Software - Snapguide snapguide.com > Technology > Explore
    • 3.5/5
    • 10 RATINGS
    • BY TAHANI ALGHAREEB
    i will teach you how to reload your blackberry soft ware when its got error 102 and not working by this steps. all you ... How to Reload Blackberry Mobile Software
  • JVM Error 102 on your BlackBerry? Try this solution BEFORE ... crackberry.com > ... > Classic > Z30 > Z10 > Q10 > Leap > OS 10.3.2 Video embedded · JVM Error 102 on your BlackBerry? Try this solution ... JVM Error 102 on your BlackBerry? Try this solution BEFORE wiping! ... "Error 102. Reload Software ...
  • Terpecahkan: Curve 9360 Error 102 (Reload software ... forumdukungan.blackberry.com/...Error-102-Reload-software/td-p/258111 Terpecahkan: Dear all, Saya newbie disini, BB saya curve 9360, sudah mati 5 hari dengan error 102 (reload software). Sudah coba ikut instruksi dari
  • How to fix an error 102 reload software blackberry torch ... www.askmefast.com > ... > Error How to fix an error 102 reload software blackberry torch 9810? ... How can I fix reload error 102 on blackberry torch 9810? Comment. Reply. Report.
  • ERROR 102 www.blackberryos.com/general-blackberry-issues/38452-error-102-a.html
    • 2 POSTS
    • FIRST POST: 2013-08-12
    2013-08-12 · how do i reload software on a bb 9360?? ... Join Date Dec 2010 Location Gainesville, FL PIN Jarmeling Device Passport OS 10.3.2.2134
  • May 20, 2016 | Cell Phones
    ROLAND 2480 RECIEVE ERROR MESSAGE SUB SYSTEM NOT RESPONSE
    This means the low-level part of the operating system is corrupted or missing. Simply try reloading the OS by putting the CD into the CD drive. If it does not allow an OS reload or if it fails, most likely the flash ROM which holds the basic part of the OS has been zapped and will require service. You can also try to replace the internal button battery inside that retains the memory.
    Aug 24, 2012 | Roland Vs-2480 Digital Recorder Loaded...
    "missing operating system"
    Keep trying in the hopes that it will trigger, and come back- try the F buttons to get to options to try like System Restore, and see if that works (it probably won't, however).
    You will have to reload the Restore CD and try to get it working again. Another possibility is that you have a bad hard drive, and will have to buy one and reload the system.
    If you can't reload your system, take it into a computer repair shop and have them evaluate the problem. It could possibly be a bad motherboard, but it can be a memory or hard drive problem, and that should be checked before having the motherboard replaced.
    Good luck, and hope this helps.
    Jan 21, 2011 | Toshiba Computers & Internet
    File: /windows/system 32/gqcpmf.sys status: 0xcoooo225 windpws failed to load because a critical system driver is missing, or corrupted do u hv a solution to this problem
    You need to reload your operating system or a part of it. Most of the time this is caused by the OS disc that the system was loaded from could have been dirty or scratched up. Try an reload and don't rush the process this will also give you mixed results.
    Jan 23, 2010 | Acer Computers>Laptops Aspire 5610-2328 PC...
    Reload
    It seems that some registry files are missing which supports street maps 2006 (or) the registry files are not deleted while in the process of system recovery.
    Download and Install Windows Clean up utility:
    http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
    Using this application, uninstall Street maps 2006, and then try installing....
    Dec 17, 2009 | Microsoft Streets and Trips 2008 for PC
    System Software Missing
    well if the system is missing it cannot be detected, contact Garmin support for the fix. This happens time after time in their updaqtes
    Jul 19, 2009 | Garmin Nuvi 760 Car GPS Receiver
    Messed with Boot sequence.Now T41 won't boot!
    With the cd reboot and press F12 for a temporary boot list, select boot from cd. At this point just choose install xp and follow the prompts.
    Nov 09, 2008 | IBM ThinkPad T41 Notebook
    No menu & calendar written on lower screen
    Sound like the phones software might be corrupted, you can reinstall the whole system, read on...
    You can hard reset the phone (Factory Settings)
    This will reinstall the operating system inside the phone back to how it first was.
    (internal memory gets formatted then the rom reloads the os back)
    (Solves all kinds of problems.)
    Switch the phone "OFF"
    Hold "3" (button) + "Green Call" (button) + "*" (star button)
    Switch the phone "ON" while holding the above three buttons.
    Continue holding for about 20 seconds then let go.
    Please note this will format all the saved information stored in phone memory. including phonebook numbers (if not stored on SIM card).
    Try to make backups first.
    You have been "Warned".
    Best of Luck.
    Mar 25, 2008 | Nokia 7610 Handheld
    Reloading Thinkpad T40 Access IBM configuration software
    I need to know the Model Number of your T41 thinkpad laptop.
    or
    You go to Lenovo site go to Support and download section or click to the link....
    http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=10&familyind=154110&operatingsystemind=49979&template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&validate=true
    and browse for you laptop and check the software and drivers and there you will be able to find the ThinkVantage System Update ... check that out...
    Cheers - Parveen
    Feb 07, 2008 | IBM ThinkPad T40 2373 Notebook
    Garmin nuvi 200W GPS Receiver Logo
    170 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
