Question about Panasonic PV-DF2700 27 in. TV/VCR/DVD Combo
My tv has only a line of couler in the middle of the screen going across it what is the problem and how do i easily solve it?
  • 4,234 Answers
This is a failure of the vertical circuit. Usually this is either poor connections at the vertical IC or a defective IC. If you can solder, try resoldering the pins of the IC. If that fails to resolve the problem, replace the IC.
Keep me posted.
Dan
Posted on Feb 16, 2009
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
TV HAS A COLOR LINE WHEN IS ON IN THE MIDDLE OF SCREEN
if it runs across the screen its a buffer board usually. Can you paste a picture of the line?
Mar 10, 2013 | Sanyo DP50747 50 in. Plasma TV
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
My tv has a line across the middle of the screen. The sound is fine.
take it to a repair center for further help.what has happened is that the vertical out put has failed. so the set needs qualified electronic technician to solve the problem.
May 18, 2010 | Televison & Video
Black horizontal line across the middle of the plasma TV screen
It could be a defective Y-Buffer board, or a defective Plasma panel.
Oct 25, 2017 | Pioneer PDP-425CMX 42 in. Plasma...
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Tv screen goes blank with a line across middle
Hi Andy.
This is a straight forward repair & wont be expensive.
The problem is either dry joints on frame chip or component going thermal and failing at a certain temperature.
Cost for repair will be between £35.00 to £55.00 ask for a quote first.
http://dysonmanuals.inc.io/
Chris.
Dec 02, 2007 | RCA F32648 32" TV
Problem with tv
Its known as 'screen collapse' and yes it can be fixed but it may not be economical you should get some quotes from your local tv repairers.
Nov 14, 2007 | Televison & Video
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Panasonic PV-DF2700 27 in. TV/VCR/DVD Combo Logo
99 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
