Question about HP Pavilion (PN153AAR) PC Desktop
HP Pavilion 700 boots but stops @ press f1 for setup then stops
Press f1 then nothing happens
  • Dick
    Dick May 11, 2010
    The question line cuts off at 46 characters. Post your question in the body of your message as a comment.
  • HP Master
  • 3,051 Answers
Hi there hey have you tried to unplug the pc cord from the power supply and opening up the case and making sure that all of the power cords are connected correctly and you can also try to unplug the power supply connector to the motherboard and press the power button than remove the battery that is on the motherboard for 2 min this will reset the cmos, than put the battery back and plug in the power supply connector back in the motherboard and reboot you will have to re input the time and date but other than that you should be able to resume setup from here. please let me know how this works out for you , i can go further into detail if needed best regards mike
Posted on Feb 16, 2009
How to change boot order dx4200-ub001a?
To change the boot order, you will want to go into your BIOS. From the HP.com website it shows the following below to enter the BIOS:
BIOS Setup Utility Information and Menu Options
  1. Turn off the computer and wait five seconds.
  2. Turn on the computer and immediately press the F10 key repeatedly until a BIOS Setup screen opens. If nothing happens, press the F1 key repeatedly.
Use the arrow keys to move through the options (Note the commands key list in the lower right of the link I provided to HP.com) You will likely need to enter the advanced area to change your boot order.
Aug 29, 2014 | HP Pavilion Computers & Internet
HP Pavilion a1410n Disk Boot failure
After pressing F1 confirm that the master drive is listed in the boot setup program.. If the drive is not listed confirm that the electrical connection from the new power supply is correctly connected to the drive. Failing to correctly connect the hard drive during power supply replacements is most likely the problem. Also confirm the SATA connections to the drive.
Confirm that the drive gets warm and a slight vibration when power is first turned on confirming the disc drive is spinning.
Hope this helps?
backupsourceee-t0vwfcdnxxkr5mkphhbyx0tu-1-0.jpg These are typical screen shots that show the boot drive connected to the mother board MOBO detected during the initial boot process. Look for similar format in your machines boot setup.
Jun 27, 2017 | HP Pavilion a1410n (ER890AA) PC Desktop
Select booting drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to advanced bios features press enter to change boot devices
press f10 to save to cmos escape then restart your computer
if you need to change any of the settings using the arrow keys if you have made any changes that has compromised your computer
you can go back and load failsafe or optimised defaults
hope this helps
May 28, 2012 | HP Pavilion a320n PC Desktop
I have a hp p6203w how do I enter bios
"HP
Pavilion:
Method 1
Enter the BIOS: Press F1 during the blue HP screen for setup.
In the BIOS: Advanced to Peripheral Configuration to Parallel Port Mode. Use ENTER key to open menu and select EPP. Press F10 to save changes and exit.
Method 2
Enter the BIOS: Press F1 during the HP boot-up screen for setup.
In the BIOS: Advanced to I/O Device Configuration to Parallel Port Mode. Use ENTER key to select EPP. Press F10 to save the changes and exit."
source: http://www.easeus.com/disk-copy/faq1.htm
Apr 08, 2011 | Computers & Internet
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
HP Pavilion ze2308wm won't boot up
Have you tried an external keyboard, either PS2 or USB depending on what ports are available?
Mar 14, 2010 | HP Pavilion ze2000 Notebook
My Pavillion a1010n is stopping at the bios screen on start up. I re-seated the memory. I pressed "F1" on power up and it says "Entering Setup" but, does not advance from there.
try removing your hard disk and boot the system if the process is fast and you can enter the bios setup then probably your hdd needs a service
Dec 01, 2009 | HP Pavilion a1010n (PS563AA) PC Desktop
My old hdd does not work on my hp pavilion gx823,it comes up press f11 to continue and nothing else happens
If you're not using the operating system from your old drive, go into your bios (usually by pressing Del, F1, F2, F10 or F12 when the computer starts) and set your first boot device to the original hard drive for your pavillion. This may be found in 'boot device priority' or a similar label in your bios.
May 06, 2009 | Acer Computers & Internet
Takes 15 mins to boot after loading Micro trend
you have too much at startup. thats the programs the computer starts at boot up.i would go to last good configuration and see what happens if that works i would seriously get rid of some programs you don't need and defrag your computer.
Dec 15, 2008 | HP Pavilion a1600n (882780776265) PC...
HP Pavilion (PN153AAR) PC Desktop Logo
286 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
