FixYa.com
Tags:
Umax Astra 1220P Flatbed Scanner
New Pure3D drivers and my flatbed scanner
By Chandler - usenet poster
If anyone is bothering to read this-
I installed the latest pure3d drivers v1.60, but it caused my Umax Astra
1220S flatbed scanner to not work (it uses its own scsi card). Any call
to the printer (tests or from programs) causes the blue screen of
death. Went back to v1.50 and everything works again. Any suggestions?
TIA- I've got no ideas or leads.
nuprin
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
Thanks for Trying (70)
Brad
Brad - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
When you say it's not working, what happens? I have an Astra 610P and have
always gotten fatal exception errors in vxd vwin32. VistaScan (which SUCKS
HARD) conflicts with video drivers at the drop of a hat. I've had a Stealth
II and a Genoa V-raptor and both caused this problem. I've had to reboot
into safe mode or drag the performance bar down on the graphics card to scan
anything.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
I've had trouble with the new drivers as well. Canopus asked me for the
specific symptoms and apparently is checking it out. Any word on what's
happening now? Canospus folks? They're probably busy fixing the drivers as
we speak...
Solution #3
Not Rated (0)
Ross
Ross - usenet poster
Rating: 0%, 0 votes
After much pain , I found out that the v1.60 drivers won't work withmy mouse
drivers . I also went back to v1.50 and won't use v1.60 until
Canopus fixes the drivers .
Solution #4
Not Rated (0)
pawa
pawa - usenet poster
Rating: 0%, 0 votes
Same problem here. I have the Umax Astra 1220P. I even had to go back to
v1.50.
Solution #5
Not Rated (0)
Hart
Hart - usenet poster
Rating: 0%, 0 votes
The same thing happened with my Umax Astra 600s. I didn't even get to
the Print stage when using its "Copy Utility". I would get Fatal
Exception Error 17. But even worse, fatal exception error began to
turn up seemingly randomly when I used other programs as well. That
Never happened before. I told Canopus tech support about it, and they
told me.
"Just one thing though, did you install special drivers for
your hard disk controller? If you did, try installing the
standard driver and see if you can run the 1.60 driver.
We have seen this problem and before and the above
suggestion usually fixes it."
They also told me that "special drivers" would show up under Device
Manager, Hard Disk Controller and have "Bus Mastering" in their name.
I checked, and don't have any. I too went back to 1.50 and all is
fine. I think I'll stick with 1.50 for now.
Bob
>nuprin
Can you Help with these Scanners problems?
Scanners
Rollers on a Canon 5020/5080
I can't seem to get to all of... Answer This...
Scanners
Canoscan Setup Utility CD-ROM...
Hi, I want to connect my... Answer This...
Scanners
Canoscan N64OP flatbed
I have lost that install Cd for... Answer This...
colour of the scanned copy
when i use the scanner the... Answer This...
Need Driver for XP of Umax...
Hi, I will appreciate if you... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
