Question about HP Pavilion dv6000z Notebook
Hp laptop goes to the start up menu and shuts down
When the laptop starts up, it goes to the menu which it starts downloading(stage 3 of 3) 100% complete, it states that it shutting down. After it shuts down it restarts again
Its dead
Posted on Feb 16, 2009
Dv9740 hp laptoop does not shut down or sleep
Open power settings adjust. OR shut down at the start up menu. You can always push the on/off button. When not it use shut your computer down, unplug.
Dec 15, 2012 | HP Pavilion DV9740US Laptop
My HP conpaq 6720s shuts down when the battery pack is taken out even when it has 100%
1.Problem with battery of laptop (like in cell phone, phone show 100% battery but while we make call it show 0%).You can check voltage of battery
Nov 24, 2012 | HP Compaq 6720s Notebook
Power come up fully and shuts off immedeatly.
Hi boyletammy,
What stage of start-up does the notebook shut down immediately?
Is it when the notebook first starts, or during the loading of the operating system?
If it's "yes" to my first question, your battery may be flat and needs a charge (easy solution) OR there's a short-circuit somewhere and you'll need to return it to someone to have a look more closely. The DV6000z series is fairly recent laptop, so should be covered under warranty.
Hope this helps
-BuzzPuppy
May 01, 2011 | HP Pavilion dv6000z Notebook
I have hp pavilion tx 1000 since 3 days it takes 7 minuted to start and takes forever to shut it down so i have to forcefully shut it down please please help me
look up what you have in the startup files, alot of stuf you download puts thier product in the startup and it will take longer for your pc to turn them on and off:
Goto start menu and type in:
MSCONFIG
goto start up and turn off anything that you do not need to run at start up....becareful that you do not turn off key components to your system...just look for software you have downloaded...this will help speed up your start up and shutdown....
Sep 02, 2010 | HP Pavilion TX1000Z Notebook PC
Hp 6735b won't start. It just turns off when I try to start it.
There are only few things which we can do if the Laptop doesnt start of shuts down at initial stage. We need to clearly understand the various stages which the system goes through while booting. And based on the stage at which the system shuts down we can analyse if there is an issue with HW or OS. If the system turns off as soon as you switches it on, This could be due to failure in post.. You may have to flash the bios and give a check to the hardware.
If it just starts the cmos and then turns off, think about any hardware which you might have attached to the laptop, remove them and then try, still if it turns off then it could be due to a major hardware detection error, which could also be due to a chipset malfunctioning on the motherboard.
If it runs till loding the OS and then turns off, we have to check the OS Boot files which could be corrupt or lost. I would advice you to take your laptop for a Hardware Check.
Good Luck.
Mar 13, 2010 | HEWLETT-PACKARD HEWLETT PACKARD PCDO...
When I turn on my computer the screen reads configuring updates: Stage 3 of 3 0% complete. Do not turn off your computer. Then it goes to shutting down. It starts up with acer, microsoft corporation the...
downloads are either being stopped by a firewall or your system cannot update what it needs to because your missing other updates. if you dont have all required updates some others will not install.try automatic updates.download all critical and recommended updates.
Oct 05, 2009 | Acer Aspire 9410 Notebook
My new lenova thinkpad t400 seems to be caught in a loop. I've taken the battery out and ctrl alt delete but still goes back to configuring updates: stage 3 of 3 screen and then says shutting down, but it...
Hello!
This is a tough one. I've seen this recently and had to just press and hold the power button to shut down. Not good!
I'm assuming you're using Windows of some sort since it shows "Stage 3 of 3" when it does updates during shut down.
What has happened is you downloaded some sort of "fix" from Microsoft and it's getting stuck while trying to install. I've had this happen and have never found a good solution for it.
1. Turn you computer off.
2. Turn your computer on
3. As soon as the power comes on, start pressing F8 repeatedly.
4. When you get a black and white menu, use your arrow keys to move up and down, select "Last Known Good Configuration" and press enter.
What the solution I've provided does is revert your computers software to a point in the past, hopefully just before you received the screwy update.
Make sure to rate the solutions you get!
Aug 08, 2009 | Lenovo ThinkPad T400 - Intel Centrino 2...
My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
Feb 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
HP dv6835tx Notebook with Visa Ultimate 64-bit will not shut down
From what you've described, it sounds like you are clicking the Standby button, instead of the actual shutdown option. On the Start button, you will see (from left to right); Left: Start Search Middle: Standby Middle: Lock Right: Arrow Clicking the arrow will show you the Shutdown menu option; http://blogs.chron.com/techblog/archives/shutdown.jpg
May 26, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
167 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
