Question about Power Acoustik GOTHIC OV4-600 Car Audio Amplifier
Protection light comes on
I got this boss ch1200m and the protection light stays on all the time and it dont send music to the sub. i disconnected it a couple times..left it that way for like half hour then connected it back up..but same thing happend..does anyone know what could be the problem, or if the amp is shot?
  • Perry Babin May 11, 2010
    The amp probably has shorted output transistors. Read through the following page if you're interested in repairing it yourself.
    Basic Amp Repair
    Let me know if you have any other questions.
    babin_perry@yahoo.com
  • 25 Answers
Its dead the chip inside is fried
Posted on Feb 16, 2009
Um the power light will flash then the protl. light will flash its all hooked up right but weird sounds coming out my subs.
Disconnect subs from output of amplifier and then turn on car and radio. Does amp stay on or go into protect? If it stays on then there is something wrong with the subs or how they are wired (series, parallel ) to the box and amp. If it still goes into protect then something internal with amp.
Feb 23, 2010 | Concept Car Audio & Video
ALL THE WIRES ARE RAN CORRECTLY,THE GROUND IS SECURE UNDER A BOLT UNDER THE SEAT,THE SUBS ARE HOOKED UP RIGHT,BUT THE PROTECTION LIGHT IS STILL ON
the protection is on because if any speaker has internal electric problems as open circuit or short circuit, need to be checked
Jan 03, 2010 | Boss C650 Car Audio Amplifier
I ran the amp in .5 ohms and it is only 1 ohm stable now the protect light comes on what could it b.
Blown protection circuit at best. Blown power supply and IC's at worst. Send it to a service center for an estimate, educated guess without having it on a bench in front of me $150-200 repair. To test for the possibility that it's not the amp, disconnect speakers and turn power on. If it stays clean, no"protection", check your subs for a shorted voice coil. Hope this helps.
Nov 11, 2009 | Digital Audio 840 WATTS 2, CHANNEL HIGH...
My jvc ax6300 amp is wired in and the protection light is on. no sound from the subs?
Try to rest amp (turn off power) be sure subs are disconnected. Se if protection light comes on. If it does the amp needs to be serviced porbably a burnt component. If the protection light does not come on, connect one sub at a time to see if either one surges. Could also be that the gain is turned up too much.
Nov 06, 2009 | JVC KS-AX6300 Car Audio Amplifier
BOSS DD3 STAYS ON AND WILL NOT TURN OFF
It's supposed to do that. An extra lug on the input jack is connected to the battery and/or power supply's ground.
So the only way to power off any pedal is to disconnect the input jack. If you use a power supply and power multiple pedals you can simply disconnect the power supply to cut power and avoid unplugging each one.
Oct 08, 2009 | Boss Music
Pyle dryver amp light protection stays on not green light stays red i have tried to disconnect everything and plug it back up but light stays red
check your subs disconnect them the try to power the amp up if it powers up the the subs have died and it could be a problem with that amp i suggest you get a better amp
Jul 09, 2009 | Pyle Dryver PLAD213 Car Audio Amplifier
Protection light comes on went the amp is turn on and it stays on for four seconds and then the amp turn on
Disconnect any speaker from the amp then re-power. If it still goes into protection, your amp needs serviced. Shorted output transistors most likely. And check your Sub for shorts as well. If the voicecoil on the sub is burnt, it will short any amp. If you can use a meter, check the resistance on the sub. Hope this helps
Jun 02, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
Red light
something is shorted in the circuit, or your subs. unhook the subs first and try it again, if it is still in protect then it is most likely the output transistors.
Feb 22, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Power Acoustik GOTHIC OV4-600 Car Audio Amplifier Logo
109 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
