Question about Viking 31 in. DGCU105 Gas Cooktop
Viking Designer Series gas cooktop not cleaning well
I have the "pretty" gas cooktop with sealed burners and am not able to clean the aluminum sealed part at the base of the burner.  Does anyone know how to get this part clean without damaging the glass surface?
  • 59 Answers
I'm sorry to say that there is not a wonder solution for this. You try laying a damp cloth on the aluminum part to try and allow the moisture to soak in the clean it off.
Don't use anything abrasive as the aluminum will scratch.
Posted on Mar 05, 2009
The glass of the electric cook top is lifting from the stainless steel frame
[PDF]Professional Performance for the Home™ - Viking
Viking RangeFortunately, our built-in rangetops, cooktops, and gas woks offer the ... sealed or open burners, every Viking gas rangetop delivers unrivaled ..... The only thing cleaner than the glass ceramic surface of Viking electric cooktops is the installation.
Sep 30, 2015 | Viking Cooktops
Is there a specific regulator for a Viking D3 cooktop or can I purchase one off the shelf?
If it runs on natural gas it has a lower pressure regulator than one that runs on propane gas. Nat gas is 1.1kpa propane is 2.75kpa
May 03, 2014 | Viking D3 RDGSU2605B 36" Gas Cooktop with...
How to clean baked on crud off the metal part of the burner, the part that is not removable? I have Bar Keepers Friend, lemon juice, SOS scouring pads and a degreaser. Still, the spots remain. What...
It is aluminum and it is a pain to clean. Use a Magic Eraser sponge by Mr. clean and order so Star Clean (only available on the web from TJT products) and it will clean it right up. I tried everything too and couldn't get anything to work. I was seriously considering getting rid of the cooktop but this combo did the trick.
Oct 26, 2010 | Viking 37 in. VGSU161 Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
I cleaned my viking 6 burner gas cooktop and now there is no clicking and nothing ignites, but I smell the gas coming out - Anyone know what to do?
how u clean it,u think you never damage the gas line? call the person how to resolve the gas leak if we have.
Sep 12, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Viking stove right burners won't light
can u see the burner spark if not then ht lead at fault of electrode
Aug 21, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking 30" gas professional series cooktop sparking problem
And before that Most likely one of the ignition switches (they are under knobs) got shorted possibly due to spilled liquid or a cleaning stuff sprayed on. In that case it should stop sparking after a switch drys. Still no go replace the spark control unit.
Kindly rate the answer
Jul 06, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking Gas Burner issue?
is this a sealed burner unit? if so the burner base (the heavy brass part under the burner cap) has to be sitting just right. you will notice that it has holes around the the sides make sure that where your ignitor sparks to it that it aligns with the lowest hole on the burner base. if you have a great flame all around the burner after checking what i mentioned i would replace the spark module. if it continues to drive you crazy with the noise - just unplug it. the burners will continue working fine without power.
Dec 23, 2008 | Viking 42 in. Professional Series...
What do I use to keep my stove top clean
Throw the burners in a large garbage bag and spray it with easy off oven cleaner. Seal the bag for a day and then rinse everything off. Clean the aluminum parts with a nice wire brush from the hardware store.
Oct 16, 2008 | Jenn-Air JGC8536 Gas Cooktop
Viking 31 in. DGCU105 Gas Cooktop Logo
384 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
