Question about JVC MX-D402T Shelf System
Can't control volume on JVC MX-D402 system
Volume blares when you adjust volume with the volume knob on JVC MX-D402 system. The only way to control volume is with remote. Any suggestions?
  • christmas113 Feb 20, 2009
    I'll check that out. The knob seems tight on the shaft so I'm not sure. Thanks
  • haveric May 23, 2009
    My volume control is also erratic. It is not loose, either. Has anyone contacted JVC?
  • 77 Answers
The control knob in shelf stereos from frequent use wear out quickly. contact the manufacture and see if it would be an adventagious avenue to replace the volume control. if not to spendy.
Ryan
Please take time to rate this.
Posted on Feb 19, 2009
I have a ge gtd 120 home theatre surround sound.for some reason, my volume is stuck on one level.. I haven't had a remote for it for a while, just used the knob to adjust the volume.someone plz help!
Unless the system has some kind of automatic volume control on it, that can only be adjusted by the remote. I think you might have a faulty volume/tone control circuit. These days many amps have a single IC that will control the volume. If that goes the volume can get stuck on one level. Since the control knob you are turning is simply sending a signal to that IC. So if the IC has died the signal is not being received.
If you want to repair it yourself just follow the wires back to the board from the volume control. You should see a large multi pin black box that if your lucky is marked on the board volume control.
Jun 10, 2016 | GE Audio Players & Recorders
Have a jvc kw-830 and volume al the sudden blares on its own
You probably have a bad volume up control switch.
Nov 07, 2014 | JVC Car Audio & Video
Whats tha volume control ic
When the volume control is adjusted it sends a signal to a small black box called an IC. This adjust the levels and power going to the main amp of the unit. The IC can be found by tracing the wiring from the volume control back to a printed circuit board.
May 10, 2014 | JVC MX-D302T Shelf System
Set clock on a jvc kd-r330
It's very simple even if you don't have the owners manual.
Step 1: Hold in the Menu button until "DEMO" shows on the display screen.
Step 2: Scroll with the volume knob until it says clock. Then press the volume knob to select it.
Step 3: Scroll with the volume knob until it says "CLOCK SET." Then press the volume knob again.
Step 4: Then adjust the hour first by scrolling with the volume knob. Once the correct hours shows press the volume knob and it will move on to the minutes.
Step 5: Once the hour and minute is chosen push the menu button again to finish the procedure.
Nov 13, 2013 | JVC Kdr330
Jvc hx-d7 sound If I turn the volume knob down to fast the volume turns up. Any ideas?
The contacts in the volume control encoder are dirty. If you know what you're doing, it can be taking apart and cleaned, otherwise replace the volume control.
Jul 08, 2013 | Audio Players & Recorders
Jvc cd player model kd-g120,how do i set the time?
Press and hold 'SEL' press down arrow until CLOCK H is displayed rotate Volume knob to adjust press down arrow once to display CLOCK M rotate Volume knob to adjust press 'SEL' to finish. Reference pages 6 and 10 in this link to your JVC KD-G120 Instructions Manual.
http://resources.jvc.com/Resources/00/00/91/GET0330-001A.pdf
Nov 18, 2009 | JVC AM FM CD DET FACE CAR STEREO
The Volume knob malfunctions
Hi there. Sorry I haven't got a solution. Just want to know if you found one, as I got the very same prob with the volume knob of my JVC hi fi. Thanks for your time.
Oct 05, 2009 | JVC MX-J30 CD Shelf System
No volume control
lower the volume of the cd player
May 08, 2009 | NAD C320 2-Channel Amplifier
JVC MXJ30 Compact Hi-Fi
Spares from JVC? Where's the cheapest remote? Where's the cheapest Service manual?
Mar 09, 2009 | JVC MX-J30 CD Shelf System
Little or no sound JVC RX6010V
i had the same problem but i went to adjust settings and it says right speaker left speaker and you have to set them on ten
Jan 02, 2008 | JVC RX-6010V Receiver
JVC MX-D402T Shelf System Logo
725 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
