Question about Frigidaire Kitchen Ranges
Range Manuel for Older model
I have a model FEF455WCB-B electric range and I would like to know if it has a timed start feature. I do not have the manuel and would like to be able to put food in the oven and leave then have the oven turn on at the selected time.
Thanks!
How to start the self cleaning on FEF455WCB
Posted on Dec 20, 2014
    President:
  • Frigidaire Master
  • 2,651 Answers
How do i use the self cleaning feature
Hello Veronica Candeleria - I located the manual on the Frigidaire website. Here is the manufacturer link and hope you find all the information that you need. If for any reason you have difficulties pulling up the requested information, I recommend taking off the last letter of the model number so you can pull up the data
Feb 14, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Electric Range Model #911 9237313-All burners quit at once?
Have you checked your fuse box. The Electric Range is on a separate circuit. Check to see if it is tripped or off.
If it has tripped and you reset it, that usually means there is a problem with the electric range.
Let me know if that helps.
Jan 22, 2012 | Kenmore Kitchen Ranges
I have an older model amana electric stove; I cannot get the self-cleaning feature to work and I don't have a manual. Can you give me the steps?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 20, 2011 | Amana AER5515QA Electric Kitchen Range
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
How to use self clean feature
Here is a link the manual for your range, it will describe in detail how to use the self clean, if you have trouble let me know and I will walk you through it.
Maunal
May 21, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
T tried to change time on reange and now reads 5Ab
You may have inadvertently set your range to "Sabbath Mode". The display actually reads "SAB". This is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
To turn the Sabbath Mode on/off on most Maytag models you simply press and hold the "Clock" button for 5 seconds. On other Maytag models you press and hold the "STOP/TIME" and "CANCEL" buttons down at the same time for 3 seconds. These instructions should be in your owner's manual.
If this does not correct the problem for you, please let me know. I hope this helps you.
Nov 05, 2009 | Maytag MER4351A Electric Kitchen Range
When cooking, at times it will start beeping and display f-10
The broil (high) comes on when bake is pushed on my Frigidaire ES340 electric range. Range is less than 5 years old, so now can't bake.
May 18, 2009 | Frigidaire FEF366 Electric Kitchen Range
He2415u convection range
1. Access SELECT FUNCTION menu
2. Turn knob clockwise until desired language is displayed
3. Touch start to accept a language change
To access SELECT FUNCTIONS menu, touch and hold COOKING MODE touch pad for 5 seconds
SELECT FUNCTION is displayed:
1.Turn knob to desired feature
2.Press START to choose any function, and turn knob to choose any sub-functions
3. After selecting feature, touch OFF
Jan 02, 2008 | Siemens HE2415U Electric Kitchen Range
Jenn Air Older Oven wall unit only
Shannbooks The first thing I would recommend to do is to reset the power. Turn off the breaker for the range for couple minutes and then turn it on. In the most cases it works. Set the time of the day and try to use the oven. If it would not solve the problem let me know. Good luck. Gendos. post back...
Jul 08, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Kitchen Ranges Logo
180 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
