Question about Toshiba 36A61 36" TV
Cannot clear the closed caption off screen
Turned the tv on & the closed caption appeared..cannot remove the writing off the screen!
  • dihutch_99 Feb 16, 2009
    i went to the menu 1st & selected "off" then turned the tv OFF for a while & the closed caption is STILL on..drives me crazy,any other options? thanks for trying!
  • 31 Answers
Go to your menu and turn it off. Or, turn your tv off and unplug it give it 5 minutes to let it reset so it doesnt keep it stored, and turn it back on.
Depends on TV i guess.
good luck.
Posted on Feb 16, 2009
I have a DYNEX 42"
Do you have a cable or satellite box connected to the TV? If so the box is probably what is providing the Closed Caption and not the TV.
Robert
Feb 26, 2011 | Dynex DX-LCD37 TV
Cant turn off closed caption
sherrillbrom
With our VIP receiver models, you have an option to turn on/off closed caption through the receiver. Press the Menu button on the remote, which will display the Main Menu on the TV screen. Press 8 (Preferences) and then press 6 (Closed Caption). On the Closed Caption screen, press 1. On the Closed Caption On/Off screen, select CC Off and then press Done from the TV screen (using your DISH remote). This will turn the feature off on the receiver. Test to see if it is turned off by watching a program that has CC. If it still appears, then the feature is activated through your TV. Please refer to your TV manual to turn the feature off. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
How to remove closed captioning on tv screen
Press the Caption button on the remote control to cycle through the caption options until OFF appears. If there is no Caption button on the remote, go to the system menu and turn captions off in the caption submenu.
Jan 08, 2010 | Philips Magnavox 20MT133S 20" TV
A black box keeps appearing in the middle of the screen and stays on until I either turn off the TV or turn on the settings screen and clear it
Somehow, the cable box or some other device changed the settings for the caption box on the TV. While no closed captions were appearing on the screen, the box was being displayed. The box stopped popping up when the captions setting was turned off.
Dec 27, 2009 | Toshiba 27AX61 TV
Cannot see the screen Philips DVP5990 DVD player. Setting problem
You may have probably turned on Closed Caption on your TV. Unhook the DVD player to find out if it disappears. If it disappears then Closed Caption is on on your TV. Turn off Closed Caption. If cannot find how, give me the brand and model of your TV.
Oct 30, 2009 | Philips DVP5990 DVD Player
How do i turn off the subtitles on my toshiba 36hf72 tv, without the remote
The subtitles in dubbed videos VCD/DVD the process to follow are :-
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and
sound effects of TV programs and videos that are closed
captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the
current program, such as weather or stock data (when provided
by individual stations).
To view captions or text:
1. Tune the TV to the desired program.
2. Press MENU, and then press x or • until the CUSTOM menu
appears.
3. Press z or y to highlight CC.
4. Press x or • to highlight the desired closed caption mode, as
follows:
• To view captions, highlight C1, C2, C3, or C4 (C1 displays
translation of the primary language in your area).
Note: If the program or video you selected is not closed captioned,
no captions will display on the screen.
• To view text, highlight T1, T2, T3, or T4.
Note: If text is not available in your area, a black rectangle may appear on your screen. If this happens, turn the Closed Caption feature OFF.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
Note:
A closed caption signal may not display in the
following situations:
• when a videotape has been dubbed
• when the signal reception is weak
• when the signal reception is nonstandard
PS: If you do not want to set these function & their commands can be entered via the buttons on the TV set. Using the remote is much easier to operate............ sodeep
Oct 08, 2009 | Toshiba 36HF72 36" TV
Black box when tv is on and going through channels
This worked on my tv...give it a try:
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | JVC AV-36S33 36" TV
Toshiba 62hx94 cant shut off closed caption have comcast cable How do I turn off closed caption on my TV. It suddenly turned on. can' turn off closed captioning 20" ws
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Jan 30, 2009 | Televison & Video
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
Closed captioning
I had the same problem. My DVD player was connected to my HD TV via a HDMI cable as was recommended by the DVD owner's manual. I removed the HDMI cable and attached the three video component cables. Bingo, closed caption crossed immediately.
Aug 09, 2007 | Funai MWC24T5 24 in. OLED Television
Toshiba 36A61 36" TV Logo
139 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
