Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana SX22se Not kkeping things frozen ice maker not making ice
Ice in the tray is shrinking not staying cold enough
  • 150 Answers
If both of your fans are working,you will will need to defrost it.
Posted on Feb 19, 2009
What can I do to fix my ice maker? My ice maker 12685003 in my Amana refrigerator keeps dispensing water and has a huge peak of ice in the tray. It works fine for awhile making regular cubes then it looks...
Most likely your Ice maker inlet valve is not closing properly and seeping water continuously.
This will lead to frozen ice layer on tray or surrounding area in the freezer. Also this water leak from valve will freeze the water line and stop making ice.
Your inlet water valve need to be changed for your fridge. Amana is made by Whirlpool Corporation. Check with your mode number.
If in USA www.repairclinic.com
In Canada www.reliableparts.ca
Hey there are lot of other parts sellers too. Just two of them above
Oct 24, 2017 | Refrigerators
Continuous knocking noise from ice maker. Ice maker has been off for past 3 months. Only thing that will make it stop is turning it off or unplugging it.
Hi Marcel,
Thank you for contacting fixya.
Our ice maker recently had its water inlet freeze up, preventing water from filling the trays. The mechanism kept dutifully trying to push nonexistent ice cubes into a bin that never filled up, which might account for the knocking noise in your case.
To defrost it we just unplugged the unit, took all the food out of the freezer section, and left the door open for a couple of hours. It wasn't long enough for any of the frozen food to defrost, and since we were careful to minimize opening the refrigerator section's door, the food in that part stayed cold enough to be safe as well.
Feb 09, 2014 | Frigidaire FPHB2899LF
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
Ice stays frozen in tray.
Hi Rich Byhre - The heater on the ice maker is energized by an internal thermostat. If it is not cycling once the ice is frozen, then the refrigerator could possibly have a faulty ice maker or the mold is not getting cold enough. I strongly suggest contacting a professional to move forward and to assist with the repairs.
Jan 21, 2013 | Frigidaire FRS3R5EMB Side by Side...
Amana side by side ice maker tray is full and frozen but cubes aren't being ejected
Make sure the ice crusher/dispenser is working or gt a technician 2 look at it. Also ensure that u do not spil water when refiling the ice maker n do not go beyond the full markings 4 this may cause malfunctions when the water is frozen.
May 05, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Frig not getting cold enough
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 08, 2010 | Amana ABB1927DE Bottom Freezer...
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
Amana refigator
The ice maker supply line is frozen remove the tray that the ice dumps in and hold a hair dryer aimed at the tray that ice is formed in a tube comes out and fills the tray this line is the one
Aug 09, 2009 | Refrigerators
Ice maker overfills with water, drips into ice bin, and auger cannot turn because of ice. Can't find any water regulator.
Don't have this model, but could there be a weight sensor for the ice tray that is stuck and possibly frozen in the up position? The weight sensor would normally sense when there is enough water in the ice tray and then cause the water to shut off. See whether the tray should have up and down vertical movement.
Jul 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker
The is a small heater in the boottom of your ice maker that is most likely not working. The heater comes on when the ice reaches a frozen state to allow the ice to melt just enough that the rotating arm can push the cubes out and into the tray.
Unfortunately, it will most likely cost more to have a technician fix the existing ice maker than it would to just have anew one installed.
I would opt for the new ice maker.
Jun 04, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
87 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
