Question about Canon MX700 Office All-In-One InkJet Printer
Printer error code 5100 I had a business card paper jam in my Canon MX700. I removed the back panel & was able to clear the obstruction, but I keep getting the Error code: 5100. I've tried turning the printer off & back on. What do I do? Help!
  • htm108 Mar 06, 2009
    I have same problem that the printer has error code 5100.
    it worked well till yestarday, but suddenly the printer can't work now.
    please help me out from this problem
  • 4,041 Answers
Hi You can Try
Same old Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
Our Canon jx210p fax keeps saying "chk printer
CHK PRINTER 5100 / SEE MANUAL
Cause Action Movement of the Holder is blocked. Clear the paper jam or foreign object that is preventing the Holder from moving, then turn off the machine and turn it back on again. There may be an obstruction that is not allowing the Holder mechanism to move. Check for any obstruction (paper clip, small object, etc.) and also that the protective tape are removed from the FINE Cartridge. Check also for a paper jam and clear the jam if necessary . Then press [Stop/Reset] and start again. The FINE Cartridge may be defective. Press [Stop/Reset]. Reinstall the FINE Cartridge (see Prepare the Machine ) and start again.In either case, if the error does not clear, try unplugging the fax. Wait several minutes, then plug it back in. Also, try replacing the FINE Cartridge with a new one. An error requiring servicing might have occurred. Turn off the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn on the machine. If the same error occurs, contact the service center.
Jul 26, 2011 | Canon FAX JX210P All-In-One Inkjet Printer
Error code 5100 has appeared
Here is what I could find on the issue. -Error code 5100 describes a physical problem either with a paper jam or an incorrectly seated ink tank.
This was found on e-how. If you would like to read more please see the link below. hope this helps.
http://www.ehow.com/how_6497472_fix-code-5100-canon-mx700.html
Apr 11, 2011 | Canon MX700 Office All-In-One InkJet...
I have a Canon MX700 printer unit, with a Error code 6000 and turning on and off will not correct error
Check the paper path for obstructions. Try running a thicker paper through to clear obstructions. If this does not work, you may have a defective paper sensor that requires service at a service center.
Mar 05, 2010 | Canon MX700 Office All-In-One InkJet...
My canon mx700 keeps giving me error code 5100 HOW CAN IFIX IT I JUST GOT ABOUT S MONTHS AGO
This error indicates that there might be some obstruction in the rollers; could be tiny paper shreds so you need to check on that one. If there are no obstruction, then this error can be caused of the white sliding thingy that the printhead stays when the printer is not in use. This needs to be lubricated. Try to lubricate also the sliders with some grease so that the mehcanism can now slide freely. By doing this, you need to open the right panel of the printer. Unscrew the 2 screws to take it off.
Moreover, since this is just a months old printer, I'm sure it is still under warranty. It is still best to have it checked and avail the FREE service. Goodluck!
Oct 21, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon MX700 printer. I had a "business card paper" jam. Since the paper is perforated for business cards, it wasn't fun removing all the pieces. I finally removed the back panel & was able to...
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Feb 18, 2009 | Canon MX700 Office All-In-One InkJet...
Canon mx700 5100 error
The 5100 error usually indicates a problem with the printer knowing where the printhead carriage unit is.
Chances are that when you cleared the jam you dislodged, damaged or otherwise skewed the little calibration strip at the back of the printer.
This strip is a clear bit of plastic that has lots of thin black lines on it and it's used by the printer to sense where it is.
If it's not that then it's most likely something jamming the printhead carriage somehow... ink soaked bits of paper are a favourite that I used to miss a lot.
Hope that helps.
Jan 30, 2009 | Canon MX700 Office All-In-One InkJet...
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 Office All-In-One InkJet Printer Logo
284 people viewed this question
old marine
old marine
