Question about Proview PL913S 19" Flat Panel LCD Monitor
Proview monitor blacking out
Hi, i have a proview monitor && for some reason after i have been on it for about an hour the screen blacks out. the power button is still on (the monitor) so i turned it off than back on but after two seconds it blacked out again. i made sure everything was plugged in and my computer wasn't over heating, but i still blacks out every hour. what do i do ?
  • 33 Answers
I would suggest getting a new monitor you might have made it overheat or your display driver failed.
Posted on Feb 16, 2009
    New Friend:
I have this issue, only in Windows XP. My Windows 7 laptop, I can connect the 900p and it works fine! I can insert the Windows 7 install disk and the monitor works fine (had it on the install screen for about 40 minutes with no issues). I use it on the dell tower with XP Pro, screen goes dark after a couple of seconds. I use my XP setup disk, same thing.
Posted on Feb 23, 2015
  • 558 Answers
The capacitors in pro view monitors are notorious for being cheapo they distend and then eventually you get the issue you have described, later the monitor will not turn on at all, I am using a repaired one right now and have had it for about a year not I had to replace 4 of the six caps on the power board they supply the inverter with consistent smooth power if you can you can open the monitor up and take out the power board(it is upside down) and there you will see blown caps could be 2 could be 6 hard to say at this point.
hope this helps
please rate
Posted on Feb 17, 2009
ProView 19" Flat Screen Monitor comes on with
The dark or black picture is caused by a failure in the back light power supply. The problem can be corrected by replacing a few parts called capacitors on the board. Replacing them will require a little soldering but anyone can do it. Here is a link to a page that shows what needs to be replaced.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 17, 2011 | Proview PL926WBi 19" LCD Monitor
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
My proview 558 monitor has a 1/2 inch black line at the bottom
ms_biguns, You need to test one or the other, The tower should output and drive a substitute known good monitor, or a known good pc should be able to display the WIN-desktop screen on your Proview 558. Could it also be that the software in pc not set up for driving a Proview558? 12fixlouie
Feb 28, 2010 | Proview Computers & Internet
Proview Monitor PL926 Wbi The power indicator
Repair estimate will be according to problem.
Nov 13, 2009 | Proview PL926WBi 19" LCD Monitor
Screen goes black
The video adapter board is what controls the monitor. If you are going to replace a board that would be the one.
Dec 27, 2008 | Proview PL926WBi 19" LCD Monitor
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
Screen goes dark
it indictes problem with ur crt tube in monitir
Dec 02, 2007 | Proview PL926WBi 19" LCD Monitor
Proview PL913S 19" Flat Panel LCD Monitor Logo
291 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Frank Russell
Frank Russell
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
