Question about Maytag Neptune MDE5500AY Electric Dryer
The gas dryer will not heat?
The dry will not heat and everything else function so the problem is either in the ingniter or the thermal fuse is out. How do you open the dryer to get to these spots??
  • charlieo7 Feb 16, 2009
    Everything seems to work ,but no heat
    Scholar:
  • 87 Answers
On that dryer, take out the door screws and the other screws on the other side. Push down on it and the 2 goalpost sides on the top should come out. I would imagine it's the ignightor. Usually a thermal fuse will stop the thing from spinning also. At least once you get it apart you could see if it glows and turns the gas on. Good luck
Posted on Feb 16, 2009
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    Tip
    Whirlpool or Kenmore Dryer Does Not Heat
    Electric
    First , check the circuit breaker to make sure they are on . Be sure to UNPLUG the dryer , while checking with an ohm meter . When checking WITH power , BEST to have another person available in case of emergency . I do know of 1 person killed while working on his dryer .
    A dryer operating on 240 volts , sends 120 volts to the timer and 120 volts to the motor . In between these two , are the thermal cut-off , and the element ( this is the basic operation parts ) . The 120 volts from the motor , goes directly to the element if selected for heat . The timer circuit , sends the other 120 volts , thru the operating thermostats , then thermal fuse , then thermal cut-off , then high-limit thermostat , then to the element . Usually , not ALL the time , the thermal fuse ( number 1 ) is the problem . The heating element ( number 2 ) is usually the problem , if the thermal fuse is good .
    If the thermostats , element , and thermal fuse check good with an ohm meter , remove 1 wire from the element and check with a meter , which side is NOT getting 120 volts . Trace the wire which will either go to the timer ( occasionally ) or to the motor ( extremely rare ) .
    Gas
    On a gas dryer , for no heat , or , heats for a short time then runs but no heat afterwords until cooled down , first check that the electronic igniter , glows red . If it does NOT glow red , then check power to the burner ( 2 wires ) . If no power , then the thermal fuse is bad . (On electric dryers , the thermal fuse keeps the dryer from starting . On gas dryers , it keeps the dryer from heating . The thermal fuse , is a 1" long , or oval , white piece , with 2 wires going to it ) . Also if it does not glow red , the igniter itself could be bad . Again , check with an ohm meter . If the igniter glows red and clicks off , but no gas , the sensor could be bad . This sensor , is mounted to the side of the burner box , and when the igniter gets hot enough to ignite the gas , the sensor opens , sending power to the coils , which open dispensing the gas to heat the dryer . To check the sensor , with the drum removed , start the dryer , and after the igniter gets red , pull one of the wires OFF the sensor , and the gas should ignite . Do this very carefully , as electricity WILL be in the wire pulled off . If the dryer heats for a short time then stops heating , the problem will be the burner coils . These coils will get warm from the electricity going thru them , and will " open " ( short ) internally , until they cool down . Then heat again for a short time , then open , until cooled .
    Most of the time , either the thermal fuse ( 1 ) or the coils are bad ( 2 ) or the igniter is bad ( 3 ) .
    ........A thermal fuse is a white 1" long torpedo looking piece , or , a white oval shaped piece , with 2 wires going to it .
    NOTE1 : The thermal fuse keeps an electric dryer from starting and keeps a gas dryer from heating .
    NOTE2 : If your dryer heats but the clothes do not dry , then a venting problem is obvious , as a dryer either heats or doesn't heat . Pull the dryer out and disconnect the vent from the dryer . Dry a load of clothes and if/when they dry in the normal amount of time , this tells you either the vent hose is kinked , maybe pushed back too far , or , the outside vent is blocked , or , the vent in the wall is restricted to the outside .
    Electric Dryers
    NOTE3 : If your lint screen is on top of the dryer , the element , thermal fuse , and thermostats are behind the rear dryer panel ....If the lint screen is behind the dryer door , then the element , thermal fuse ( located behind the lint screen housing ( 2 screws ) , and thermostats , are located behind the lower front panel .
    on Apr 17, 2010 | Dryers
    Thermal fuse blew...replaced it...got one load dried and new fuse blew...checked for clogged vents; are none. What else could be causing the thermal fuse to blow and so quickly as the new one did?
    You need to change the t-stat, thermal fuse and high limit all at the same time...
    read the electric no heat tip...
    If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
    if you dryer is gas check out this gas no heat tip....
    If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
    check out this electric no heat tip...
    heatman101
    Sep 24, 2010 | Dryers
    Gas ingnition does not start
    unplug the dryer and check the ignitor,the sensor and the thermal fuse located on the blower wheel housing,also if the dryer works correctly for the first 15 to 30 minutes then will not ignite again you have bad gas coils,also if the ignitor glows but flame doesn't lite most likely it's the coils,while your in there vac out the dryer,the duct where the lint filter slides into and if the vent line is long blow it out with a leaf blower
    Jul 04, 2010 | Whirlpool LGB6300 Gas Dryer
    Dryer turns on but does not heat up
    the first thing to check is the ignitor .how ever there is a thermal fuse located on the exhaust duct inside the dryer that may be bad this woulld cause the unit to run and not get hot.this needs to be checked with an ohm meter for continuity there is more than one thermal fuse so check them all just to be sure.i hope this has helped.please let me now how things turned out.good luck
    Jan 22, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
    The dryer is not drying. The drying temperature
    Hello there:
    Proper Voltage
    dryer_heating-element.jpg Heating Element
    dryer_thermal-fuse.jpg Thermal Fuse
    dryer_thermostat.jpg Thermostat
    dryer_timer.jpg Timer motor
    A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
    Jan 19, 2010 | Kenmore 500 6952 Dryer
    It wont dry my clothes
    Check the following for a gas dryer--
    1. Gas valve coils
    Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
    Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
    2. Thermal fuse
    Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
    Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
    3. Igniter
    Igniter may burn out or break. Replace the igniter if found defective.
    Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
    4. Flame sensor (or radiant heat sensor)
    Replace the sensor (located near the igniter) if found defective.
    Check the following for a electric dryer--
    1. No power to the dryer
    Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
    2. Heating element
    A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
    3. Thermal fuse
    Jun 01, 2009 | Kenmore Dryers
    Dryer want heat up
    Hi
    Things that could stop a electric dryer from heating:
    - house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
    A ohm meter test for these parts is here.
    Things that could stop a gas dryer from heating:
    - glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
    A page for checking gas dryers is here.
    Please do rate the solution as "FixYa" and revert for further assistance.
    Thanks
    Rylee
    Apr 19, 2009 | Kenmore Dryers
    Maytag MDG5500 - heat goes off after several minutes
    Q - My gas dryer will not heat, what could stop my dryer from heating?
    A - Things that could stop a gas dryer from heating:
    - glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
    Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
    Kenmore 70 Series
    You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
    If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
    Jun 04, 2008 | Dryers
    Maytag Neptune MDE5500AY Electric Dryer Logo
    90 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
