Question about HP Media Center m7250n (ED842AA) PC Desktop
Can't find where to get the input from red/white/yellow cables
I'm trying to find where i can see the input from the red/white/yellow set of input cables to be able to play my PS3 with internet connection.
I'm trying to get my HP Media Center PC m7250n to show input from my PS3 because I can't find a way to hook it up directly to the monitor, and don't want a tv in my den, but still want internet connection and can't get that anywhere else in the house. so, I have the regular red/white/yellow audio/video input cable hooked to the front of my pc and it doesn't want to show me what's being inputted.
  • 3 more comments
  • tulae101 Feb 16, 2009
    i don't know. I don't think so
    hmm, not quite. on the back same as on front there's a composite video input, and I searched tv on the help and support center, but all of the listed topics tell me "to get more help on the media center press start on the remote then go to settings > help." and i don't have a remote..
  • tulae101 Feb 18, 2009
    well yes, but I'm havin trouble finding the software on my computer
  • tulae101 Feb 20, 2009
    THANK YOU
  • Richard Ray May 11, 2010
    Hi tulae101,
    do you have a tv card installed in your machine.....
  • 77 Answers
If u have a look on the back of the pc, u shud see a card with a lot of connectors on it, video, audio and an antenna, if this has then connect to the video in connector and set the tv tuner software to composite and then it show what is bein imputted...
hope this helps
Posted on Feb 16, 2009
  • Richard Ray Feb 17, 2009
    the problem seems to be with media centre, as there is no way of changeing the input, the tv tuner normally has software of its own.
    if you have a look for that. then you should be able to select the composite video input...
    hope this helps
  • Richard Ray Feb 18, 2009
    Have a look in device manager in sound/video and game controllers and u shud see what tv card is installed in ur machine........ then goto HP's site and look for the updated driver/software then u shud be set to go
    hope this helps
I have the 3 RCA red, yellow, white cables on back of dvd and to tv. Video only plays when I select video 1 under the input. When when I select video 3 only sound and no video. What else can I try?
Sounds like from the symptoms that you have plugged the white and red cables into AV3 input on the back of the Teleivsion and plugged the yellow cable into AV1 on the back of the Television.
Check the cables are all plugged into AV1 input ports on the back of the Television. Red and White go into the Audio inputs and Yellow goes in the video input. Also make sure you have not plugged cables into component inputs on television look for AV1 in on back of Television .
Mar 08, 2015 | RCA Televison & Video
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
My dynex tv only shows channel not available message?
Okay- the three cables (red, white, and yellow) are called RCA plug connectors. They are commonly used to carry audio and video signals.
Plug them into your Xbox according to the color codes- red cable connector to the red socket (jacks); then white to white, and yellow to yellow.
Now connect these leads to the RCA input jacks in the back of your t.v. - maintaining the same color code connections (red to red; white to white, and yellow to yellow)
The RCA input jacks on your t.v. should be labeled with an input number, to distinguish itself from the other inputs, like HDMI, S-Video, and such.
After plugging in your Xbox to the wall outlet or surge strip, turn it on.
Turn your t.v. set on.
With the remote control that came with your t.v. set, open the menu bar, scroll to... and open the "External Output" menu.
You should see a list of [however many] inputs your particular t.v has. Scroll to the input number that the 3 RCA cables are attached to, and press that number as the default video screen.
Exit the prompts and your Xbox video screen should be displayed.
Nov 27, 2013 | Dynex DX-LCD32-09 LCD TV
Which cable should be hook up to tv. Trying to hook up DVD player. I have cable with Red, white, yellow.
hi that"s easy thing. first connect rca wire red white yellow to dvd hook up same colour red white & yellow female rca connection. then use another rca wire connect to your tv be video input in yellow one . red & white be sound input - red to red . white to white. just that. good luck!!
Jun 03, 2011 | JVC C-13920 TV
I have a dvd player drc212 that i have no
Hi Tana,
If your TV is supplied with a video input, you will need a set of Composite Baseband video cables commonly known as RCA cables (Yellow, Red, White).
See the last paragraph if your TV is not supplied with a video input.
You will connect the Yellow (Video) from the DVD's video output, to the Yellow (Video) input on the TV set; example is VIDEO 1 or AV1.
You will connect the Red (Right Audio) from the DVD's Red Audio output, to the Red (Right Audio) input on the TV set using the same input number as example above.
You will connect the White (Left Audio) from the DVD's White Audio output, to the White (Left Audio) input on the TV set using the same input number as example above.
Turn on DVD, and TV set. Select the proper input on the TV set using the input button (video, source, AV select, etc.)
If your TV set is not supplied with a video input only a coax cable input, you will need an RF Modulator which can be purchased at any Best Buy, Radio Shack, Wal-mart, etc. You will also need a small coax jumper (3 to 6 foot should do it), and a set of RCA cables (Yellow, Red, White) as described above. The RF Modulator comes with instructions on how to connect it. It has a coax input, RCA input and a coax output that will connect to your TV set.
I hope this helps. Cheers.
Feb 09, 2010 | Televison & Video
How to hook up from TV to recorder
hi there
there are three cable yellow red and white your yellow
cable is the picture cabe and your red and white cabe is the sound cabe plug the yellow cabe in the yellow input and the white and red in the red and white input @ the back ok you recorder now the some go to the tv set it will work 100% now
Dec 19, 2009 | Samsung DVD-VR357
Hooking up a dvd
You want to hook up the cables to any of the VGA input sets. Red= right audio channel, White= left audio channel, Yellow= Video. Don't plug them into the sets that have Red, , Green, and blue inputs. Just the set with red, white and yellow. Now you won't get HD from this since it's not bluray or HD-DVD. Just be sure you select the corresponding input on the TV when you want to use the DVD player. For example, select input 1 from the on screen display if that's the one you plugged it into.
Nov 07, 2008 | Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD...
We are having trouble connecting our dvd player to our samsung tv.
couple of ways but the easiest way would be connecting the video and audio out from DVD need rca connections yellow red and white)
Yellow --- Video
white and red is audio out left and right.
find in your tv set inputs with similar colors its going to be input 1
or input 2 (as an example)
once you conect the cable matching colors yellow to yellow red to red and white to white make sure you select the same input on your set (video 1 or 2) that its throu input selection in remote control from tv or set itself.
Jul 04, 2008 | Samsung Televison & Video
How do we hook up the D.V.D. player to the T.V. We think we have done it correct but it does not play.
couple of ways but the easiest way would be connecting the video and audio out from DVD (need rca connections yellow red and white)
Yellow --- Video
Jul 03, 2008 | Televison & Video
Setup
I went to 'S' video for that function and use the external audio inputs for L/R. This path is slightly superior for video but carries no audio signal.
Check to see if they both have it.
The yellow cable is normally a 'composite' video cable which carries video and sync info.
The red and white are pretty standard for audio with red=right and white=left.
May 25, 2008 | Olevia LT32HVM 32 in. LCD Television
HP Media Center m7250n (ED842AA) PC Desktop Logo
235 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
