Back to:
Tags:
Umax Astra 4000U Flatbed Scanner
UMAX Astra 4000U transparency adapter problem (by 2 users)
By Duke - usenet poster
We recently purchased a UMAX Astra 4000U and a 4000U Transparency
Adapter. We want to scan dental x-rays. The platform is Windows 98, v.
4.10.1998, on a Pentium machine with 128 mb RAM.
The scanner will scan on the flatbed setting, but when it is set to
transparency (UTA), the scanner does not scan, and an error message is
generated: "00001500h". This happens either when VistaScan is activated
through another program or when it is activated directly.
The transparency adapter is unlocked. Its power supply is connected
and the connection to the base is secure. If I remove the glass and
gently move the head, the unit will repark when it is reassembled and
powered on. So it seems to be getting power. I never saw it light up,
even if I lifted the lid during a scan attempt.
It seems that the transparency adapter is a dud. In fact, I just
sent an email to UMAX support about this.
Does anyone have any suggestions? Thank you.
-- Margaret Nupponen
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by jfaccv, posted on Oct 18, 2008
It's the same situation.
Best Solution
posted on Aug 01, 2007
Helpful (85)
Cornish
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Did you ever figure out your problem? Did you get an answer from UMAX?
I have a 4000U with a transparency adapter. Can scan normally on
reflective mode, but have the same problem with the UTA. Mine has worked
in the past. Also have mine unlocked.
Would appreciate any help! Thanks.
Michael.
Posted via CNET Help.com
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on UMAX Astra 4000U transparency adapter problem:
I don't want to Accept this solution
Can you Help with these Scanners problems?
Scanners
I have found the drivers for the Minolta SC110 scanner for...
I Have Umax 4100 Astra Usb scanner.I Loaded WinXP on my...
Hi, I'm desperately looking for Windows Vista driver for...
I can not get it to work in windows XP service Pack 2 When...
minh co cai may Scanner ma cai dia Driver cua minh hu roi...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
