Question about Krups Caffe Centro 888 Coffee Maker, Espresso Machine
Water remains in filter basket after brewing
After I have brewed desired amount of espresso and have turned off the espresso function, there is still quit a bit of water in basket. Is there something wrong with the pressure?
    Problem Solver:
  • 3 Answers
Behind automat(machine side ) it gets clogged with grinds. Clean it with air hose. If that don't work, change the o-ring on automat.
Posted on Feb 16, 2009
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
Cuisinart brew on demand coffee maker
what about on/off switch, does it seem ok.
regards,
dont rate it untill fully satisfied
Aug 23, 2008 | Cuisinart DCC-1200 Coffee Maker
How do you descale
Since you don't specify what type of machine you have, these directions are a bit general: Run a solution of white vinegar and water through the machine, turning it off 1/2 way through the cycle and let it sit for 20 min to 1 hr. Then turn it back on and let the rest of the solution brew through. Dump that, rinse off the carafe, brew basket or whatever parts are removeable, are run a brew cycle with just water Different makers will tell you different amounts of each to use, but I usually mix about 1/2 water and 1/2 vinegar, sometimes more vinegar. Don't use all vinegar, there's no reason to waste it, and less than 1/2 vinegar won't work very well. It depends on what kind of machine you''re descaling for the total amount of water/vinegar mix you would use... if it's a 4 c. Mr. Coffee, I do the whole pot. If it's a 12 cup coffee maker I use about 4or 5 cups of the mixture. Something like a Keurig is a bit more tedious - same general directions, but after rinsing the water holder, run clean water through the brewer several times before making coffee again.
Mar 31, 2012 | Coffee Makers & Espresso Machines
Excessive water comes out the drain when brewing a expresso
Hi
Your 3 way valve is dirty or bad. Have you ever done a back flush with a detergent?
About every 3 months it is a good idea to do a backflush your machine with a blind filter basket. When backflusing you should only use a good espresso machine cleaner designed for an espresso machine's brew system. DO NOT USE a decalcification cleaner. First, clean the screen and dispersion plate plus the brew head and reassemble, which will prepare you for backflusing. Then, insert the blind filter basket into the portafilter with a ½ teaspoon of cleaner in the basket. Next, place the portafilter into the brew head and tighten. When the machine is hot turn on the brew button for about 10 seconds and then turn off. Then, wait 30 seconds to a minute. Next, turn the brew button on again this time for only about 3 to 5 seconds and then turn off. Wait 30 seconds to a minute. Repeat these last two steps six to eight times. After you have completed the backflushing remove your portafilter and rinse the blind basket with fresh water. Next, you turn on the brew switch to rinse the plumbing. Then, reinsert the portafilter into brew head and turn on the brew button for about 10 seconds and then turn off. Next, turn on the brew button for approximately 3 to 5 seconds and then turn off. Repeat about 4 to 5 times. Always remember backflushing is hard on electric 3 way solenoid valves, so it is not recommended do this no more than four times a year for a machine used in home application. You will find more good is done to your machine be properly cleaning the brew head.
Apr 23, 2011 | Pasquini Livia 90 Espresso Machine
How to use mr coffee tea appliance
First clean the pitcher, lid, steeping basket and steeping basket before you use it the first time. Run a brewing cycle without any tea the first time and discard the water.
With the unit unplugged, fill the pitcher with water to the top water level mark on the pitcher and then pour the water into the reservoir. Do not overfill. Place the steeping basket and lid on top of the machine. Place a tray of ice cubes into the pitcher. Turn the steeping dial to open. Put the lid with the spout open on the pitcher and slide it, spout first, under the machine. Plug in the unit and turn it on. Wait until it turns off automatically.
For brewing, fill the pitcher with water to the line for the desired amount of tea. Pour this water into the reservoir (with the steeping basket and lid removed). Place a Mr Coffee filter into the steeping basket and add the desired amount of tea bags or loose tea. You can add sugar or lemon over the top of the tea if desired. Slide the steeping basket into the unit and put on the lid with the steeping dial set to closed. Fill the pitcher with ice to the desired ice level or with cold water to the same volume as poured into the reservoir. (If you are using water, put the pitcher in the refrigerator to chill.) Slide the pitcher with the lid on under the brewer and make sure the lid is open over the spout. Plug in and turn on the brewer. When the brewing cycle is done, it will turn off. Turn the steeping dial to open to drain the remaining tea from the steeping basket. (Let the remaining tea sit longer before opening the dial if you want stronger tea.)
You can get the manual from http://www.mrcoffee.com/Products.aspx?cid=43 . Click on the link for the TM3 (all the models in a series work the same way).
I hope this helps.
Jan 16, 2011 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Kenmore Elite coffee maker Model # 100.9101670A Is this model on a recall? How can I get a manual for it? And what is the filter reset button?
I have a manual with mine and as far as "recall" goes on this model, I've not found anything recalling this particular model...<br /> <br /> The most important thing in the manual, that I have found, is how to clean and change the filter. If all else fails unplug the pot for 10-15 seconds; replug it...this resets it...(if it ever acts up, do this; it helps)<br /> <br /> The filter reset button: Your coffeepot should flash a small message stating: "change filter and clean" To do this you first, turn off the pot, remove filter~(the filter is in a long thin black plastic thing and the filter cover simply snaps and pulls apart to expose the charcoil filter; Remove the Filter, then fill the coffee pot with 7 cups of vinegar plus 7 cups cold water; Place a paper type regular coffee filter in the brew basket, or a thin paper towel works well too~(This traps and holds particles that get trapped inside the pot)<br /> <br /> Before brewing; PLEASE NOTE, brew the first pot of vinegar/water mixture only HALF WAY then TURN OFF and let it sit for a good 15 minutes to soften any deposits...<br /> Turn the pot BACK ON and brew the remaining solution. When brew stops turn OFF coffee pot, empty the solution, and discard the paper filter...<br /> <br /> Refill reservoir with cold water and turn ON; you may want to dump this and refill with more cold water to ensure the vinegar taste/smell is gone...<br /> <br /> Now, wash the brew basket and the glass pot...Open the black skiny Water Filter and replace with a new charcoil filter...Put Filter back in pot...fill brew basket with coffee and brew some mighty fine tasting coffee!!! Hope this helps....Good Luck
Jun 29, 2010 | Coffee Makers & Espresso Machines
Keeps spilling over during brewing
These tanks can't actually be overfilled since all water poured in displaces the exact same amount of water coming out the spout. So, whatever amount of water you pour in, will be the same amount of water that flows to your pot minus the amount absorbed by the coffee grounds and filter.
Your problems sounds like an undersized (Non Bunn) filter, or clogged brew basket. To verify this, try pouring in only half the water for your brew cycle and wait for it to finish dripping, then pour in the rest. If no overflow has occurred, you simply have the wrong type of filter. If overflow begins again, you have a clogged brew basket, since no Bunn can flow too fast for the brew basket to keep up with it.
This is because Bunn filters are manufactured differently than generic store bought paper filters. They will flow faster, brew cleaner and stand up better than normal generic filters.
Remember, Bunn makes their OWN filters for good reason.
They made the first, best paper filters for drip coffee pots, and all others are just generic dioxin gas producing paper.
Mar 05, 2010 | Bunn VPR Coffee Maker
Solis SL 90 occasional pressure loss, only a few drips of coffee before it switches itself off. Cleaning sometimes helps or not using for a bit.
HI
There are a few things that can cause this. If it brews without the portafilter in, then your coffees is too fine or you have a blockage in your basket if it has a ring in the bottom. You can clean the basket by using espresso machine cleaner like Cafiza or JoeGlo. Automatic dishwashing detergent works in a pinch also. 1/4 teaspoon in the basket then brew like normal but stop after 3-5 seconds and let set for 1 minute. Repeat this for about 5 - 10 brews then rinse the basket and run 2 - 3 long shots of just water through the basket (brew) to thourghly rinse the basket.
If it doesn't brew with out the portafilter in, then you have a blockage in your brew head. There is a screw that holds in the dispersion screen. Above that is a larger screw that holds in a check valve. if you can get the check valve out see if water will run through. If not your blockage is in this tube. run a heavy wire up this tube for about 4 inches. Twist the wire as you go. Test to see if you can get water through. If so reassemble and do a descale through both the wand and brew head. Use a strong descale the first time and then do a second. Descale 2 to 3 time a year to prevent this.
Nov 12, 2009 | Solis Crema SL-90 Espresso Machine
Bunn coffee pot blows water out top of basket
Check the grind on the coffee, brew a pot without coffee and if it overflows, then the machine has a problem. If it doesn't then try a coarser grind on the coffee.
Jun 14, 2009 | Bunn Coffee Pots: Thermal Carafe
Krups Caffe Centro 888 Coffee Maker, Espresso Machine Logo
153 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
