Question about SanDisk Sansa Clip MP3 Player
How u open the snasa clip to get out the battery
How do you open the sansa clip to get out the battery
  • 34 Answers
You can`t
Posted on Apr 13, 2009
How can i open the sansa clip to see if battery is damaged?
Google "sansa clip disassembly". This will provide you with links to many different videos and text descriptions on how to open up the Clip.
Feb 19, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip won't turn on even thought the battery is full.
Unfortunately there was a manufacturing flaw with many Sansa Clips which caused one of the battery leads to detach from the battery. A symptom of this is that the Clip will turn on and charge when connected to an external power source, such as USB or an AC adapter, but will not actually turn on using the internal power source (eg, the battery).
If your Clip is still under warranty, you should return it for a refund or an exchange.
Feb 17, 2010 | SanDisk Sansa Clip MP3 Player
My sansa e250 not play video files when connect to the system throug sansa video converter it tell your snasa not support video format
my ipod is sansa e250. the problem is im not able to load videos in my ipod.i can see in through system the videos are present in ipod but when i plug out and see in ipod the videos are not there.please give me a exact solution
Nov 15, 2009 | SanDisk Sansa e250 MP3 Player
Battery fully charged,but will not turn on when unplugged from charging cable. only plays when plugged into charger??
The battery wire inside may have broken off...its a common problem in sansa clip...if you are comfortable opening it up,you need to solder the wire into place correctly...
Sep 26, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Disk Clip MP3 (4gb) is stuck on refresh screen. Won't turn on or off. Computer/Rhapsody won't recognize it. Can't open to "reboot" the battery. All stuck! Thanks
Sansas usually have a tiny reset button you can push with a needle or a paperclip if you can find that, it may however be beneath the battery cover, but you should be able to remove this with a small screwdriver
Sep 03, 2009 | SanDisk Sansa Clip MP3 Player
It was working fine an hour before the problem started happening. now when plugged into a computer it is normal. when unplugged it usually stays on but now its just blank and off. earlier it would turn on...
The battery wire must have come off...Sansa clip has this problem...u'll have to open the sansa clip and solder the battery wire in appropriate position..
Aug 11, 2009 | SanDisk Sansa Clip MP3 Player
Hi, how do I format my sansa?
you connect it to the computer then go to my computer
then find the sansa and right click then press format
Dec 07, 2008 | SanDisk Sansa e250 MP3 Player
How to charge my sansa mp 3 player
it doesnt matter if the mp3 is on or off if its off the mp3 turns on when you connect it to the computer or the wall charger then starts to charge if its on it just starts to charge
you should be able to see the little battery charging
Nov 12, 2008 | SanDisk Sansa E280 MP3 Player
Snasa
My Sansa Clip mp3 player is lock
Apr 11, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
54 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
