Question about Nikon Coolpix L11 Digital Camera
Turn on camera and message says "This card cannot be used."
My mother has same camera and I take her card (which is exact same brand) out of her camera and put it in my camera and it says same thing, but it of course works in her camera. It actually was working when we first got the camera but it just suddenly stopped working one day.
-Manual says to make sure card connectors are clean. Hows that work?
  • alijclarke May 23, 2009
    Hello
    I have the same problem. After I used the card in the printer the camera won't accept it anymore. I bought a new card and I get the same message -'This card cannot be used'. Its a Coolpix 5600. Any help wouls be much appreciated.
  • 423 Answers
On the card there will be skinny metal strips or points. That is how the card connects to the camera. What they're saying is make sure you don't have any grease, or yuk on those strips before inserting it into the camera.
Posted on Feb 16, 2009
  • Rob
    Rob Feb 19, 2009
    What is the message your getting?
  • Rob
    Rob Feb 19, 2009
    You say the card works in her camera and not yours? If so, the card was probably formatted in her camera, thus it would not work in yours until you formatted it in your camera (losing all the pictures).
    If it doesn't work in either of your cameras, then try this: check the card. Has it been locked? There is a little switch on the side, one postion is locked and the other is unlocked. Make sure the switch is unlocked. Let me know if I can still help you.
Need to know if u need to have exactly kodak sd card or can u use any brand
Any brand is fine. But if your camera is older than a few years, make sure that you utilize the proper size card for it (2GB or less). But if your camera is new, it should be able to use any size card.
Jul 15, 2011 | Cameras
Everytime I turn it on its says out of memory or this card cant be used
That's a typical message on the L10 if you have either tried too large a capacity of SD card, or if you have used an SDHC car.
The L10 is compatible with SD cards ONLY up to an absolute maximum of 2GB capacity. It is incompatible with the commonly available SDHC cards which start at 4GB capacity.
If you are using the wrong type of card then your fix is to stick to using SD cards, and for the greatest reliability try to keep to a maximum of 1GB, as in common with many similarly specified models the L10 can be a bit fussy about brands when you push it to the 2GB limit.
I hope that my free and speedy answer has been of use, if so please take a moment to rate my reply. If not then instead of rating my answer, please add a comment giving details of exactly which card you have been using and whether you get the same problem with other SD cards and I'll try to provide further assistance.
Jun 21, 2011 | Nikon COOLPIX L10 Digital Camera
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
Mar 11, 2011 | Kodak EasyShare C330 Digital Camera
Probably not a fixable one, but here goes. I
Hopefully you know by now that the message wanted you to push on the card to eject it. The pictures you want to retrieve...are they on the card or the internal memory? You can easily download from the card using a simple card reader. If you've ruined the mother board circuit on the camera, then you probably can't retrieve the pics from the internal memory. In retrospect, you should never use the internal memory on a camera. It's too small to be of any use and it usually causes no end of troubles.
Dec 29, 2009 | Olympus FE-140 Digital Camera
Memory card error with new memory card
Hi there, welcome to FixYa.
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Rob
Mar 14, 2009 | Canon PowerShot A75 Digital Camera
My canon 20d stopped taking photos for no aparant reason. Kept getting error 99 and when I re insert the battery it starts clicking on it's own whether turned on or not. I sent it to Canon repair who...
If two cameras are doing it, I would suggest the contacts on your lens are dirty.
Try the following diagnosis steps for solving ERR 99 issues : -
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Memory card error
hey man I have the exact problem my one is exactly the same i need help for it
May 14, 2008 | Pentax Optio S4i Digital Camera
I'm needing a driver for my FE-280
I went to Olymbus website to find the driver for the FE-280 Digital camera and it states, no software availble at this time.
They show the camera on the website and I know there is a driver for it, but they are not supplying the consumer with it. Bad choice for Olympus.
I have given you some information and links below:
http://www.olympusamerica.com/files/FE-280%20Instruction%20Manual.pdf
This is the manual for your camera.
Go page 45 at the very bottom. Using a New Card
The FE-280 does not recognize my memory card. What can I do?
First, refer to the xD-Picture Card™ Compatibility Chart to verify that the card is supported in your model. If the card is not supported, return it to the store where you purchased it.
The FE-280 may not recognize non-Olympus brand media or a card that has been formatted on another device, such as a card reader or personal computer. As a general rule, xD-Picture Card media should only be formatted in the camera. Card readers should only be used to copy files from the memory card to an external device.
You may be able to use the card if you format it in the camera.
Warning: Formatting a media card will delete all content on the card.
When I put an xD-Picture Card™ flash memory card into my camera and turn it on, I get a “Card Error” message. What can I do?
This message occurs when the camera is unable to recognize the memory card or when an attempt to format a card fails.
If you see this message after inserting a brand new card, refer to the xD-Picture Card Compatibility Chart to verify that the card is supported in your model. If the card is not supported, return it to the store where you purchased it.
If the card is supported, it may need to be cleaned. Wipe the gold contacts of the card with alcohol using a soft cloth or tissue. When the contacts are dry, insert the card and turn the camera on.
If the Card Error message still appears, remove the card and insert a different supported card into the camera. If the camera reads the second card, then the camera is working properly and the problem lies with the original card.
If you receive this error message after a failed attempt to format the memory card, the card may be defective. For assistance, contact Olympus’ Customer Service and Repair Center using any of the following methods:
Phone: 800-622-6372
http://www.olympusamerica.com/cpg_section/OM_UpdateSoftware.asp
This is about updating the olympus Master Software.
If I can do anything else for you let me know
Mar 29, 2008 | Olympus Stylus 800 / ? 800 Digital Camera
Nikon Coolpix 4500
Did the 1st card ever work? (i.e. is the camera new to you). After many uses, the memory cards need to be reformatted (thru your Setup menu). Post the make and model of the cards and we can check to see if they're compatible w/ your camera.
Aug 04, 2006 | Nikon Coolpix 4500 Digital Camera
Canon parweshor s400 ixus
First of all have you seen the answers you got on a parallel post? - http://www.fixya.com/problems-solutions/t103943,p294010/Canon-Digital-Cameras.aspx Some good suggestions there. Always try to leave the battery charging until fully charged. Batteries like to be fully charged and then fully drained, it's not 100% causing this specific problem, but it will prolong your battery life. Certain small brands for memory cards can have compatibility problems with some cameras, including a "card locked" message, when the card isn't locked. The big brands(kingston, sandisk etc) will usually work fine and fast with all cameras. Pretec is also pretty good. Try using another card, and see if the problem persists. And don't completely rule out the possibility that you have the card locked... ;] Good luck
May 26, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Nikon Coolpix L11 Digital Camera Logo
82 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
