Question about Dell INSPIRON 3500 INTERNAL 56K MDM 0008713D CD-ROM Drive
I can't load a new OS.
I'm trying to install Ubuntu from cd, but when i start my pc it goes straight to "grub>" what can i do to install this?
  • Dell Master
  • 13,433 Answers
Hey,
ubuntu installation guide is here
https://help.ubuntu.com/community/Installation
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 15, 2009
How to fix error 17 by starting windows xp at acer aspire zg5
Error 17 sounds like a grub bootloader problem, IE: your Acer disk didn't perhaps reload the boot code for Windows, or remove grub entirely.
http://www.ubuntu.com/download
Ubuntu 10.10 Latest Version
which can repair what windows has ruined and is unable to fix fix the problem
either burn it to a disk as an iso and install
you might have burn it to an iso first then boot from the cd rom to install ubuntu or you might just try to install ubuntu directly from the download if it does not install you might save it to a folder then burn it as an isohttp://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
once Ubuntu has been installed on your computer has corrected the fault you will be able to reinstall windows
or keep ubuntu and install windows next door to it
you can have a dual boot computer with both windows and ubuntu linux you will need to partition your hard drive to do this
is a free partition program.
I have actually used this process to fix my computer with similiar problems and it works.
also
You might want to look at this
http://en.kioskea.net/forum/affich-4...aspire-one-zg5 also
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
Right click on the error message select properties you will see all details about the error
or click start type in event viewer pressENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Nov 27, 2013 | Computers & Internet
Hello I have a asus 1001p netbook that doesn't
Sounds like a job for a repair shop that can attach an external drive to it and reload the operating system.
May 09, 2012 | ASUS Computers & Internet
Am pulling my hair out. I'm a newbie to Linux but keen to get into it. Installed 9.10 as a dual boot alongside XP and after problems with grub, which I have re-mounted, I get to the OS choice page. XP...
Backup, Repairing and Reinstalling GRUB
  • To make a backup a copy of the existing menu.lst file use: cp /boot/grub/menu.lst /boot/grub/menu.lst.oldYou can try re-installing the grub using the Ubuntu Live CD, in two different ways.
GUI
  1. Boot your computer up with Ubuntu CD
  2. Go through all the process until you reach "[!!!] Disk Partition"
  3. Select Manual Partition
  4. Mount your appropriate linux partions / /boot swap .....
  5. DO NOT FORMAT THEM.
  6. Finish the manual partition
  7. Say "Yes" when it asks you to save the changes
  8. It will give you errors saying that "the system couldn't install ....." after that
  9. Ignore them, keep select "continue" until you get back to the Ubuntu installation menu
  10. Jump to "Install Grub ...."
  11. Once it is finished, just restart your computer
Jul 27, 2010 | Canonical Ltd. Ubuntu
How can I uninstall Ubuntu from Dual Boot. I have a dual boot of Windows Vista Ultimate with Ubuntu 9.04 The specs of my computer is 2gb ram, 500 gb HDD and dual core processor 2.66ghz (E5300). I installed...
How to remove Ubuntu from a Vista dual-boot config
On my new PC I wanted (still want) to have toa go with Linux. I chose to experiment with Ubuntu. I downloaded thedesktop CD, burned it, freed up some disk space (inside Vista) andloaded up Ubuntu from the CD. After some experimenting I figured outhow to install Ubuntu in the empty disk space and it all worked fine(GRUB took over my booting (recognized Vista automatically!) and Ubuntuloaded up fine).
Then I tried to install my GPU drivers andeverything went wrong.. For some reason Ubuntu wouldn't boot anymore(failed to load X-Server or something). I was completely lost andwanted to remove Ubuntu.
This is where things start to get really messy!
Ifyou simply remove the Ubuntu partition, GRUB (Linux boot loader) willstill be on your PC (in control). It will trip out, as the Ubuntupartition will be removed.. Bad thing!
So you need to restore your Master Boot Record (MBR) for Vista (so that Vista will handle the booting, not GRUB).
Googleonly pointed me to sites that explained how to REMOVE VISTA, whichisn't what I wanted. Many sites talked about the 'fixmbr' command, butthis is really only available in Windows XP.
So how do you restore your MBR for Windows Vista?
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec.exe /FixMbr, and then press ENTER.
That'sit. Now when you reboot your PC, Vista will load automatically... Youcan now safely boot using your Ubuntu desktop CD, to use the built inGnome Partition Manager to remove your Ubuntu partition!
Apr 06, 2010 | Microsoft Computers & Internet
What is grub error 17? how to fix it?
Its GRand Unified Bootloader used in Linux OS.
Normally you get this error when GRUB is not able recognise the partition from which you are trying to boot the system. Make sure the boot partition on your system is recognisable by GRUB (such as EXT3).
You can try to restore the GRUB using the LIVE CD
  1. Boot From Live CD
  2. Open Terminal Window
  3. type >sudo grub
  4. then type : find /boot/grub/stage1
  5. you'll get something like: (hd0, 1)
  6. then type : >root (hd0, 1)
  7. type: > setup (hd0)
  8. >quit
  9. >exit
Remove the Live CD and reboot the system.
Please let me know if you need any further assistance.
Thank you for choosing Fixya
Oct 30, 2009 | Compaq Presario M2000 Notebook
Cannot access XP after Ubuntu Installation
- reboot with LiveCD
- in CMD run command fixmbr, fixboot
restart, load Windows XP.
OR in Unbuntu Grub write XP portition
Aug 20, 2009 | Computers & Internet
Ubuntu grub error 17
You have to delete the ubuntu partition completely and recreate a new partition for the vista install. You can do this during the vista setup.
Jan 19, 2009 | Canonical Ltd. Ubuntu
There is no grub menu just grub command
Try running the command grub-install or if that fails, try the help command
You could also boot off the Ubuntu CD and be able to reinstall grub
Regards,
Deboo
Sep 24, 2008 | Canonical Ltd. Ubuntu
Ubuntu error 22
While in Ubuntu do:
sudo fdisk -l to find the drive you want to boot to.
On the command line type:
"sudo grub", this will give you the grub shell >
If the disk you want to install the MBR is sda* for instance, then type (at the grub prompt):
"setup (hd0)"
then type "quit" at the prompt.
Aug 25, 2008 | Canonical Ltd. Ubuntu
Computers & Internet Logo
64 people viewed this question
Alun Cox
