Question about Canon EOS 40D Digital Camera
Cannon 40d error99
Hi everyone,
fell into bog hole yesterday while out taking some shots,was up to my shoulder in water before i knew it,problem is i had my 40d around my neck at the time.took in water and is now making little click noise when i switch it on and is going straight into error99 ???
  • 423 Answers
Sorry but, i think it's probably toast.
Posted on Feb 16, 2009
  • Rob
    Rob Mar 07, 2009
    You dunked a sensitive electronic device underwater. How was my answer inappropriate? Do you really need someone to tell you to take it to a shop for repair? Or do you want ta magic word to make it all better?
I have a Cannon 40D 28-135mm lens. With the lens in auto focus, the lens will act as if it has found the target will focus, beep, ready to shoot. The lens then makes a focusing sound and moves just a...
Does the camera still work even thought it does a small extra adjustment?
Are your pictures fine and is the camera working ok otherwise?
If your pictures are good then theres noting to worry about.
if on the other hand you can't take pictures, try reseting the camera, there should be a small reset hole in it.
Jul 04, 2008 | Canon Cameras
Which would you recomend i buy 450d or 40d
You can compare these two products from the web site below:
http://www.dpnotes.com/canon-40d-vs-canon-450d-digital-rebel-xsi/
good luck and do rate the solution if helps
Dec 07, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Will not release shutter on canon 40D
Cannon is notorious for their auto focus and automatic setting to be very discriminant. If you are to close to your subject while in these settings granted your strobe will fire and your flash may flip into position but the shutter just wont work. Cannon is trying to tell you you are too close. You need to back up. If you are trying to get that close up and don't have the proper lens that's all you are going to get.
It is best to go long lens then go for your close up.
Mar 09, 2010 | Canon EOS 40D Digital SLR Camera Digital...
Canon 40D and 64Gb CF Card
What i find is that the larger the card the slower the write recovery in taking pictures. If you are an action photographer this is a pain as things happen fast . To have the camera take so long to recover from a write leaves you open to losing some excellent shots. So my rule of thumb is use smaller value cards. If you are just a happy shots photographer then this probably doesn't really matter.
Thanks for using Fixya
Sep 15, 2009 | Canon EOS 40D Body Only Digital Camera
Focusing issues with canon 40D when taking sports shots
I believe I have found my problem. I think my image stablizer on my lens is on the brink! I turn it off and got good pictures.
Jun 03, 2009 | Canon EOS 40D Digital Camera
Waterpump bleeder valve fell off !!
are you calling the bleeder valve the weep hole in the bottom of the pump?  If it's leaking you need a new pump.
Mar 15, 2009 | 1997 Ford Taurus
Preview screen half white, with black blob!
I think ribbon connector of LCD is misaligned in your camera.
If you are comfortable with it, please apart camera and readjust ribbon connector at main board.
Jan 26, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Internal Temperature too high to shoot.
This is obviously a problem with the internal parts of the camera. There are too many things it could be to give a definitive answer, and it would be too complicated for an amateur. If you take it into a local camera shop they should be able to run diagnostics on it and replace the problem.
Best of luck to you.
Nov 07, 2008 | Canon EOS 40D Digital Camera
Canon EOS 40D Digital Camera Logo
114 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
