Question about Panasonic DMR-E55 DVD Recorder
DMR E55 timer recording won't work
I used to have regular cable service, but when I purchased a Sony HD TV, I needed to sign up for high definition, digital service with my cable company.
When I hooked up our 2004 model E55 Panasonic Recorder to our new digital service box from the cable company, a message appeared on the screen- "Copy Protection Blocked - press exit to cancel". Don't know what that meant, but I pressed exit to cancel, ran through the setup and then tried to use the Timer Recording feature. When I tried to enter a channel, it kept going back to Channel 3. It would not let me enter any channel. I can't get the thing to record anything. It will play a purchased DVD, but won't record.
PLEASE, ANY SUGGESTIONS.
Signed,
Frustrated
  • Mark Egan May 11, 2010
    There are some issues of recording digitally transmitted programming. For more information, research the term "Digital Rights Management" on the Internet.
    Champion:
  • 236 Answers
Your recorder doesn´t have a digital tuner, let alone an HD one. You can record digital programs via your TV tuner if it gives a signal out. Connect your TV to AV1 or AV2 on your recorder and program the recorder to record from the one you chose. You must program the TV separately (I don´t know if this is possible on your TV) or leave it on and on the channel you want to record.
Posted on Feb 18, 2009
Panasonic DMR-E55 DVD Recorder plays does not record
Are you trying to record from a broadcast signal, or via one of the SCART inputs? The E55 has an analogue tuner. If the TV companies in your part of the world have switched to digital broadcasting, the E55 can ONLY be used to record via the SCART and other video inputs, the tuner won't receive anything
Dec 18, 2014 | Panasonic DMR-E55 DVD Recorder
Hi, I am in Melbourne Australia. Can I receive gem hd channel thru my dmr-ez48v. I haven't tried but I do have a hd monitor screen that I can plug the unit into. Also what does the hdmi on the unit do....
HDMI means high definition multimedia interface.
When connected to an HDMI compatible unit, an uncompressed digital audio and video signal is transmitted, enabling you to enjoy high quality digital video and audio with just one cable. When connecting to an HDMIcompatible HDTV, the output can be switched to 1080p, 1080i or 720p HD video.
Panasonic uses Viera link option between their video products.
When connecting with a Panasonic TV (VIERA) or a receiver equipped with 'HDAVI Control' function, linked operations are possible. [Linked Operations with the TV (VIERA LinkTM HDAVI ControlTM)]
Please use HIGH SPEED HDMI cables that have the HDMI logo (as shown on the cover).
It is recommended that you use Panasonic's HDMI cable.
Recommended part number: RP-CDHG10 (1.0 m/3.3 ft.), RP-CDHG15 (1.5 m/4.9 ft.), RP-CDHG20
(2.0 m/6.6 ft.), RP-CDHG30 (3.0 m/9.8 ft.), RP-CDHG50 (5.0 m/16.4 ft.), etc.
Non-HDMI-compliant cables cannot be used.
(the above is from the owner's manual of this model - page 40 tells you about linked operation using HDMI HDAVI control and how to set it up)
As for Gem HD, this unit has an SD (standard definition) digital tuner - it will not decode/receive HD channels. I should point out that 7mate also is a HD channel but is not specified as such in any menu or even their website. (I found this out by accident when I tried to record on timer 7mate one day and all I got was 'unable to decode HD channel' banner at the bottom of a blank screen)
Channel 11 is a SD channel - so this will work with your DMR-EZ48 as will all the other relevant main free to air channels (ABC/7/9/10/SBS). GO! is also a SD channel.
To be able to record HD to this combo unit you will need a HD set top box connected via its AV inputs. HDMI simply means you will get HD video quality from the combo to the TV, you will not receive HD channels from your HDTV to your DMR-EZ48 unit via this method.
Mar 26, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
RF OUTLET FREQUENCY
normaly set to ch36 or ch58 in U.K. If U.S. I don't know
Mar 25, 2010 | Panasonic DMR-E55 DVD Recorder
I am trying to connect my DMR E55 DVD recorder to my Viera 32LX TV and take the satellite signal from the TV and the recorder is reading nothing. I am using optical cable and a SCART. What am I doing...
To hook up you need to go from the satellite box to the recorder then to the TV. If you do that then you should be able to record the show on Tv. You can get the manual on the link below. Page 7 tells you how to hook up.
http://www.hollywoodstudiorentals.com/uploads/030708__Panasonic_-_DMR-E55%5B1%5D.pdf
Dec 30, 2009 | Panasonic DMR-E55 DVD Recorder
Setting up the Panasonic DMR-E55 DVD Recorder
If the freeview box has a SCART output, connect that to either AV1 or AV2 on the Panasonic. To record, select either AV1 or AV2 as the input. Use the other AV to connect to the TV to playback.
Jan 28, 2009 | Panasonic DMR-E55 DVD Recorder
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Panasonic DMR E55 DVD Recorder
Hi James,
When in EXT link mode the recorder is looking for a signal from the TV to start recording off the TV's timers system.
There is a EXT Link button on the remote control and pressing that will take the machine back to normal mode. The button is near the bottom of the remote.
Hope this helps
Andy
Sep 09, 2008 | Panasonic DMR-ES10 DVD Recorder
SPEAKERS TO DMR E55 DVD RECORDER
Using a receiver to operate speakers?...accordianman
Nov 08, 2007 | Panasonic DMR-E55 DVD Recorder
Please help me with the set up of two Panasonic DVD recorders
To record and veiw DVD movie at the same time connect the DMRE55 RCA cable output to DMREZ25 input 1 then the DMREZ output to yout TV input. Then on the DMREZ press input select and select IN1 to record from the E55.
Nov 04, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic dvd video recorder dmr-e55 user manual
http://service.us.panasonic.com/OPERMANPDF/DMRE55.PDF
Oct 13, 2007 | GoVideo Home Audio&Video: Go-Video DVD...
Panasonic DMR-E55 DVD Recorder Logo
313 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
