Question about Linksys Wireless-G WRT54G Router
Passphhase cant find my passphase for linlsys router 54
    Novelist:
  • 180 Answers
I'm assuming you set the password for yourself and have forgotten it? If that's the case, you'll have to start over. Press and hold the reset button in the back of your router for about 30 seconds. This will reset it to the factory default settings. Now you're able to use the default passwords. On older routers, the default username is blank and the default password is admin. On newer routers, both the default username and the default password are set to admin.
Let me know if this is what you needed. If not, we'll take it another step if possible.
Posted on Feb 16, 2009
Help secure setup
login to your router from a browser to 192.168.1.1 the default login is blank password is admin if you have not changed it. go to wireless. then to wireless security. select wpa/wpa2. type in a passphase. any wireless devices will need this password/passphase to connect to your wifi network.
Feb 23, 2012 | Linksys Wireless-G WRT54G Router
I want to secure my Linksys router
you can secure your router by going to internet explorer and browsing to 192.168.1.1 the login/pass is blank/admin if you haven't changed it
go to the wireless link and then click on wireless security to setup your encryption/passphase.
choose wpa personal and then a passphase for for your wifi. any devices that want to use the wireless will need to tyep the passphase you created to join the network.
May 01, 2011 | Linksys Wireless-G Broadband Router
Cant find PIN
if you dont know the pin you can put the CD in that came with your router.
if you lost it or dont have the CD then you can just setup the router manually by using your browset to http://192.168.1.1
login. the default login/pass is blank/admin
then go to wireless and choose manual.
this will let you set the SSID or name of your wireless network.
then you go to wireless security and choose WPA-personal
type in a passphase for your wireless password.
you will need to configure all your wireless devices to the new SSID wireless network you created and use the passphase you created to join the secured network.
Mar 29, 2011 | Linksys Wireless-G WRT54G Router
May i have a quuestion to you regarding my problem on how to set up the linksys broadband router 2.4 ghz 54 mbps through my loptop? pls answer me asas pls.!!!!
you need to configure your linksys router. to do this
connect to the router with a cat5 cable in any of the lan ports.
open internet explorer and go to the http://192.168.1.1
the default login/pass login : blank pass: admin
if you had changed this before please use that login/pass. or reset the router if you can't login by holding the reset button for 30 secs.
once you login go to the wireless button.
there you can set the SSID of your wireless network. this will be the name of your wireless network.
then go to wireless security to set the security to WPA.
choose a good passphase that you can remember.
apply the settings you had made.
on your laptop unplug from the router and search for a wireless network. you should see the ssid name that you made.
connect to it and it will prompt you to input a wireless password.
put the passphase that you setup for your wifi.
you should now be able to surf the internet wirelessly.
Mar 28, 2011 | Linksys Wireless-G Broadband Router
When i log on to internet my wirelss router asks for a passphase i did not set upthe router how do i find out or reset passphase
The passphrase is a way of setting up the encryption code in the wireless router. This is used to protect your wireless router from unauthorized access.
The passphrase is configured in the router wireless configuration and this configuration is applied to the wireless card in the laptop/computer to allow the laptop/computer to connect to the wireless router.
Please click on this link and follow my instruction to configure your wireless router and wireless card in the laptop/computer :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jun 22, 2010 | Computers & Internet
My wireless card is asking for a passphase 8 - 63
WPA requires an group of alpha numeric sequences for encrypting data between the wireless card on the computer and the wireless access point/router.
These sequences are hard to remember when setting up the wireless Access point/router soa passphase is used to generate these alpha numeric sequences, just use any english phrases such as "I love you 2 pieces", then this can be used to configure your wireless card on your computer.
Jan 13, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Linskys WRT54GX ver.2 with SRX
better to reset the passphase of your router. You need to get into the admin page of the router's webpage. just follow the 'how tos' in the manual. hope this helps
Oct 17, 2008 | Linksys Wireless-G WRT54GX Router...
Setting up a wireless connection between my linlsys pcmcia card and my 2 wire gatway
first insert your pcmci linksys card into the laptop, you would find a found new hard ware screen, insert the setup disk, and then follow the steps, automatically your card would be installed, once the installation is done, the wireless adapter , would detect wireless signal, try connecting to the wireless network.. if it asks for any key, look at the bottom of your 2 wire router you would find a 10 digit number, enter the number as the number as key code or password, automatically you would get connected.. if case if you have any problem , revert back ..
Nov 19, 2007 | 2wire HomePortal® 1800HW Router...
Linksys Wireless-G WRT54G Router Logo
55 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
