Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Leaking while draning
The machine will wash the clothes but it leaks when it is on the spin cycle and it only leaks on the right side. Any ideas?
  • 2 more comments
  • jennifer_mos Feb 15, 2009
    no it is coming from the inside
  • jtamme84 Feb 15, 2009
    My whirlpool cabrio is leaking from the bottom as well! I am not sure what the problem is? I know it just started comming out of the bottom and that it is not a drain line or anything from the hoses. Any suggestions????? let me know,
  • James Bradburn
    James Bradburn May 11, 2010
    Is the drain line located on the right side?
  • James Bradburn
    Is it leaking from the drain line in the back?
  • 640 Answers
Take the back off,,look up under the tub thats where the pump is at,,either the pump is leaking or the drain hose,,,or tub to pump hose...onthejob
Posted on Feb 16, 2009
Kitchenaid washers vibrating spinning, and leaking water on the right front side
Motherboard might be on it's way out..
May need balancing...
Check the hoses for leaks
Nov 01, 2011 | Washing Machines
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Apr 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool® 4.6 Cu. Ft. Cabrio® HE Washer leaking water
coins may have breached the outer tub. expensive way to learn to remove loose objects fro clothes before washing them
Sep 14, 2008 | Washing Machines
Washer will not spin sometimes
look under for the belt(s). Belts must be clean and dry, and in good shape, no oil or grease on them. If the machine is leaking on the belt, it will slip. Detergent will make the belt slip.
Apr 01, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing machine does not spin out all water
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 02, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
156 people viewed this question
Dan Webster
Dan Webster
Sal De
