Question about HP Photosmart 3180 All-In-One Printer
Act like it prints but doesn't print
My 3180 acts like it's printing but then doesn't print. I've checked all the usual things - USB cable, reloading driver, etc. Once in a while I can get it to work for a few print jobs, and then it does the same thing again. It used to work fine and will still scan and copy. I'm printing off a Mac if that makes any difference.
  • Ryan Mar 08, 2009
    Sounds like the same problem I was having: print jobs go through the print queue just fine, the printer takes in a sheet of paper, and I hear the print heads move back and forth a few times and then it just ceases all activity with the paper halfway in. It print's photocopies just fine. I found it to be something application related - it seems to print HTML webpages from Firefox, but it won't print PDF files from Adobe Acrobat Reader (v8.1.3). My OS is Windows XP Media Center Edition, SP3.
ctf1800
  • 4402 Answers
SOURCE: HP Laserjet 3050 won't print - os X
Power off printer, disconnect all leads such as USB, network, etc and power on again.
Does it power on to the normal state?
Are there any messages on the control panel or light patterns (eg off, on, flashing etc)?
Posted on Jan 10, 2008
SOURCE: black ink does not print
This is quite a common problem for these models, particulary with the black not printing, to check if this is your issue print a self test page, then try a cleaning process through the tools menu if you are still not getting any black print you have the classic blocked nozzle/ airlocked printhead issue, it is most commonly seen in printers that have used aftermarket black ink at some stage and/or have been sitting unused for a while.
try the following
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
if this doesn't work the only way to clear it is to disassemble it and soak the bottom of the printhead in hot water then reassemble and clean the head
good luck
PS it only seems to be a problem with black refilled/aftermarket cartridges, haven't seen any probs with any of the colour refills
Posted on Jun 03, 2008
SOURCE: Won't print - just flashes it's lights at me!
I tried what phrek said (" Pressing the flashing buttons simultaneously, evokes the printer to spit out an internal diagnostic page ..."), but after the diagnostic page printed out the printer worked fine again.
Thanks for the help, and hopefully things work out for the rest of you as well.
Posted on Aug 18, 2008
  • 43 Answers
SOURCE: HP 3015 AIO printer Won't print
Yes, you are correct in that you have to select the USB port from the driver in order for the printer to print to USB, or install another driver for the USB port.
Posted on Jan 23, 2009
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Saying reload cartridges
Hi Linda,
Try removing the cartridges, where they clip in see if anything is not obstructing the clips where they lock into position.
Also check the contact points on the cartridges, and those inside the printer for the cartridges. lightly clean those points.
Hope it helps
Sep 28, 2014 | Epson WorkForce WF-7510 Wide Format...
I have an epson stylus TX110 and it was printing fine today, but then as is sent a job from adobe it prepared to print (made usual noises) but then didnt take any paper and just went quiet. I've tried...
Try purging your temp files. If it's a usb connection try a different usb port. Since it can print from scan and do a test nozzle print then it's not getting data from the pc to the printer. If a different port doesn't work either, and if purging your temp files doesn't work try it on a different computer if possible. You may need to reinstall the driver for it.
oh and make sure you don't end up with one of those 'oh duh' moments :) ... check both ends of the cable to make sure it didn't become loose or unplugged :)
Jun 05, 2011 | Epson Stylus Photo R1900 InkJet Printer
Recently had to reload everything on a new hard drive and reinstalled the Z82 drivers and updated firmware. Printer acts like it is printing but does not print anything. Any suggestions?
do you get anything from the self test? Press Setup until MAINTENANCE appears in the display. Press ?ž?or ?¿until PRINT SELF TEST appears in the second row of the display. Press Enter/Select. The message PRINTING appears in
if that works then it is definitely on the computer if not then you know it is a printer issue. When you plug in the USB cable did the computer react as if something plugged in? Try re-installing the drivers. Make sure the port selected is USB
Nov 30, 2010 | Lexmark Color Z82 InkJet
Dell 540 photo printer
It might be time to, but try these first:
(1) Try rebooting the computer (Press Ctrl+Alt+Del>Shutdown>Shutdown OR press and hold the power button down on the front of the workstation/computer/tower/CPU until the unit turns OFF)
(2) If that doesn’t work, then try clearing the print queue: Start>Settings>Printers>Double-click on the printer>Right-click on the print job(s) and click cancel/delete/purge documents and try reprinting a document
(3) If that doesn’t work, then try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print
(4) Run a Test Print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
Jan 02, 2009 | Dell 540 Photo Thermal Printer
HP LaserJet 2420 printing problem
Hi all of you
  • try use another data cable.
  • If the printer work proper before do system restore.
Hope this fix your problem,
Thanks
Hamedo
Nov 20, 2008 | HP LaserJet 2420 Printer
HP Photosmart 3180 All-In-One Printer Logo
97 people viewed this question
Seeker5211
Seeker5211
