Question about Dacor ER36D Stainless Steel Island Trim Kitchen Range
My Dacor ER36D wont heat after self-cleaning. What should I do?
Set up the self-cleaning this afternoon. Went to cook dinner and the oven will not heat at any setting.
  • lori_prusso Feb 16, 2009
    Thanks for the suggestion. I took a look around and don't see any irregularities. Was hoping there was a reset button or something..oh well.. I plan to call decor tomorrow to see if there's anything else. Frustrating b/c it's only 6months new. Will write again if it's a quick fix or not.
Okay, I'm not a service tech, but I fixed this very same problem with my double Dacor oven. My wife self cleaned the bottom oven and after that when we tried to use it, the oven would only stay at the pre-heat (135F) level. My oven is electric, so I flipped the breaker switch at the breaker box in the garage that powers the oven...I didn't want to get electricuted. I opened up the oven door to the bottom oven. Where the latch sticks out there is a grill held on by 4 screws. I took the grill off and using a flash light I found the silver looking "thingy" that is mounted behind the oven latch mechanism. There are two black wires coming from this "thingy." On the right face of the thingy there was this little red button. I pushed it in till I heard in snap back into place. I believe this silver thingy is some sort of heating safety switch. Pushing the red button back in apparently resets the switch. I put everything back and turned the power back on to the oven and it has been working just fine ever since. I hope this layman fix can help the next guy.
Posted on Apr 14, 2009
Same thing happened to my Dacor Oven ERD30 -it quit after self cleaning - I opened the oven door and saw an angled cover just under the controls - it looks kind of like a metal grill held on with 8 screws - turned the circuit breaker off and took 8 screws off - then the cover came off and exposed the locking mechanism in the centre and two black squares on the right ( 1 inch square) with small red center bottons. I pushed the red center buttons with my screwdriver as they were fairly stiff ,and they kind of clicked - I think this was a reset for excess temperature and was triggered by the self clean - this fixed the problem. Hope this helps.
Posted on Dec 11, 2009
Apparently those little red switch buttons trip with the extreme heat of selfcleaning. Mine did also and I fixed it with the help of you guys above. On my oven, it was 6 screws to remove a cover and presto! Thank you.
Posted on Apr 21, 2010
    Scholar:
  • 87 Answers
I would guess you probably have a element out. These stoves are suppose to be self cleaning but I can't tell you how many times I go to repair a stove and it's usually after self cleaning. I'm not in favor of self cleaning becuase it gets SO hot for SO long it really stresses out everything in the stove. If your element is exposed, look for cracks or any iregularity. If you can't see it, it will be under the bottom pan and that usually comes off with 2 screws in the back. Elements can be found about anywhere. Here is one spot.
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
Posted on Feb 15, 2009
Oven Pre-heats too high
Your oven sensor has gone bad and telling the control board/thermostat to keep heating. Find the model number on the range and go to a parts distributor like repairclinic.com or apdepot.com and order you sensor. This is an easy repair.
Apr 23, 2012 | Dacor ER36D Dual Fuel Range
I'm in the middle of cooking dinner and I got a f3 e2 error and the oven locked...how do I get my dinner out? My husband is an elevator mechanic so he's handy...we turned off the breaker to quit...
That code refers to the oven temperature sensor sensing a too hot oven. I suspect what you did to quite the cleaning cycle should help once the temperature cools down the door should open. I am a little confused, did you set the oven to clean while your cooking, or did it do this on its own, or was it preset and yopu forgot it was set to clean? Your temp sensor may be going bad if it just detected a too hot oven while your cooking. If it started cleaning then it may have gotten too hot and this is the safety device to prevent it from overheating. it sounds like it is trying to self clean, its essential that you find the error code sheet, stuck in the stove or oven cabinet somewhere, also check your range settings so that it is not set to auto clean.
Jun 28, 2011 | Ovens
Did self clean noe it wont heat up to cook dinner
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 17, 2010 | Whirlpool GBS307PR Electric Single Oven
When I was cooking dinner and went.. when I was
did the clean lock get pushed to lock it ,let the oven cool down and it well unlock. it should open at about 100 degrees
Jul 21, 2010 | Crosley CE35111AA Electric Kitchen Range
Self Cleaning NOT working and Locked itself...and BEEPS NON STOP
heatman101
Asker's Testimonial " Thanks for this! I did not realize self-cleaning was so bad for the appliance2_bing.gif. Fortunately, I hardly ever do it! " - sej51
Apr 20, 2010 | Dacor ER36D Stainless Steel Island Trim...
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
Our Dacor Millennia wall oven will not heat
There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
Dacor Electric Double Oven - bottom oven won't heat
If ti has a timer that is flashing auto, reset it to manual , as it will not work in auto mode.
Hope this helps.
Plz rate soltuioun.Thanks
Dec 26, 2008 | Ovens
Oven not working
15
problem
8. door will not open.
9. oven will not heat after Self cleaning.
possible Cause
oven is in Self-clean mode.
time of day is not set due to power failure.
oven settings are not correct.
remedy
if oven is hot, door latch will release
automatically when oven temperature
falls below 390˚F at end of cycle.
if Self-clean was just selected
and the oven is still cool, press
“caNceL•SecuRe” to turn off Selfclean.
the door will open in about 30
seconds.
Press “cLock” touch pad, then press
“tiMe•teMP” pad to set correct time of
day.
follow mode selection and clock settings
as specified in the oveN oPeRatioN
section.
oven will turn on automatically
at preset time. if desired, press
“caNceL•SecuRe” touch pad to cancel
out of delay timed mode.
Troubleshooting Guide (Continued)
Important:
If a Failure Code is displayed, the oven will beep continuously until the user presses the “CanCel•seCure” button. the oven will not heat
after a failure. Call a qualified appliance technician to repair the oven.
Oven Failure Codes
Clock Display Cause
f0. touch pad is stuck in depressed position.
f1. Relay circuit failure.
f . oven temperature exceeded the clean runaway temperature (Self-clean mode
only) or the cooking runaway temperature (cooking modes only).
f3. Short circuit in the oven temperature sensor.
f4. open circuit in the oven temperature sensor.
f6. failure in the eePRoM check comparison. (only time of day and timer will
operate.)
f7 failure of the Self-clean automatic door latch circuit.
f8. failure of the door latch motor. occurs when the motor runs for two minutes
without the door locking in Self-clean mode.
befOre yOU Call fOr servICe
No maintenance, other than the Care anD CleanInG
InstruCtIons identified in this use & Care manual, should
be attempted by the owner/operator. all other maintenance and
service must be performed by a qualified appliance technician.
first, review the recommended checks listed in the preceding
troubleshooting Guide. then, be certain that the appliance has
been installed properly and is being operated correctly. familiarize
yourself with the warranty terms and conditions listed in the
proDuCt WarrantY section.
if the above checks have been completed and the problem has
not yet been remedied, call your local authorized dacoR®
service representative. your dealer can normally provide the name
and telephone number of the nearest service company.
prOdUCT maInTenanCe
If yOU need servICe...
dacoR® works diligently to ensure your satisfaction when
service is necessary. However, if you are not completely satisfied
with the service provided, contact the company that performed the
service and express why you are not pleased. Normally, they will
be willing and able to resolve the problem.
if the service agency is not able to respond effectively, call or
write the dacoR® customer Service department. the phone
number and address of this department are listed on the inside
front cover of this manual. Please include your telephone number
if you choose to write. we will then do our utmost to assure your
happiness and satisfaction.
Here is a snipet from www.dacor.com
You can view the manual there by enter ing your oven model number.
Feb 22, 2008 | Dacor ECD230 Epicure Electric Double Oven
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Dacor ER36D Stainless Steel Island Trim Kitchen Range Logo
881 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
