Question about Microwave Ovens
The microwave was cooking, a few seconds later it ceased working
I cooked the porridge this morning in the microwave for three minutes. I then put in a cup of water that did not even get warm. Since then it will not cook? It appears everything else works?
  • treborlertoc Feb 15, 2009
    Thank you for your quick response. I cooked the oats for breakfast in the microwave. A few seconds later I tried to boil a cup of water in the microwave but it remained cold. It appears that everything else is working except it is not cooking. Thank you!
  • Mark Egan May 11, 2010
    It sounds like either the door switch has failed, or there is a problem in the microwave circuitry or components.
    Reply back if you want to pursue the repair further, or check my Tips and Tricks for some insite as to how microwaves work.
    Scholar:
  • 87 Answers
If it's not making a strong buzzing sound or anything out of the ordinary, it's probably the Magnatron. Most of the time that's what I find. It's the "antenna" that creates the microwaves. Some ovens carry a 5 year warranty on that part so I would check your manual. They are very easy to replace most of the time. They usually run about $100-$150.00
Posted on Feb 15, 2009
My microwave starts running when you open the door how can i fix that
It is supposed to. It is designed that way. It put the light on and the extractor fan to remove steam and cooking smells. Some have a timer that continues to run for a few minutes after cooking. It is not emitting the cooking radiation when the door is open. The are at least three safety devices to stop that.
Oct 06, 2017 | Microwave Ovens
Our microwave, a (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few minutes later i
Not enough venting. Imagine putting your hair dryer on full and putting it that cabinet. Would your venting keep it cool? Your microwave oven uses about the same current
Dec 20, 2014 | In Microwave Ovens
Microwave stops after 59 seconds
Check that a "favourite" setting has not been selected. The unit may think that is the time that you want to cook. Im not sure about your model but see if there is any clear or cancel buttons to clear any pre programmed selections. If not, unplug the machine for 15 minutes to reset the controller and try it again.
Nov 25, 2013 | Electrolux Microwave Ovens
LG microwave intermittently runs
I would try troubleshooting the "defrost circuit". The behavior sounds like the microwave is cooking in the defrost mode, where it actively cooks then stops allowing the food to rotate and the heat to spread then actively cooking again.
Nov 06, 2013 | Microwave Ovens
I have owned a AMC5101AAW for about three and a half years. It has been a good microwave,perfect for my needs. The display went black and the buttons didn't work right after I boiled a cup of water for...
It sounds like it could be just a bad crimp connector supplying power to the whole system, which would have to be the fuse holder on the mains input panel.
Worth a look!
Jan 01, 2011 | Amana AMC5101AAS Stainless Steel 1000...
Heating ceases after one second
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
May 30, 2010 | Panasonic NN-H275 Microwave Oven
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
Microwave works for 30 seconds and then turns off
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 23, 2008 | Microwave Ovens
Comes on when you open door, and now it finally quit working
I think you've put up with enough hassle from this unit and should get another one. Intermittant flakey problems are hard (read expensive) to fix.
Dec 29, 2007 | Panasonic NN-S962 Microwave Oven
Maytag Over the Range Microwave
Assuming the entire power line from the breaker to the microwave cord is okay, it's almost certainly a bad connection on the circuit board of the control panel assembly. For reference, we repair these from all over the country for $32.50 postpaid.
Oct 16, 2006 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
139 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
