Question about Sony VAIO FRV28 Notebook
AC Power adaptor wont work without usb printer connected
I have a Sony VAIO Lapto VGN-FS550 that would not charge with the ac power adaptor by itself ... the icon on the task bar show the battery only. when I plugged my HP printer USB Connector the icon will show the ac connector adaptor and begins to charge if I removed the USB connector it goes back to battery and wont last for more that 20 minutes ... also the cpu fan is not working... can some one help with this issue.
Thank You Alberto.
    Sergeant:
    Champion:
  • 237 Answers
Hey alberto,
First off thanks for choosing Fixya.com. The Ac adapter itself could be bad or it could be the dc jack. And also the problem with your cpu fan could also be that the fan has gone out or the motherboard itself needs to be replaced.
Posted on Feb 15, 2009
Battery will not show or charge even with new battery. It will run on a batery that has a charge in it but will not charge one. Is there a fix or is there a charger that can be use instead of one in...
With my laptop, I held the power button (still with everything removed) for 30 sec to decharge the capacitors. Finally, put the battery back in and plugged in the adaptor and everything worked
Jan 11, 2011 | Sony VAIO VGN-A790 Notebook
Hello experts, I am havig problems with my Sony VGN-Z56TG. When I start up my computer, the Sony Vaio Gate does not open or respond. Thanks, John
you dont here any sound or wont see anything on the screen?
try doing this..
  1. disconnect the computer from a power outlet
  2. remove the battery
  3. without the ac adapter and the battery, press and hold down the power button for 7-10secs to release static electicity
  4. put back the battery and ac adaptor then turn on the computer
hope this works.. ü
Mar 12, 2010 | Sony Computers & Internet
Wont power up, today.
try doing this
  1. disconnect the ac adapter and the battery
  2. reseat the RAM or memory if you can. if not, its ok
  3. press and hold down the power button for 7-10secs even without the ac adapter and the battery to release static electricity
  4. reconnect ac and battery
  5. try turning it on
Jan 26, 2010 | Sony VAIO VGN-N110G/W Notebook
Sony viao wont boot, battery light flashes amber once when power button is pressed, AC power indicator on laptop is green and responds to being un-plugged and the adapter LED is green,but it still wont...
Move the power jack around while plugged in, does the blinking on the battery stop when you hold it in certain positions? If so, your dc-jack needs to be soldered, but i probably was loose already before you started using it. It could be a broken motherboard issue as well. You can try to open the laptop and check the dc connection. There is a Laptop Repair Guide that shows you how to take apart a laptop, the sony may be made in a similar way. Sony Repair NYC
Jan 17, 2010 | Sony VAIO VGN-N325E Notebook
Sony vaio vgn-fs630/w. the ethernet port and usb ports not workin
The best thing you can try is a Static discharge.
Please remove all the external devices. Unplug the power adaptor.Remove the battery. There should be no electricity connected.
Then press the power button and keep your finger on it for about 30 seconds to release any build up electricity.
Plug in the adaptor and battery again and see if there is still a problem.
Maybe is a good idea to get a surge protector in the future.
Regards,
Purito
Oct 17, 2009 | Sony VAIO VGN-FS630/W Notebook
My sony vaio vgn-fs285e will not switch on since this morning. Even if the AC adapter is plugged-in it still won't come on. None of the lights come on, it won't run with the battery pack or just AC power....
To check if the problem is the power adaptor or the Vaio, just have a look at the charger itself and see if the green light on the adaptor itself is on?If yes, then more likely it is working fine. If no light, change the fuse in the plug and try again.
You can also try a static discharge on the Vaio. Please remove all external devices, unplug the adaptor and remove the battery. Put your finger on the power button and hold it for about 30 seconds. Then connect the power adaptor again and try to boot.
Regards,
Purito
Oct 17, 2009 | Sony VAIO NR Series Notebook VGNNR460EP
Sony vaio VGN-CR116E/P its work properly with the battery but when you connect AC power after 20 minutes its shutdown
go to your task barat the bottom of the screen and look for the mini icon of the battery with a ac power plug right click it and go to more power options and brows through there there should be an option to change the power settings and you need to make sure that when on ac power it is set not to power down or sleep or shut off hard drive. if you need more information let me know what Operating system you are using and i can be a little more detailed
May 07, 2009 | Computers & Internet
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
Sony VAIO FRV28 Notebook Logo
127 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
