Question about Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907fpf will not power on.
Whe i plug in my Dell 1907fpf, i get no power led, and i cant turn the unit on. I opened the case and found a blown fuse which i jumpered, still no luck. tested the buttons and they seem to be in working order. Have some voltages going into the button board, but without schematics, i cant tell what its supposed to be. changed out 2 mosfets and also no luck. Everything seems to be in order. Can anybody help?
  • darrelld
    darrelld Mar 13, 2009
    Same exact problem and model as shadyb92. I suspect a known bad part that Dell's not reporting. Any luck with this?
Please search for "Power button stuck on Dell 1907FP" and see the advise from other members. I solved my by following their instructions.
Posted on Mar 19, 2009
My cd-rom on dell Dimension 8250 pc desktop computer will not show up on my computer. Am i missing cd-rom drivers.
hello,
1.first go to http://support.microsoft.com/mats/cd_dvd_drive_problems
click on the green button that has run now
Run the microsft fix it tool
if it works GREAT! if not go to #2
#2 go to this site http://www.techsupportall.com/fixed-solved-cd-drive-not-found-not-detect-remove-upper-and-lower-filter/
follow instructions
IF THAT WORKS GREAT! if not proceed to 3
#3 turn off computer unplug power cord.
open your computer case unplug the cables that connect to the back of the cd rom. plug computer back in power it up. shut it down once it loads. then once it is powered down open case again and plug the cables back in make sure they are connected well. close case and power up the computer.
hope that helps
Nov 25, 2012 | Dell Dimension 8250 PC Desktop
I got a dell monitor. model number 1907Fpf. i plug it in via DVI and its power cable and it wont turn on. the power button just blinks at a steady rate and dosent react at all when pressed.
Does it do the same using VGA cable? Same problem with another PC?
If it does not work with other PC, then you will have to take it apart.
It may be in the shutdown/restart mode due tp shorts circuits.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Nov 07, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
Optiplex SX270 LED light code
Hello
The LED code you described indicates a memory failure. Remove and re-install all of your memory. If this does not fix the issue, remove all memory and insert one stick at a time until the unit turns on. Replace faulty memory.
Here is the LED Code guide from Dell...
http://support.dell.com/support/edocs/systems/opgx270/en/ug/solve.htm#1235408
May 01, 2010 | Dell OptiPlex SX270 PC Desktop
The power led and reset was both on
We have to open the system unit where the motherboard is located, but first pull off the power of your computer so that there will be no ground.
Removed the cover, before touching any part inside the system unit (motherboard) touch first the casing or chas-is of the system unit to removed the static in our body.
Let us first remove the reset wire usually the color is red and black it has a name reset at the connection pin at the mother board usually found at the bottom of the mother board, or follow the reset botton wire found infront of your system unit.
After you have removed, try to plug the power of your computer and turn it on. We can open our computer if the reset connection is off.
That will be the first step to know the cause of the problem. Try also to clean the motherboard using vacuum cleaner the portable only or clean paint brush, cause some of those problem due to dust.
Oct 18, 2008 | ASUS P5P800S Motherboard
Yello power light, dell
1st remove all PCI cards, see if anything changes.  If no change\:
If the power LED is solid AMBER, replace the motherboard
If Flashing AMber, replace the power supply
Sep 08, 2008 | Dell OptiPlex GX260 PC Desktop
Europe-to-usa power supply problem?
Hello Sarah, I brought mine in Europe too and found out that they are rated for 220 VAC while in the US you will need a 110 VAC power adapter so if this is your case you need to buy a replacement.
Jul 30, 2008 | JBL CREATURE II Computer Speakers
POWERSAVE
I have A "Dell" E152FPc, and I have found an open transistor (Q201) on the Power Supply Board. My monitor comes on nice and bright for approximately 2 seconds, then goes dark; the power LED is steady. The voltage to the PWM IC is waky.
Before you try any hardware troubleshooting go to your control panel and turn off any power management options.
May 26, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Dimension 8200 will not turn on
Try a new power button. Also does the machine power light turn on at the front of the machine? if so check that the CPU is seated correctly as if it has come out of position then the machine doesn't boot. I would like to think power switch though.
Thanks J
Jan 17, 2008 | Dell Dimension 8200 PC Desktop
Case upgrade for Dell Dimension 4100
The easiest thing to do it is look at your motherboard and make a note of the manufacturer and model/version number, as Dell don't make their own boards. Go to the manufacturers web site and search for the manual probably in PDF format and download it and look for the relevent power button connections.
Oct 11, 2006 | Dell (2336V) Motherboard
Dell UltraSharp 1907FP 19" LCD Monitor Logo
1,026 people viewed this question
Alun Cox
