Question about NRS Oregon Bar And Chain Set For Echo Chainsaws 16" Oregon # 105700 Fits Echo Models 280, 290, 300, 301, 302, 302S, 315, 330, 351, 3000, 3400, 3451
Echo kloritz302s Gas mixure
    Problem Solver:
  • 12 Answers
40:1
I Don't think you could go wrong with that, Its one small 2 cycle oil mix bottle to 1 gallon of gas.
Posted on May 27, 2009
How due I adjust Air to gas mixure on a lp gas system
There is a metal ring on the front of the burner with a couple of slots and a locking screw. Loosen the screw a bit and turn the ring until the flame burns better, should be mainly blue.
Sep 30, 2014 | Imperial IFS40 Deep Fryer
I put a mixure of oil and gas in my 1999 cadillac deville how to drain it out
Use the in tank electric fuel pump to pump it out by jumpering the fuel pump relay socket with the key on. The relay is located under the hood in the fuse and relay center. Unless this is a very high mist of oi to gas you need not do this, just top it off as soon as its low and continue to dilute the gas.
Feb 24, 2012 | 1999 Cadillac DeVille
Have a sears 32cc craftsman weedeater that turns on but as soon as I push thegas trigger it turns off. Put a new fuel line, spark plug and clean the carb. What should I do next?
Sounds like your idle fuel mixure is too lean, depending on how old you trimmer is, it should have 3 adjustment scews, one for the idle, one for the low idle mixure, and one for the high idle mixure. If all three are a flathead screw type you can make the adjustment yourself. look for the one labeled "low" and make your adjustment counterclock wise in 1/4 turn increments until it runs properly. you shouldn't have to adjust the high mixure screw. if you don't have the screw type adjustments, them you may need to buy a special tool (available at most lawn mower shops) to make the nessesary adjustment. make sure you leave the Idle Screw alone though( the one that move the cable) as adjusting this one will make adjusting the mixure harder to get right.
Sep 13, 2010 | Garden
Echo gt 2000 wont start
Mix the fuel/oil ratio an ounce of two cycle oil to a quart of gasoline or 4oz of two cycle oil per gallon of gasoline. I don't think that the fuel mix is the problem though. Check the screen at the exhaust port and clean out any carbon build-up found there. I would clean or replace the in-tank fuel filter as well. Anyway, hope this helped and best wishes.
Aug 18, 2009 | Craftsman 25cc Gas Line Trimmer
What type of oil do I need to mix with the gas for the Echo PB 2100?  Also, what ratio?
Misplace your Manual? Want to view a Safety Video? Look up a Part for your ECHO Equipment? Do It All Right Here
  • www.echo-usa.com/documentation.asp?Model=PB-2100&lang=E
  • Echo recommends 89 octane fuel and 50:1 mix to one gallon gas for your pb2100
  • go to this site and find fuel and read about it if you would like
  • i use 40:1 in everything i have and have had no problems
  • The oil you buy make sure it is for 2 cycle engines and not outboard motors
  • 50:1 =2.6oz to i gallon gas
  • 40:1 =3.2 oz to i gallon gas
Jun 07, 2009 | ECHO, Inc. PB-251C Handheld Blower
NRS Oregon Bar And Chain Set For Echo Chainsaws 16" Oregon # 105700 Fits Echo Models 280, 290, 300, 301, 302, 302S, 315, 330, 351, 3000, 3400, 3451 Logo
146 people viewed this question
Top NRS Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a NRS Measuring Tool and Sensor Expert? Answer questions, earn points and help others
