Question about HP Pavilion dv5000t Notebook
Screen fades in and out, have to tap lcd or around keyboard
The screen on my dv 5000 is messing up, it just gets these lines in it and sometimes it goes black, but you can tap on the lcd or on the case around the keyboard and it will go back to normal but adjusting the angle of the screen also makes it mess up. is this problem in the video card or cable running to the lcd? how do i get to these parts?
  • 237 Answers
It sounds that you may have a loose wire underneath. If your mechanically incline you can take of the front my going from the right side and lifting the top where the power button is and working it up starting from right to left. Then you should see 3 screws remove those and slide your keyboard up. There you should see your LCD connections, reseat those and if that doesnt solve your problem you would need to replace your LCD display.
Thank you for choosing
John C.
Posted on Feb 15, 2009
Vizio VW46LFHDTV10A vertical lines on either side of the screen. I tapped screen and left side lines disappeared.
If you wish to get some details; check the site linked here. Pull up older posts. Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 27, 2016 | Vizio VW46LFHDTV10A 46 in. LCD TV
What is wrong with Sharp Aquos LC-40C32U Picture
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site with the keyword "Line fault"
Jul 01, 2015 | Sharp Televison & Video
Thin vertical blue ink bleed line from bottom of Malaprop screen - Fades over time
Yes, it's a screen problem. It could be a loose connection of the LCD and the motherboard or the lid lights gone bad. You can fix that by either resetting the connection of the screen and the motherboard or replacing the whole screen. You would need a technician to do that.
May 27, 2013 | HP Pavilion Computers & Internet
My screen has a green line
If you're screen has a green line, this can be an indication of either the LCD or the video card is failing. To confirm this, try changing the resolution or background image of your desktop screen, then see if the green line disappear. If it doesn't, then it is either the the LCD or the Video Card.
You will need the help of a professional to replace these parts.
Hope this helps.
Jun 24, 2011 | Neoware m100 Notebook
I am getting lines on my laptop screen. the colored lines appeared all of a sudden and hiding half of my screen. pls help
Hi azmiug,
I see that you are getting colore lines on the screen hiding half of your LCD screen, Please see steps below.
*Turn your Laptop OFF.
*Once Turned OFF, Turned the Laptop back ON then keep on tapping F2 on your keyboard.
*By Tapping F2 on the keyboard this will bring you to the BIOS screen, once in the BIOS of your Laptop and the Colored Lines are still present then the problem is the LCD of your laptop and may reuire replacing.
*If the Colored Lines are not present then the Problem would possibly be the connection of the Video Card to the LCD or the Video Card itself.
*Reformatting Windows can be one of the steps to be done to find out if the issue Colored Lines will be fixed or not.
I hope that this will help you with your concern.
Have a nice day,
Apr 24, 2011 | Computers & Internet
Main Display Screen has faded so I can see numbers but not real good
The outer LCD screen is messed up now. Fixing this means replacing the front LCD screen... Go to a local repair shop..
Hope that'll help you..
Happy Holidays...
**please rate my post**
Dec 16, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Phone has begun going 2 a white screen & the pixels are messed up
Yes, its one of two things, the LCD (display) is faulty or the LCD ribbon cable that links the top half oh the phone to the bottom is failling, a common problem on samsungs, but a cheap easy fix.
Oct 26, 2009 | Samsung Propel A767 Cell Phone
HP nx7000 display sometimes still or sometimes flickering horizontal lines then goes and says blank
It appears the video cable connector needs to be seated properly, it may be loose. The connector would be located near to bottom of the screen on the motherboard between the hinge and the top edge of the keyboard.
Depending upon the model of the laptop there is a plastic panel which houses push buttons and indicator lights that is located between the top edge of the keyboard and the bottom of the LCD screen. There are screws at the bottom of the laptop and possible screws on the back next to the hinge securing this panel. This panel would also have small plastic retaining clips locking it into place. You need a thin blade to lift this panel up, be careful not to crack the panel.
Once you remove this panel you see this video connector and cable. the connector may also be held in place with a screw and plate.
Jun 03, 2009 | HP Compaq Business Notebook nx7000
Laptop screen keeps going fuzzy!
The display connector contact on the motherboard is loose. If you can open the casing, you'll see a ribbon cable from the LCD part connecting to the motherboard. The connector is usually rectangular and connects downwards. Try pressing it in firmly.
Mar 30, 2009 | Computers & Internet
HP Pavilion dv5000t Notebook Logo
119 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
