Question about ASUS A7A133 (A7A133/WA) Motherboard
Forgot CMOS password
Motherboard: ASUS A7A133 ATX.
    Problem Solver:
  • 4 Answers
Take battery out for 3min and put back
Posted on Feb 15, 2009
How do I reset the bios password on an Asus P4S-E motherboard? Cannot find the jumper to do this!
Remove the cmos battery for 15 min.
This will reset the password.
Enter the bios and set the boot settings
Clock,drive boot priority,etc.
Here you can download drivers and a manual:
http://support.asus.com/download/options.aspx?SLanguage=en
Hope this was helpfull.
Mar 29, 2011 | ASUS P4SE Motherboard
I want to reset bios password of My Asus TUV4X, because I forgot the pasword instead.
remove all power from the motherboard. then remove the round back up battery from the circuit board. if the battery has a metal clicp on top it's best to gently slide a piece of paper between the arm and the battery as those clips are easy to break. some motherboards actually have a jumper you move to another position to accomplish this. i do not have the manual so this is the next best bet. wait about ten to fifteen minutes before removing the piece of paper and reapplying power. the password should be removed.
p.s. don't count on this working on a dell system
Sep 28, 2010 | ASUS TUV4X (TUV4X/533/PA/6P-UAY)...
I have a series of 10 beeps every few minutes. What does this mean?
10 Short Beeps Your problem lies deep inside the CMOS. All chips associated with the CMOS will likely have to be replaced. Your best bet is to get a new motherboard. (for AMI BIOS)
Oct 26, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
I have asus mother board support to core 2 duo and quad core recently purchased and inserted quad core processor. Problem is forgot my password. How to avoid that trouble myself
what kind of password? bios or administrator password should be clear!..
if bios password reset it.. else administrator use PROGRAME OR SOFTWARE TO REMOVE IT.. LIKE < password changer which can dowload from the internet... try it..
Sep 12, 2009 | ASUS PC-DL Deluxe Motherboard
Forgotten password ASUS P4P800-VM
There is a blue jumper located just below the lithium battery on the motherboard. You need to remove the jumper and move it to the two pins on the right for about 10 seconds to clear the CMOS then move the jumper back to where you found it. That should clear out the password. It will also change all the BIOS settings back to factory so adjustments to the BIOS may need to be made after reset.
Sep 06, 2009 | ASUS P4P800-VM Motherboard
Won't stay on long starts the just stops
I am sorry to say this but the problem you are describing is usually caused by a board failure. Given the age of the motherboard it is likely that it is finished.
However, before giving up, make sure that battery on the motherboard is good, all of the hardware is seated and plugged in tight. You could also try another power supply.
Apr 15, 2009 | ASUS A7V133 Motherboard
System won't boot
Your motherboard has a chassis intrusion detector. This just means that someone opened your computer case. Since you did this to change drives all you need to do is reset the detector and you'll be fine. You should have a setting in bios to reset the detector. Hope this helps.
Apr 08, 2009 | ASUS A7A133 (A7A133/WA) Motherboard
Need to reset Asus k7v bios
Yes, if you consult your motherboard manual this will show you the location of the cmos battery and reset jumpers. You can either move the jumpers from pins 1+2 to 2+3 and then back again after a few seconds or remove the cmos battery for a few seconds. Make sure your pc is off!
Dec 16, 2008 | ASUS VIA KX133 Chipset K7V (K7V/500/SWA)...
Windows boot password reset
to delete any bios password, remove the cmos battery and locate the bios clear terminals, normally called JBAT1, CLRCMOS, CLRCLK or similar, refer to the manual.
Nov 26, 2007 | ASUS M2N-MX Motherboard
ASUS A7A133 (A7A133/WA) Motherboard Logo
43 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
