Question about Fuji FinePix S1000FD Digital Camera
Color noise on pics
I noticed alot of colored noise on my pics how do i get rid of it or is it there for good?
  • lalena515 Feb 28, 2009
    Thank you for the response i will try it . peace pharoh
Camera is setting a high ISO, probably due to low light. Higher film speed results in higher grain. Try turning off high speed shooting mode which ups the ISO so cam can set a higher shutter speed. Or, select the P setting (Program) and select a pre-set ISO under 400.
Posted on Feb 28, 2009
We have a Samsung #HLN5065WX/XAA that has started making a very strange noise and flashing "Check fan no. 2". The colors are also off. What can I do to fix this?
The tv is making loud noises like humming or motor noises and tv have strange colors flashes or black and white backgrond flashes.The tv Colors wheel it is dying and not spinning the right speed of it RMP speed any more.The tv colors wheel must have be replaced to solved this problems.Have no mechanicals skills hire a tv tech. to change the tv colors wheel because u have to take out alot of mechanical parts out before u can come to the tv colors wheel itself to replace it.
Aug 20, 2011 | Samsung HLN5065W 50" Rear Projection...
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
The pictur freezes to balck and white.
Tv have a colors wheel design into it.Tv make alots of noises like grinding,humming,buzzing or pictures freezes or lost colors or flashes black&white flashes within the pictures.The tv colors wheel it is dying and the colors disc is it warping and not spinning correctly inside it motor walls axis anymore.The tv colors wheel must be replaced.The tv colors wheel sit way back of the tv and have to take out alot mechanical parts out before even can come to it and change it.If u have no mechanical skills.Don't attemp change the tv colors wheel by ur self.Hire a tv tech.person to change it.
Jun 30, 2011 | Samsung HLN617W 61" Rear Projection HDTV
There has been a gray shadom on left side of screen, maybe 3 inches wide, for the entire length of the screen. I can see through the shadow, but it is noticeable.... any thoughts?
This tv have a colors wheel design in it.Flashes or discolors on this shadow?Tv making any humming sound or motor noises.Yes,mean the tv colors wheel is dying and spinning out of it motor axis.The color wheel,is the problems.Colors wheel sit way back of the tv,must take out alot of mechanical parts to get to it to replaced.U have no mechanical skills,don't tries this.Hire a tv tech to replace the colors wheel.
Jan 17, 2011 | Samsung DLP HL-P5663W 56" TV
TV will not come on. Tries to start, no pic, then shuts itself off. Humming sound like fan runs for a while and then stops.
This tv have a colors wheel is dead,require a new colors wheel replacement.Tv humming,loud squiling or motor noises and picture flashes black&white within the picture.The problems is the colors wheel are worn out or warp and it not spinning correctly in it motor joints anymore,it is the tv causes.Call the tv repair shop for a tech. to repair and replacement of the colors wheel.This job,it not simple,must take out alots of machanicals parts,even come to the colors wheel itself to replace it.
Nov 26, 2010 | Samsung HL-S4266W 42" HDTV
The bulb has been replaced within the last 3 months and everything has been working fine. When I turned the TV on just now there is a buzzing sound sounds like a motor is running and continues to run for a...
Ur colors wheel it dead.It spinning of it axes.The noise u hear it the grinding of the colors wheel.There no colors,big buzzy loud noise,or grinding noises.In any kind of DLP tvs that produce the last 10 years they all have colors wheel's.Hire a Tv repairman for this job.Because it require alot of taking out of machanical parts,even can come to the colors wheel part to replaced.Many people made a mistake think it was easy,cost them alot more $$,because tv's tech. don't like fixing other people mistakes,and blunders.Give them a head aches tries figure out what the customer did.
Apr 10, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Picture color is pinkish and out of focus
there might be a problem with ur monitor.
Step 1 - check these pics on sumone else's comp or open sum other jpegs just to check
Step 2 - If the pics are fine on sum other comp then ur monitor needs attention
Otherwise
use Adobe photoshop
adjustments ----> color balance to get rid of pink tint
Apr 05, 2010 | Canon PowerShot A95 Digital Camera
Color wheel
The motor is nothing more than a harddrive motor, not sure that was the right solution but.... I would suggest that your chassis is not in the right location. Verify that the chasis is centered on the mounting bosses. The screws might be a good clue. Good luck.
Jul 05, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
52 rca concave pic and bad colors
concave and colors off indicate the convergence cuircit is bad. which can be one of three boards. sorry
Dec 08, 2007 | RCA HD52W56 52" Rear Projection HDTV
Fuji FinePix S1000FD Digital Camera Logo
69 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
