Question about Jenn-Air JES9860 Electric Kitchen Range
Plastic melted on burner- how to remove?
1) Accidently laid one of those heat resistant hot pads that are like rubber and it melded onto the burner surface
2) Accidently knocked a plastic vegetable container from the store on another burner and it melted on.
Anyone know if I can remove these melded on chemicals or do I have to buy a new top range?
Thank you!
    President:
  • 1,214 Answers
Just allow all the plastics/rubber and burners to cool and then peel off any melted plastic/rubber. Wipe the burners with a mild cleaner like Formula 409.
You may get a little smoke and odor the next time you turn the burners on next time, or if you didn't remove all the plastic.
Reply back if you have any additional questions.
Posted on Feb 15, 2009
  • 296 Answers
If you can break away the plastic then you will be fine, but never use a scraper on them. If all fails replace.
Is there a seal between the nozzle and the tip? I have glue leaking out everywhere??
No, no seal. The heating element is just a heated tube with the nozzle simply threaded into its end. The heating element in your glue gun may be cracked. Or... possibly... you (or someone in your household) got it hot and laid it down and left it that way for a LONG time, and the melted glue backed up inside the heating element. A glue gun should never be laid on its side while hot but idle, especially for long periods of time.
Jul 31, 2014 | Stanley GR100 DualMelt Pro Glue Gun Kit
Burner stains Hot cookie sheet accidently set on
abrasive cooker cleaner. and pad. should clean it off. give it a good scrub.
Oct 27, 2013 | Kenmore Cooktops
Melted plastic on heating coil
you can not remove the plastic safely please replace the heating element
Sep 30, 2013 | Frigidaire (FEB30S7D) Oven
On my glasstop a hot pad melted on it how can i get it off without scratching it
Hi, Ms. Stubblefied. I am sorry to learn about the heating pad melting on your range top. You can use cooktop cleaner to try to remove what you can from the top of the range. Then, using an oven mitt to cover your hand, turn the burn on very low, and use a scraper to gently remove the melted pad. Be sure to use care as the burner will be on. You may not want to do this if the scraper is plastic, as that may melt to the range top. If you do not want to do this, then you may need service. Here is a link you can use if you need service:
Apr 05, 2012 | Maytag MER6772 Gemini Electric Kitchen...
The on off switch broke off.
***Disclaimer***
If you are under the age of 18 please get a parent or an adult to supervise please. This repair calls for a Hot Soldering Iron and or another hot heat source to melt plastic. You can be injured and nobody wants that.
If it broke on the copter itself you may be able to remove the switch and replace and resolder. If it happened on the remote open the remote and remember to keep track of how many screws and whee they came fromonce you have the top cover off get a small screw and heat it while holding it with a pair of plyers or hemostats, not red ht but hot enough to melt into whatever remaining plastic is left of the original switch. If NO plastic is left then you have to eaiher replace the switch itself, requireing you to find an available swith and resoildering it onto the board. Good Luck!
Dec 28, 2010 | Air Hogs Glow In Dark Havoc Stinger Rc ...
I have plastic melted on my glass top (son let plastic bag touch hot burner). i can NOT get it off. any suggestions?
Getting the plastic hot again may allow you to remove the bulk of it. I'd use something wooden to scrape with. I'm assuming that the glass top you're talking about is an electric stove. You have this listed under the "Timers" category and not many of them have glass tops. Dabbing a small amout of acetone onto the plastic without touching the glass any more than you have to should help you disolve the plastic so you can finish scraping it away.
Dec 02, 2009 | Hardware & Accessories
I have a Kenmore stove and was cooking several things on stovetop burner and accidentally put a plastic bag of tortillas on top of hot burner and the plastic melted all over the burner. I soaked the burner...
We are factory authorized Kenmore service & parts suppliers. We have all the parts you might need.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number and we will get the correct burner element out to you asap.
We look forward tow roking with you and getting you cooking again soon.
Nov 09, 2009 | Washing Machines
Laars lite 2, mod-lg125n, sn. d03pj3400.
sounds like heat exch is plugged.remove top of unit and inspect for nests.could also be plugged with soot because of poor burner flame characteristics.with top off,turn htr on and look straight down into unit. you should be able to clearly see burner flames between fins. if not remove exchanger and clean
Jun 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Front brake pad replacement
black caliper and black caliper bracket = ATE (Teves), the other color is Akebono. To replace pads, use a screwdriver to stick into slot to pry caliper open a bit. Remove 2 caliper pins (under plastic caps on rubber caliper boots.) Lift caliper from rotor. Remove old pads. Wipe caliper anti-squeak onto back of new pads, and place pads into caliper. Replace caliper onto rotor and bracket. Insert pins and tighten securely (you can lubricate the pins) Replace plastic boot covers. Install wheels. Lower vehicle.
Jul 16, 2008 | 2000 Jeep Grand Cherokee
Jenn-Air JES9860 Electric Kitchen Range Logo
427 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
