Question about Cuisinart Coffeemakers
My Cooks Coffee Maker just beeps but doesn't brew
As soon as I press the button to turn it on, I just get the beeps that I used to get at the end of a brewing cycle, to let me know the coffee was ready. It doesn't do anything else.
  • 3 more comments
  • nonniepatch Feb 18, 2009
    It's Model Number CM4158TA
  • kaitlinmay Feb 25, 2009
    About one minute after I press the 'brew' button the coffee maker beeps as it previously did when the coffee was ready. I had this problem a few months ago and I stopped using it for about a week and then it started working again. It worked for months but stopped working yesterday.
  • Anonymous Mar 14, 2009
    The coffeemaker just doesn't brew. The lights come on but nothing happens.
  • Anonymous Mar 21, 2009
    Same problem. When I push the button to brew it beeps 5 times as if the cycle is complete but it never started., Model is CM4158TA
  • Mark Egan May 11, 2010
    It sounds like either the temperature sensor or controller board has failed.
    Please provide a model number and we can check if the parts are available.
SOURCE: Kenmore Coffeemaker 100.82006
hi gayley i could have wrote your post. i am so mad . i brought this coffee pot in oct. or nov and really liked it . it brews really fast . now i cant find the receit. hope some one knows what to do
Posted on Feb 16, 2008
Coldcut
  • 1554 Answers
SOURCE: turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Posted on Apr 02, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart coffee maker won't brew
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Posted on Dec 15, 2008
  • 2039 Answers
SOURCE: Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Posted on Feb 14, 2009
Doesn't work, just beeps
press and hold the power button, that should reset the unit.
Oct 02, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Lite is on will not brew there is water and coffee and it doesnt brew
You can try this.
1. Plug the coffee maker into the wall power outlet. Turn the switch on. The light will glow. Then press the on/off switch TWICE. The coffee maker will start.
2. If the machine doesn
Aug 02, 2011 | DeLonghi DCM485 Coffee Maker
I turn on my Mr. coffee maker and it just beeps and won't brew any coffee. What could it be?
Tried to clean it, everytime you press the brew button it just beeps and if we try to set it to clean it sounds like it tries to turn on but nothing happens.
Apr 27, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Need To Turn Off Beeping After Coffee Brews
on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
May 15, 2009 | KitchenAid Pro Line Coffeemaker Coffee...
Error keeps popping up
PROBLEM
CAUSE
SOLUTION
3 beeps sound and E:rr flashes on LCD display (31)
prog (24) was pressed before clock time was set
auto (23) was pressed while no program was stored
TSB was pressed (25) before brew cycle was complete
Set clock time, then set the program
Set the program first.
Wait until brew cycle is complete and 2 beeps sound
Mar 05, 2009 | GE 106591 Coffee Maker
Cannot turn off alarm.
The machine will not run if the covers /for the coffee grinder, the filter basket and the machine itself) are not properly closed.
It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button.
Hope this will help you.
/Mirran
May 09, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Turning off the beeper
The manual is not too clear on this function. Turn the coffee side on, press the middle button on the coffee side for > 2 seconds and then use S1 and S2 button to select a mode that does not show the bell.
Jul 11, 2007 | Krups XP2070 10 cup Coffee Maker/15 bar...
Cuisinart Coffeemakers Logo
599 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
