Question about Daewoo Heating & Cooling
A?C Doesn't work. NO cooling
I take the cr to the Mechanic for check A?C and the anwser was, change Compressor and Dryer. I'm looking for good A/C Traden and how much cost. Thak you
Water coil heat pump do not work in cooling
Posted on Feb 16, 2009
A/c doesn't blow cool air. it stopped suddenly along with the speedometer. mechanic looked at it and said he changed out a relay and all should be fine. speedometer works but a/c still doesn't. mechanic...
There may be two relays with the AC circuits. One will control the AC cooling fan on the radiator. The other will control the AC compressor, to turn it on when requested. Any relays that aren't in the AC circuit would have no affect, whether good or bad. And relays just do not go bad that often.
You need somebody to check out the AC circuit, somebody willing to do a little testing.
Aug 04, 2013 | Pontiac G6 Cars & Trucks
Honda cr- v climate control not working
Don't think your mechanic looked up anything to do with
your model vehicle or cares to
Without diagnostic manuals you can not work on it yourself
I guess a dealer would know more than some repair shops,
most shops would be my first choice, but not the one you went to
Clearing anything is not a fix for anything
If your mechanic told you all sorts of things, then why didn't they
resolve them,they don't know,that's why,most likely have no data base to work on much of anything
If there was low pressure before you bought it, why is it okey now,
but not work properly,sounds like nonsense to me.
Sep 18, 2012 | 2007 Honda CR-V
I have 2004 hoda cr-v the a/c stop working compresor is no cycling
A mechanic would check the fuse for the compressor then see if the system is full of freon.
Jul 30, 2012 | Honda CR-V Cars & Trucks
Abs control module on honda cr-v 2007
ok about the abs is possible that the abs cable that goes the the brake caliper is not good.about the brake light check brake fluid level filled up also check the sensor on the brake fluid container also check any malfuntioning wire connection corosive plugs.about the ac check compressor ad freon in order to kick on check the relay or fuses or the compressor is no good
Jul 13, 2012 | 2007 Honda CR-V
LG Fridge LSC26945TT compressor getting to hot and not cooling
if it's not cooling unplug it so you don't damage the compressor,hopefully you just have a bad overload and relay,it's plugged into the side of the compressor,with the machine unplugged remove the bottom back panel,look at the compressor,remove the cover on the side of compressor and remove the start device or ptc assy. call your local parts store and give them the model number and buy a new start device for your machine.if you can hear a clicking sound every once and a while and the compressor is hot change this out first,if it still doesn't start then you have a bad compressor and will be in the market for a new fridge if the compressor is running take everything out of the freezer,remove the back inside wall of the freezer and check the evap coil,if the coil is all iced up you have a defrost problem,if the evap coil doesn't have an even frost pattern covering the whole coil you have a freon leak.if you have a freon leak you'll have to replace the fridge..hope this helps
Jul 04, 2012 | LG Refrigerators
A/C not cold on 2004 Toyota corolla. Compressor appears to working and we have added freon
if the clutch is turning on that fuse is good check the cooling fan if it doesn't work it will not cool the freon
Apr 27, 2012 | 2004 Toyota Corolla
I have a ''GE"heat &
Look at the wires that go to the compressor and make sure they are not burned off. Inspect the capacitor tops for swelling and loose or burnt wiring. Also check the connections coming from the controls. May have a wiring problem or even a bad compressor. How old is the unit?
May 17, 2011 | GE AJCQ06LCB Air Conditioner
Three days ago, our daughter's 2002 CR-V with about 125k miles had its air conditioning fail. It blows air, but is not cooling the air. We bought the vehicle for $7000 one year ago, and have received an...
had my ac compressor fail in my 02 honda a quote to replace the compressor and drier for 750 total. tried to hold off on the work cause i did'nt want to spend the money. long story short car broke down down on my way from ga to ny and had to buy a new car. if you dont trust the mechanic go for a second quote, most reputable mechanics will do it for a nominal fee fee if they think they;re gonna get the work. just go in acting like you know what you're talking about.
Jul 29, 2010 | 2002 Honda CR-V
My kegerator is not cooling and when i start the unit the pressures dont change is the compressor out or is there a chance the cap tube or dryer is plugged
Good day,
If the pressures don't change, and you can feel the compressor running, then the valves failed in the compressor.
But make sure the compressor is getting power, and the start components mounted on the side of the compressor are working. (overload protecter, Start relay and capacitor if it uses one) An appliance parts house usually can check these components.
P.S. make sure the gauges are connected properly and not cross bleeding.
Feb 26, 2010 | Danby DKC645BLS Compact Beverage Cooler
Ac problems on a 1994 toyota 4runner
Did you put freon in it? If you changed the compressor, you lost compression. A certified mechanic can do this. No one else.
May 21, 2009 | 1991 Toyota 4Runner
Heating & Cooling Logo
172 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
