Question about Timex Watches
How to access older timex automatic watch second hand
older timex automatic watch w/no.3431810879 on dial face , second hand will touch the minute hand sometimes causing the watch to stopĀ  older timex automatic watch w/no.3431810879 on dial face
  • 1 more comment
  • joe Feb 17, 2009
    the older timex watch is an automatic and the movement is held in by tight fit brackets, i need to know how to safely extrude the stem control without damage
  • joe Feb 17, 2009
    this automatic timex is self winding with inertia and is not easily disassembled
  • Anonymous Mar 31, 2014
    match watch hands with sound
    Problem Solver:
  • 7 Answers
You should be able to open the back by popping it off with a sharp knife blade. Sometimes, the lip where you'd open it is hard to see and usually under the band, between the lugs. The movement will just come out. If I read you right, you know how to do this, once the movement is removed. You can't just pull the hands off. Hopefully, you'll be able to just VERY EASILY bend the one that is causing the problem.
Posted on Feb 17, 2009
How do I change time and date on timex indiglo
  • How to Set Dial Indiglo Watches
    • 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
    • 2 Pull the knob out from the watch slowly until it clicks into the first position.
    • 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
    • 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
    How to Set Digital Indigo Watches
    • 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
    • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
    • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
    • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Read more : http://www.ehow.com/how_5758168_set-timex-indiglo.html
    Mar 31, 2015 | Timex Indiglo Watches
    What are the three little faces for? do not have instructions
    Your watch is a chronograph or a watch that includes a stopwatch. Two of the three dials are for recording minutes and hours with the large sweep second hand recording seconds. Pushing the upper button starts and stops the stopwatch function. Pressing the lower resets everything to zero. The small bottome dial is the seconds hand for the watch, it always is moving.
    Dec 29, 2011 | Callaway Golf Unisex CY2085 Collection...
    Hi my Guess chronograpah 123503G1 keeps getting stuck. First it appeared that the hand on the small seconds dial face was stuck. The watch wwill not keep time while this was stuck. If I shake the watch...
    mcdevito75 here, Sounds like your Guess watch neds some service, cleaning, oil etc. You can check with the repairservice directory right here at fixya, bottom of this page click on repair service directory then watches.
    Aug 03, 2010 | Guess 17558L1 17558 Watch for Women
    The minutes, hours and seconds hand popped off. i need to fix them. how to open the case??
    Im sorry, but it is not that simple. You will need to take to watchmaker as they need to remove the whole inside of the watch to get to the face and that requires removing the dial also. No other way to do this. Sorry
    Jul 24, 2010 | Anne Klein AK Automatic Crystal Accented...
    Analog second hand freezes periodicaly, digital clock works fine
    mcdevito75 here, Sounds like the seconds hand is bent and hanging up on the face. See the repair service directory her at fix ya, bottom of the page click on repair service directory the watches.
    Jun 24, 2010 | Timex Expedition 84601 Wristwatch
    Watch erratic. Slows suddenly between days of working well.
    Sounds like a failing battery to me. Its very common for a watch to loose time when battery needs to be changed.
    Jan 09, 2010 | Timex Watches
    The hour/minute/second hands on my Timex Ironman not moving
    It could have 2 batteries! 1.5 volt for analog and lithium for digital! Take it to a reputable watch repair business and let them check! :-)
    Jan 09, 2010 | Timex Ironman Triathlon 50 Lap Digital...
    Resetting stopwatch dials - Armani AR5331
    When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
    Do as follows:
    1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
    2) push the crown in half way back (not completely)
    3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
    4) when big seconds hand is zeroed push the crown back in
    5) pull the crown out again and set desired time
    6) push the crown back in.
    If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
    Rate me, please.
    Apr 03, 2009 | Watches
    Eliminate half moon from dial of a Timex Ironman Triathlon watch
    You need to hold down the Indiglo button for 4 seconds. The half moon means that night mode is activated, and it will tuirn itself off in 8 hours (which I'm sure you know by know, seeing how it's been 5 years).
    http://www.sportswatchinformant.com/timex-ironman-watch-night-mode-feature/
    Nov 13, 2008 | Timex Ironman Triathlon Sleek 50 Lap 5G301...
    Pull the crown to first position (where you set the date) then adjust the dials with buttons.
    uhrmacher
    Jan 10, 2008 | Giorgio Armani Classic AR5326 Wrist Watch
    Watches Logo
    225 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Geoff
    Carol
    Level 1 Expert
    Are you a Timex Watch Expert? Answer questions, earn points and help others
