Question about Whirlpool GH7208XR Convection / Microwave Oven
Whirlpool microwave cook light turns on but oven does not work
I have a built-in oven/microwave combo. Number stamped on the back of the microwave is 3183566B. The problem started a while back with the motor shutting off on its own while cooking. Pressing on the door fixed it temporarily, but it got worse and worse. For a while, the oven worked fine with something pushing the door up slightly. However, now nothing works. The cook light lights up properly, but nothing else happens.
  • joytouchedit Mar 04, 2009
    thanks for your quick response!
    President:
  • 1,214 Answers
Check and replace the door safety switch.
Posted on Feb 15, 2009
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool microwave cook light goes on but oven does not work
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Having had to wiggle the door to make it work is the giveaway.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Your model number (since it's a Whirlpool) will be something like MH1150xxx#m, GH6177XXX#, etc.
The model number will be located on a tag either in the cavity or around the door frame if it's an over the range model, or on the back if it's a counter top model.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If yours is a counter top model, you will need to remove the outer cover.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Feb 16, 2009
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
Whirlpool Talent Microwave The microwave starts off ok, then during cooking its still turning & the light is on but its not cooking. It can go on like this for 8 or 9 minutes and then you hear a small...
That is the magnetron faulty. The oven stops cooking, as the magnetron lose contact, when the magnetron restart working you hear that loud bang, and it restart radiating.
Replace the magnetron.
You find parts here or here.
Oct 08, 2008 | Whirlpool Microwave Ovens
The other day my microwave quit cooking and the turntable stopped turning. The fan still turns on and the light still works as if it is cooking but it doesn't. We shut off the power and tried again but it...
It may just be a bad door switch. See this file.
You can enter your full model number at the Sears parts site to find helpful exploded view diagrams.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
May 27, 2010 | Kenmore 62622 Microwave Oven
Whirlpool microwave only cooks for limited time?
It's possible that the module that produces the microwaves is failing. The parts are cheaper but the labor may not so get an estimate before deciding if it's worth repairing or replacing.
Nov 20, 2017 | Whirlpool GH5184XPQ Microwave Oven
Feb 15, 2009 | Whirlpool GH7208XR Convection / Microwave...
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Kenmore Galaxy Microwave Hood Combo Model 72180002400
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Jul 29, 2008 | Kenmore 62622 Microwave Oven
Whirlpool GH7208XR Convection / Microwave Oven Logo
457 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
